Gauging interest for lowering springs for the KFX-700
This is a discussion on Gauging interest for lowering springs for the KFX-700 within the Kawasaki KFX700 V-Force forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; Mike, is this something that you are working on then?...
Old 06-23-2009, 01:49 PM   #21
Feedback Score: 9 reviews
twyztid's Avatar
View twyztid's Photo Gallery(8)
Default
'04 KFX730
Fundy 11.1:1 Pistons, FST Stage 2 cams, Ceramic-coated Muzzy Exhaust, +8 Swingarm, 12-Hole Mod, UPP Cross-over Intakes, 3/32" drilled main jets, #42 pilots, 3 shims/needle, Elka Front Shocks, Revalved Rear Shock w/ Road Magnet Spring, CCP Steering Stabilizer, TrailTech X-bars/Clamp, Pro-Armor nerfs--grab bar, #2 Blaster Paddles, Polaris Yellow Clutch Spring w/ 2 shims... BOSS NOSS 30-shot
'04 KFX700
DMC Afterburner Quiet4 Dual Exhaust, 12-hole Airbox Mod, Crossover Intakes, #45 drilled main jets, shimmed needles, 6* Timing Advance Key, Spark Plug Boot Mod, Road Magnet Suspension Springs, 24x11-10 8-paddle Skat-Trak Extremes on 10x10 wheels, EPI Almond Clutch Spring
twyztid is offline   Reply With Quote
Old 08-04-2009, 08:33 PM   #22
paulg's Avatar
View paulg's Photo Gallery(0)
Default
just wondering if this has been done yet.. or anythign been updated on it??
FST 715
FST stage 3 cams
FST valve job
FST billet side cover
FST CDI
VFJ stage 3 clutch with spider mods
EPI maroon primary
36mm carbs
SHOTGUN PRO BAR HERE
k&n air filter
YFZ catch can mod
hmf duals
and much much more to come when i get some more money.. the V is a money trap
paulg is offline   Reply With Quote
Old 08-05-2009, 06:32 AM   #23
twyztid's Avatar
Default
Yeah, I am curious too. What happened to "a couple of weeks"?
'04 KFX730
'04 KFX700
Old 08-05-2009, 07:59 AM   #24
mike@bwoodyperformance's Avatar
View mike@bwoodyperformance's Photo Gallery(0)
Default
The company thats making the springs is back logged with work right now, im supposed too drop it off to them at the end of next week, i'll update this post once i recieve the new product in hand.
2009 Renegade X (HID Conversion, Stock)
2009 Polaris RZR (muzzy, power commander, BWoody snorkel kit, clutch limiter removed)
2009 KFX 700 V-Force (AMR 730 BBK, Muzzy SUper Pro, Venforcer +4, xx cams, AMR p&p heads, +1.5 int. +1 ext. Valves, crossover intakes, 6 degree key, Trailtech clamp, trailtech vapor, 12 hole mod, velocity stacks, Twin air filter, maroon clutch spring, custom BWoody oil catch can, Plethora of green powdercoating)
2009 Polaris 850 XP LE(HID, Super Swampers ITP rims)
2008 Polaris Sportsman 500 EFI Touring (AAen slip on, HMF tuner, K&N)
2009 Polaris Sportsman 300
2006 Polaris Hawkeye 300
2007 Dodge Charger SRT-8 (392 stroker 530 whp)
2007 Jeep Grand Cherokee SRT-8 (11.27@122)
2005 Viper SRT-10 Truck (Beater...lol)
2004 Dodge Viper (941whp 984Tq)
2004 Dodge neon (10.43 @ 136)
1968 Road Runner 440 6 pack
mike@bwoodyperformance is offline   Reply With Quote
Old 08-06-2009, 01:27 PM   #25
WOLFPACK 04's Avatar
View WOLFPACK 04's Photo Gallery(0)
Default
if they make it for the v's a triple or double rate spring would be alot softer and smoother and use same travel
WOLFPACK 04 is offline   Reply With Quote
Old 08-07-2009, 07:58 AM   #26
banshee66's Avatar
View banshee66's Photo Gallery(1)
Default 2 inch rear lowering kit
I have made a 2" rear shock lowering kit for my v. It is great. I run Oval and TT races and have no problems with this. I am useing a stock shock with this part.
djbanshe@rochester.rr.com check out our local track www.bataviamotorspeedway.com
banshee66 is offline   Reply With Quote
Old 08-07-2009, 08:31 AM   #27
twyztid's Avatar
Default
On my green V I am running a 2.5" ID x 10" long QA1 coilover spring with a 225-lb spring rate and I had a local guy rebuild my rear shock and make the rebound 25% quicker. I had to have some spacers made for inside the ends of the springs because the stock springs are 2 3/8" ID. It seems way better now but some of that is from the +4 extension. I did all those things at the same time.
'04 KFX730
'04 KFX700
Old 08-10-2009, 01:14 PM   #28
Default
Ok guys I just dropped off my kfx 700 about 2 hours ago, they removed the front springs and checked the rate. The OEM springs are a 265 lb rate. for the fronts they are going to make a 200lb rate spring and a 220 lb rate spring. they want me to come back after they install them and see which ones i like, they should have prototypes made within the week.
Old 08-10-2009, 01:24 PM   #29
twyztid's Avatar
Default
Are they doing anything with the rear spring? I think I had read somewhere that it was measured at a 270-lb/365-lb dual-rate but I could be way off.
After you try them out if would help if you could tell us your weight so we can get an idea if they would feel similar for us.
'04 KFX730
'04 KFX700
Old 08-10-2009, 01:25 PM   #30
twyztid's Avatar
Default
I almost bet that for some of the lighter riders, a lighter spring yet may even have good results. Something like a 175-lb maybe?
'04 KFX730
'04 KFX700
kfx 700
kfx 700 6 degree timeing key
1968 roadrunner 440 6 pak
converting kfx 700 swing arm
2009 polaris rzr
kfx 440 for sale
power commander for kfx 700
You may not post new threads
You may not post replies
any interest in hndlbarmonkey Kawasaki KFX700 V-Force 12 09-18-2007 05:57 PM
Any interest? V-powered 730 For Sale 4 09-13-2007 05:03 PM
Gauging interest DaveHenke For Sale 5 08-10-2007 08:39 PM
Interest? Ranger For Sale 17 03-21-2005 05:46 PM
A arm interest? Big Al Kawasaki KFX700 V-Force 9 11-16-2004 02:28 PM
