Conversion Chart for Drilled Jets
This is a discussion on Conversion Chart for Drilled Jets within the Kawasaki KFX700 V-Force forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; Is there a size conversion/comparison for jets? Fractional drill bits, numbered drill bits, or diameter as compared to Keihin numbered jets?...
Old 07-02-2009, 02:23 AM   #1
Feedback Score: 2 reviews
View NovaKaw650's Photo Gallery(0)
Default Conversion Chart for Drilled Jets
2002 665 FPS Prairie
FPS Trail kit - 12:1 comp due to 1mm shaved off the heads
Mild porting
Crossover intakes
Modded airbox
Full Muzzy
Dalton springs and weights
Other stuff
NovaKaw650 is offline   Reply With Quote
KawieRiders.com is the premier Kawasaki ATV Forum on the web. Registered Users DO NOT see these ads. Please Register - It's Free!
Old 07-02-2009, 09:21 AM   #2
Feedback Score: 1 reviews
kujo's Avatar
View kujo's Photo Gallery(0) Send a message via MSN to kujo
Default
(Width = true hole diameter)
Width------Keihin # -- DynoJets # -- Mikuni #
0.0350---- 92.5--------- 92---------- 86.3
0.0360---- 95----------- 94---------- 88.1
0.0370---- 97.5--------- 96---------- 90.0
0.0380---- 100---------- 98---------- 91.9
0.0390---- 102.5------- 100---------- 93.8
0.0400---- 105--------- 102---------- 95.6
0.0410---- 107.5------- 104---------- 97.5
0.0420---- 110--------- 106---------- 99.4
0.0430---- 112.5------- 108--------- 101.3
0.0440---- 115--------- 110--------- 103.1
0.0450---- 117.5------- 112--------- 105.0
0.0460---- 120--------- 114--------- 106.9
0.0470---- 122.5------- 116--------- 108.8
0.0480---- 125--------- 118--------- 110.6
0.0490---- 127.5------- 120--------- 112.5
0.0500---- 130--------- 122--------- 114.4
0.0510---- 132.5------- 124--------- 116.3
0.0520---- 135--------- 126--------- 118.1
0.0530---- 137.5------- 128--------- 120.0
0.0540---- 140--------- 130--------- 121.9
0.0550---- 142.5------- 132--------- 123.8
0.0560---- 145--------- 134--------- 125.6
0.0570---- 147.5------- 136--------- 127.5
0.0580---- 150--------- 138--------- 129.4
0.0590---- 152.5------- 140--------- 131.3
0.0600---- 155--------- 142--------- 133.1
0.0610---- 157.5------- 144--------- 135.0
0.0620---- 160--------- 146--------- 136.9
0.0630---- 162.5------- 148--------- 138.8
0.0640---- 165--------- 150--------- 140.6
0.0650---- 167.5------- 152--------- 142.5
0.0660---- 170--------- 154--------- 144.4
0.0670---- 172.5------- 156--------- 146.3
0.0680---- 175--------- 158--------- 148.1
0.0690---- 177.5------- 160--------- 150.0
0.0700---- 180--------- 162--------- 151.9
0.0710---- 182.5------- 164--------- 153.8
0.0720---- 185--------- 166--------- 155.6
0.0730---- 187.5------- 168--------- 157.5
0.0740---- 190--------- 170--------- 159.4
0.0750---- 192.5------- 172--------- 161.3
0.0760---- 195--------- 174--------- 163.1
0.0770---- 197.5------- 176--------- 165.0
0.0780---- 200--------- 178--------- 166.9
0.0790---- 202.5------- 180--------- 168.8
0.0800---- 205--------- 182--------- 170.6
0.0810---- 207.5------- 184--------- 172.5
0.0820---- 210--------- 186--------- 174.4
0.0830---- 212.5------- 188--------- 176.3
0.0840---- 215--------- 190--------- 178.1
0.0850---- 217.5------- 192--------- 180.0
0.0860---- 220--------- 194--------- 181.9
0.0870---- 222.5------- 196--------- 183.7
0.0880---- 225--------- 198--------- 185.6
0.0890---- 227.5------- 200--------- 187.5
TRP/FPS (902)893-dyno
DS650 w/FZR1000 engine
kujo is offline   Reply With Quote
Old 07-02-2009, 09:28 AM   #3
kujo's Avatar
Default
Drill Size Chart
here is the chart to convert the standard measurement to the drill bit sizes.
Old 07-02-2009, 09:34 AM   #4
Default
Excellent info, thanks Kujo!
Mild porting
Crossover intakes
Modded airbox
Full Muzzy
Other stuff
Old 07-02-2009, 09:52 AM   #5
kujo's Avatar
Default
no prob.. did you get those heads on the prairie yet?
Old 07-02-2009, 09:58 AM   #6
Default
They are on, so is the crossover intake. Runs good but weak. I've got to get busy and tune it.
Mild porting
Crossover intakes
Modded airbox
Full Muzzy
Other stuff
Old 07-02-2009, 01:15 PM   #7
Supporting Vendor
Feedback Score: 5 reviews
VFORCEJOHN's Avatar
View VFORCEJOHN's Photo Gallery(0)
Default
That's good. but Keihin jets don't go up in increments of 2.5
also a 200 keihin and 200 mikuni are different. but not that different I have them both here in my hand 200 mikuni is about a .087-.088 drill bit so that chart isn't that correct.
unless they are talking about large round mikuni's (about 10mm) like on the harley's and DS 650 carbs??
www.VForceJohn.com (570) 773-1721
VFORCEJOHN is offline   Reply With Quote
Old 07-02-2009, 02:07 PM   #8
Default
I wonder if those 2.5 increments are for aftermarket Keihin jets?
Or if they just took the measurement of the smallest and biggest sized jets and divided the rest into 2.5 increments?
Mild porting
Crossover intakes
Modded airbox
Full Muzzy
Other stuff
Bookmarks
You may not post new threads
You may not post replies
Drill bit size to jet # conversion chart BossMan Kawasaki KFX700 V-Force 21 09-22-2008 08:46 AM
drilled jets for 750 pop Kawasaki Brute Force/Prairie/Bayou 6 07-01-2007 07:17 PM
DJ conversion chart, how accurate? ManicHaze Kawasaki KFX700 V-Force 13 05-24-2007 05:41 PM
Drilled main jets? OHVFORCE Kawasaki KFX700 V-Force 4 05-16-2007 05:53 AM
Is there a conversion chart for Dyno/Keihin Jets? KeithsKFX Kawasaki KFX700 V-Force 3 05-21-2005 12:11 PM
