jetting questions
This is a discussion on jetting questions within the Kawasaki KFX700 V-Force forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; Hello all.Cannot seem to get my quad right at the local bike shops.I have a 06 700 with White bros full system,12 hole mod,6deg key,upp ...
Old 02-07-2010, 10:12 AM   #1
View keithsv700's Photo Gallery(0)
Thumbs up jetting questions
Hello all.Cannot seem to get my quad right at the local bike shops.I have a 06 700 with White bros full system,12 hole mod,6deg key,upp crossover intakes,pink spring.I had it tuned and wont start easy and if it sits for 2 weeks it spins over a while before it tries.When warm it feels great.but it seems rich, it pops on decel,can see flames from the pipe too.my elevation is 108 ft where i ride.what needles and adustments do you guys think i should run,and what would you buy next?
keithsv700 is offline   Reply With Quote
Old 02-07-2010, 11:40 AM   #2
View JRENIGAR's Photo Gallery(0)
Default
well, the upp intakes are the only thing that throws my thoughts off. If it were mine Id go with 42 pilots shimmed stock needles and 180-182 mains to start off. Im guessing probably the only thing that would need changed from that point would be the mains. If you get it right lemme know because Id like to get the upp's also and the 6deg key. Other than that were about the same as far as mods go.
HMF duals, EPI pink spring, 12 hole mod, UNI filter. Horsepower recipie: cheap, fast, reliable. You can pick any two you want!!!
JRENIGAR is offline   Reply With Quote
Old 02-07-2010, 05:29 PM   #3
Feedback Score: 1 reviews
Kenny4's Avatar
View Kenny4's Photo Gallery(9)
Default
Keith---Why don't you put up a signature with the above info--Easier for you and those trying to help-----Did they adust the vakves????
Kenny
"As For Me And My House We Shall Serve The Lord"
2007 KFX 700 V Force------"DIY MODS"-----Pink Spring---Yoshimura Duals---12 Hole Mod---Twin Air Power Kit---1 Shim & Cut Springs---Polished Slides--- 3.0 turns out---#40 Pilots---182F/185R---Spark Plug Boot Mod-----------"OTHER STUFF"---Odi grips---Full Under Armor---Billet Stator Cover---HID Lights---Trail Tech Vapor---Pro Armor Front Bumper---Rear 6 Pack Rack---Nerfs--22x11x10 Haulers 10 Paddle---22x11x10 Edges 9 Paddle---Quick Release Lighted Whip---IMS 4.6 Gas Tank
2005 Honda Rancher 350ES
The Avatar picture is my custom home for sale in Yucca Valley, So. Calif.
Kenny4 is offline   Reply With Quote
Old 02-08-2010, 10:56 AM   #4
Default
valves are right, however it helped some onc they were adjusted. also you have to push the throttle some when cranking too.Im not good at tunningand wonder if anyone can rec a GOOD tune shop in wilmington nc area
06 kfx 700,upp intakes,,pink spring,white bros full exhaust, grab bar,upgraded tie rods and ends,still original tires and battery,black plastics!
Old 02-08-2010, 05:07 PM   #5
Kenny4's Avatar
Default
Do you know what size pilots and main jets are in it---Before you take it to a shop---Give it a try here---The guys here are great and can walk you through most any repair even if your novice at it---It's a great feeling to tackle something a little over our heads and accomplish it---You'd be surprised at what you might be able to do with these guys tutoring you---Just sayin.
Kenny
Old 02-08-2010, 05:26 PM   #6
GarDog's Avatar
View GarDog's Photo Gallery(0)
Default
^^^^^what he said^^^^^:d
Green 04 KFX700...HMF Duals... Mechanical Oil Pressure Gauge...Spark Boot Mod...TwinAirPowerFlow...(15) 1" holes + (5)1/2" holes in lid... 3/32 drilled jets...springs cut...one #4 washer on needles...slides polished...more to come...
GarDog is offline   Reply With Quote
Old 02-08-2010, 06:43 PM   #7
Feedback Score: 4 reviews
Toyotadude's Avatar
View Toyotadude's Photo Gallery(3)
Default
I agree. Jets are easy to change and something to get your feet wet to work on these.
04 KFX700, HMF Duals, Dynatek CDI, #42 pilots, American Star Racing 2" extended A-arms, G-Force Honda 400EX extended rear hubs, 22-7-10 Sand Stars in front, 24-11-10 8 paddle Extremes in Rear, K&N air filter, AC Nerfs & Six pack rack
86 Toyota 4X4, 4.3L Chevy V-6, 700R-4 trans, Marlin Crawler dual transfer case, limited-slip front diff, ARB rear diff, custom flatbed w/aluminum diamond plate insert, Super Swampers for trails & Desert Trac paddles for sand
Toyotadude is offline   Reply With Quote
Old 02-09-2010, 07:44 AM   #8
View bigguy3044's Photo Gallery(0)
Default
Note sure if this will help guys but I have much the same set up as you are talking about but without the 6 degree key and a muzzy exhaust but I do have the intakes from Vjohn. I am sea level and am jetted with 42 pilots, shimmed needles and am running a jet size of 240 in both carbs. It is equivalent to the 3/32 drilled jet. starts and runs great.
bigguy3044 is offline   Reply With Quote
Old 02-09-2010, 04:35 PM   #9
Default
thanks guys it will be next weekend before i can do anything to (I work for Toyota,gas pedals are my current life) so i will post the outcome
Old 02-09-2010, 05:21 PM   #10
Feedback Score: 10 reviews
RobCatV's Avatar
View RobCatV's Photo Gallery(0)
Default
Changing jets is easy.
How To: Changing Main Jets
FST800, stg 3 cams, 38mm carbs, BKP intakes, VFJ Stg 3 spidermod, LTE's, AMR coils, Dynatek CDI, Fluidyne radiator, SPAL fan, Venforcer radiator guard & stator cover & dash, Mike Walker oil cooler, billet catch can & gas cap & dipstick, pc'd frame, Jettrim seat cover, TribalCarbonfiber hood, PIAA lights, Elka Elites, Penland tie rods, WER stabilizer, Lonestar hubs, Durablue axle, +4.5" swingarm & German gears, QuadBoss armor, Warn winch & Amsteel cable, Razr2's on Hiper beadlocks, PRM Rack & SideBars, Armadillo bumper, FST clutch cover, Fasst bars, Autometer gauges, Cycra ProBend handguards on BRP mounts, ODI Rogue grips, ASV shorty levers, TerryCable throttle, Hermann Racing +1 stem, Rox risers, Hurst shorty shifter, IMS tank, Cobra tank guard, Garmin E-trex GPS & RAM mount, Maddog mirror, chrome LED taillight
RobCatV is offline   Reply With Quote
Tags
jets, mod, tune, upp
jetting for 700v force
You may not post new threads
You may not post replies
Jetting and a few v questions? JDogg Kawasaki KFX700 V-Force 2 12-03-2009 05:28 PM
More jetting questions Biffman5000 Kawasaki KFX700 V-Force 3 07-05-2007 08:45 PM
More Jetting questions.... BigRed Kawasaki KFX700 V-Force 6 06-25-2007 09:22 PM
More jetting questions.... ZKriegel Kawasaki KFX700 V-Force 23 04-10-2007 06:49 AM
Questions on jetting quadparts Kawasaki KFX700 V-Force 1 09-24-2004 05:56 AM
