02-09-2010, 05:00 PM
#11
Feedback Score: 1 reviews
"As For Me And My House We Shall Serve The Lord"
2007 KFX 700 V Force------"DIY MODS"-----Pink Spring---Yoshimura Duals---12 Hole Mod---Twin Air Power Kit---1 Shim & Cut Springs---Polished Slides--- 3.0 turns out---#40 Pilots---182F/185R---Spark Plug Boot Mod-----------"OTHER STUFF"---Odi grips---Full Under Armor---Billet Stator Cover---HID Lights---Trail Tech Vapor---Pro Armor Front Bumper---Rear 6 Pack Rack---Nerfs--22x11x10 Haulers 10 Paddle---22x11x10 Edges 9 Paddle---Quick Release Lighted Whip---IMS 4.6 Gas Tank
2005 Honda Rancher 350ES
The Avatar picture is my custom home for sale in Yucca Valley, So. Calif.
02-09-2010, 05:56 PM
#12
Feedback Score: 10 reviews
my tab where the air box cover meets my rear plastic is hanging out in the picture.
That a little HP secret I learned awhile back.
2004 KFX715
'The Blue Bullet'
2004 KFX700/Stock
2004 KFX700/Bolt Ons
02-09-2010, 06:30 PM
#13
Feedback Score: 2 reviews
2009 CAN AM RENEGADE X 800R
2006 SEA DOO GTX LIMITED
2006 POLARIS PHOENIX 200
2005 KAWI KFX 700 W/ MODS
2004 SEA DOO RXP W/ MODS
2002 POLARIS SCRAMBLER 500 4X4 W/MODS
= too much crap to wrench on ! ! !
02-09-2010, 08:19 PM
#14
Feedback Score: 9 reviews
You will find that the best sand performance is from using a tire that is taller than your 22" A/T tires. Most go for a 24x11-10 8 to 10 paddle tire for the sand.
'04 KFX730
Fundy 11.1:1 Pistons, FST Stage 2 cams, Ceramic-coated Muzzy Exhaust, +4 Swingarm Extension, 12-Hole Mod, UPP Cross-over Intakes, 3/32" drilled main jets, #42 pilots, 3 shims/needle, Elka Front Shocks, Revalved Rear Shock w/ Road Magnet Spring, CCP Steering Stabilizer, TrailTech X-bars/Clamp, Pro-Armor nerfs--bumper--grab bar, 25x12-10 10-paddle Extremes on 10x11 wheels, VFJ #6 Clutch Spring w/ 2 shims... BOSS NOSS 30-shot
'04 KFX700
DMC Afterburner Quiet4 Dual Exhaust, 12-hole Airbox Mod, Crossover Intakes, #45 drilled main jets, shimmed needles, 6* Timing Advance Key, Spark Plug Boot Mod, Road Magnet Suspension Springs, 24x11-10 8-paddle Skat-Trak Extremes on 10x10 wheels, EPI Pink Spring
02-09-2010, 11:03 PM
#15
I got my new paddles home, supposed to fit my KFXs, and the bolt pattern is too small by a long ways. The tire is a 21-12-8, much smaller diameter and wider rim than the ones on the A/Ts.
Not sure what I'm gonna do, I really wanted paddles on both KFXs this weekend.
I work with the guy i got them from, so getting my money back shouldn't be a problem; he may have just grabbed the wrong set....
2004 KFX 700, Quadzilla (green), Muzzy pipe, Twin-Air filter, 42.5 pilots, 155f, 160r jets, screws out 2.5 turns, 6* key, White bros CDI, 2 washers on needles, polished slides. Carbon fiber snorkel/scoop.
2004 KFX 700, Pumpkin (orange), FMF pipe, repacked FMF Titanium 4 muffler with "quiet" insert, K&N/Outerwears filter, 40 pilots, 145 f, 150 r jets, screws out 1.75 turns, washer on needles, polished slides.
Both airboxes modified by cutting out the "wall".
02-10-2010, 01:23 PM
#16
Feedback Score: 6 reviews
What are you planning on using these paddles for? A 21-12-8 paddle on a KFX?
I don't care what size the jockey of the quad is these KFX's need AT LEAST 24" paddles.
The Speed Force KFX800™
FST800, Stage 3's, Muzzy Pro, VFJ Stage 3, 36's, EPI Maroon, MSA Wheels, Duro Scorchers, Powdercoated Everything. Proud winner of August '09 KOTM and lucky winner of December '09 KOTM.
02-10-2010, 05:20 PM
#17
whats a good place to get the 24's for the v cheap,
Can you run stock fronts with ok results? im going to silver lake michigan in the spring.
02-10-2010, 05:37 PM
#18
I have 24's I am selling cheap. One of them leaked at the bead. P.M me if interested.
They are 24x11x10 edges
02-10-2010, 05:38 PM
#19
If you are able to hold off a little longer, I may have a set of 24" 8-paddle Skat Trak Extemes for sale. It all depends if I am forced to sell my orange V. I will know in 3-4 weeks, I would guess. PM me if you would like me to let you know once I figure out what is going on. There usually aren't too many used sets for sale.
They are the tires on the rear of my green V in my sig pic.
'04 KFX730
'04 KFX700
02-11-2010, 09:48 AM
#20
Dave at Fullerton Sand Tires says teh same thing the 24" are the Ticket! now to go either Edges or Haulers for the wifes Quad, he like to put them on 10" wide rims, I hate 10" rims, Pro: Great Floatation, Con: Sand Can Get into The Bead, have to silcone the edges.
I run 9" on the DS and the LT500, Like to see how a set of Comp Grooved SS would work on the V700.
If It Has Boobs or Wheels Its Bound To Cause Trouble!
http://s192.photobucket.com/home/erbe03/index
88 LT500 DR Q Sand Shredder
02 DS650-now 730 Sand Tank
87 Mojave
CWR 36 carb, Big Gun Evo Exhaust, Works Front Shocks, TCS Modded Raptor Rear Shock
KFX700 2006 <-Holly Cat Excretions Bat Man!!! HMF Duals, VFJ-2 Clutch Mod, 12 hole Air Lid, 6" Extendtion, Fire Ball Racing Plus 2" A-Arms w/ Long Travel Elka's Front & Rear Shocks, 6-deg Key Way.
| Thread Tools |
| Display Modes |
Linear Mode
You may not post new threads
You may not post replies
» Site Navigation |
