Carb issues or engine?
This is a discussion on Carb issues or engine? within the Kawasaki KFX700 V-Force forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; Quote: Originally Posted by the_depraved_one Say.... could someone tell me what is acceptable for compression then if the book is not? yes it's 43-75 on ...
Old 03-12-2010, 08:19 PM   #11
Feedback Score: 8 reviews
hndlbarmonkey's Avatar
View hndlbarmonkey's Photo Gallery(0)
Default
yes it's 43-75 on a stock motor
hndlbarmonkey is offline   Reply With Quote
Old 03-12-2010, 09:35 PM   #12
Feedback Score: 1 reviews
Kenny4's Avatar
View Kenny4's Photo Gallery(9)
Default
Quote: Originally Posted by Knightrider View Post
I always check compression with the motor warm and with the motor running. My V makes the same sound when its cold but quiets down after its warm. Hasnt blown up yet
Just curious---How do you do a compression test with the motor running
Kenny
"As For Me And My House We Shall Serve The Lord"
2007 KFX 700 V Force------"DIY MODS"-----Pink Spring---Yoshimura Duals---12 Hole Mod---Twin Air Power Kit---1 Shim & Cut Springs---Polished Slides--- 3.0 turns out---#40 Pilots---182F/185R---Spark Plug Boot Mod-----------"OTHER STUFF"---Odi grips---Full Under Armor---Billet Stator Cover---HID Lights---Trail Tech Vapor---Pro Armor Front Bumper---Rear 6 Pack Rack---Nerfs--22x11x10 Haulers 10 Paddle---22x11x10 Edges 9 Paddle---Quick Release Lighted Whip---IMS 4.6 Gas Tank
2005 Honda Rancher 350ES
The Avatar picture is my custom home for sale in Yucca Valley, So. Calif.
Kenny4 is offline   Reply With Quote
Old 03-13-2010, 02:24 AM   #13
Knightrider's Avatar
View Knightrider's Photo Gallery(0) Send a message via Yahoo to Knightrider
Default
I run it on one cylinder, put the tester on the other cylinder. It will run. Otherwise the readings arent very accurate. This is how I do it on my pro street car, I do it on my snowmobiles too. 43-75 just seems low. I know on a two stroke anything under 100 psi is bad.
Knightrider is offline   Reply With Quote
Old 03-13-2010, 05:12 AM   #14
Feedback Score: 22 reviews
g-rider's Avatar
View g-rider's Photo Gallery(0)
Default
Yep.... what he said
g-rider is offline   Reply With Quote
Old 03-13-2010, 08:47 AM   #15
Feedback Score: 2 reviews
View NovaKaw650's Photo Gallery(0)
Default
Thought spec was between 43 and 75psi because of the compression relief in it?
also I guess to be more specific the sound I hear is coming from the front somewhere
Correct. If it starts, the compression should be okay.
But I'm with The Speed Force; it ran good, ran out of oil, runs crappy. Look at everything that lack of oil could have affected.
You didn't do anything else other than put in more oil; i.e. worked on something else while it was in the shop for the oil refill?
2002 665 FPS Prairie
FPS Trail kit - 12:1 comp due to 1mm shaved off the heads
Mild porting
Crossover intakes
Modded airbox
Full Muzzy
Dalton springs and weights
Other stuff
NovaKaw650 is offline   Reply With Quote
Old 03-13-2010, 01:03 PM   #16
Default
OH ok. I didnt know there was a compression relief. How stupid am I? So the compression relief must come on automatically?
Old 03-13-2010, 01:38 PM   #17
GarDog's Avatar
View GarDog's Photo Gallery(0)
Default
Yes it is a spring loaded, centrifugally deactivated, pin on each cam...
which holds the exhaust valve slightly open @ low RPM...
then moves down/into the cams, once the cams/engine gets to a preset RPM...
Green 04 KFX700...HMF Duals... Mechanical Oil Pressure Gauge...Spark Boot Mod...TwinAirPowerFlow...(15) 1" holes + (5)1/2" holes in lid... 3/32 drilled jets...springs cut...one #4 washer on needles...slides polished...more to come...
GarDog is offline   Reply With Quote
You may not post new threads
You may not post replies
carb issues. ruthlessxbeastx Club Kawie 0 08-29-2009 05:32 PM
carb issues coleminer Kawasaki KFX700 V-Force 18 08-03-2009 03:30 AM
Carb issues??? primvnut Kawasaki KFX700 V-Force 43 07-07-2009 06:08 PM
CArb issues? stumper Kawasaki Brute Force/Prairie/Bayou 7 08-26-2008 06:54 PM
Big Carb Issues bb 650 Kawasaki KFX700 V-Force 16 04-06-2007 12:36 PM
