Old 03-15-2010, 12:04 PM   #1
Delmustator's Avatar
View Delmustator's Photo Gallery(0)
Default Won't idle without choke on
Hey Guys! I'm back!
It's been almost 5 years since my last visit!
I went and pulled my V-Force from storage. I think it had about 10 hours of run time before I had to store it. Only to find that it will not run properly without the choke on. Among other things, I replaced the battery, added new fuel, oil, and coolant. She cranks up immediately but I cannot open the choke without it stalling.
Surely a fuel starvation issue. I put some Sea Foam in the fuel and ran it for about 30 minutes but that did not clear the issue. The carbs and filters (including fuel) are factory clean.
Any suggestions short of pulling the carbs and doing a thorough cleaning?
-Del
04 V-Force - Team Green
06 M109R - Team Burple
http://www.ButtryNET.com
Delmustator is offline   Reply With Quote
Old 03-15-2010, 12:20 PM   #2
Feedback Score: 15 reviews
RobCatV's Avatar
View RobCatV's Photo Gallery(0)
Default
Did you drain the gas from the carbs before storage? If not, you're probably gonna have to pull them and clean them. I worked on an older Polaris that had been stored for several years - looked like shellac in the carbs.
RobCatV is offline   Reply With Quote
Old 03-15-2010, 12:26 PM   #3
View Black-V's Photo Gallery(0)
Default
Sounds like dirty jets. Pull the float bowls and check the main jets. Probably filled with gunk.
Black-V is offline   Reply With Quote
Old 03-15-2010, 12:26 PM   #4
Default
Yeah, I didn't drain them. Just drained the tank, put a little fuel stabilizer in and stored. I really didn't expect it to be in storage so long.
I did drain them before cranking it back up. The fuel was yellower than normal for sure and didn't smell much like gasoline. I was hoping the Sea Foam would break any shellac'in down.
I'm a good mechanic but not alot of carb experience. Too many tiny parts to get misplaced.
-Del
Old 03-15-2010, 12:30 PM   #5
RobCatV's Avatar
Default
I agree. Pull the bowls and main and pilot jets, soak them in carb cleaner, then blow out with compressed air. Hold up to a light and see if you can see through them.
Old 03-15-2010, 01:44 PM   #6
Default
Thanks guys,,,, I'll give that a shot this weekend.
-Del
Old 03-15-2010, 01:57 PM   #7
View bumblebee's Photo Gallery(0)
Default
u might try putting staight race fuel in tank drain carbs until ur sure race gas in coming out let sit for 24 hr drain again and let sit another 24. did this on my shelby that had almost full tank of gas when stored,,, less than 1/4 when it came out of storage. first round came out discolored yello 2nd round came looking like fresh fuel, filled tank with ethel gas and fired her up no problem and a whole easier than pulling tank out of car
bumblebee is offline   Reply With Quote
Old 03-15-2010, 03:49 PM   #8
Default
I think I'm going to have to de-varnish the jets. Unfortunately I had a KFX50 and a tiller in storage with it also and they are suffering from the same problem.
Man that gas stinks when it gets varnished too...
-Del
Old 03-15-2010, 07:29 PM   #9
Feedback Score: 23 reviews
T_Dilley's Avatar
View T_Dilley's Photo Gallery(3)
Default
Good to dump in someones yard that pissed you off though..
2004 KFX715
'The Blue Bullet'
2004 KFX700/Stock
2004 KFX700/Bolt Ons
T_Dilley is offline   Reply With Quote
Old 03-16-2010, 07:37 AM   #10
View LowEtsRock's Photo Gallery(0)
Default
I have seen this at the Dealer. Yamaha Carburetor Cleaner Dip At Parker Yamaha.com I know it's Yamaha, but it works really well. You can run it in the fuel line and let it sit over night and drain, or if you have it off fill up as well as soak over night in solution. cleans it really well.
LowEtsRock is offline   Reply With Quote
06 kawasaki mule want idle
2005 kawasaki 700 quad choke position
2005 kawasaki mule wont idel
atv won't run without choke
atv wont idle
atv wont idle without choke
atv wont run without choke
kawasaki mule won't idle
kawasaki mule won't stay running
kfx 700 wont idle
kfx700 wont run without choke
quad wont idle without choke
why won't my quad idle
You may not post new threads
You may not post replies
choke? mAdHaTTer3392 Kawasaki KFX450/KFX400 0 11-22-2009 06:38 PM
Choke on 36's KYVFORCE Kawasaki KFX700 V-Force 5 01-18-2008 07:42 PM
BF 750 Choke Problem MudMut Kawasaki Brute Force/Prairie/Bayou 2 04-09-2007 05:02 AM
Choke Problem?? rotty Kawasaki KFX700 V-Force 3 03-09-2005 03:12 PM
Choke? MoJaVeReEpEr13 Kawasaki Mojave/Lakota 1 06-30-2003 01:56 PM
