CCP Steering Stabilizer Reviews - Kawasaki ATV Forum
post #1 of 76 Old 07-26-2010, 03:45 PM Thread Starter
Feedback Score: 24 reviews
twyztid's Avatar
Thought it would be best to start a new thread for reviews of the CCP steering stabilizers.
Here is a copy/paste of my review:
I am DEFINITELY pleased with the stabilizer. I rode around in the dunes a lot more yesterday than I normally do (usually spend more time drag racing) and my wrists/forearms aren't even sore today. Usually they are a bit stiff the day after riding all day. I had the stabilizer set to the #3 setting (has 1-8 with #1 being the stiffest) and it gave a lot of control but didn't seem to be too stiff for the type of riding I was doing. If I was doing a lot more tighter turns, I would have probably put it at #4 or #5 setting because #3 might have made the steering feel too heavy. I didn't have to have nowhere near the "death-grip" that I usually have on the handlebar grips with this stabilizer (even compared to a stick stabilizer). I ran across some pretty deep ruts in the sand that were made by trucks at both high and low speeds and I could definitely tell it was better than my old stick-type. I could still feel the ruts but it didn't have that abrupt jerking feeling that I experienced before. Also, the higher my speed, the less I felt the ruts. I like it enough that I am buying a 2nd one for my other V and will be selling my stick stabilizer even though I don't really ride that one myself that much. I would recommend this stabilizer to anyone that doesn't want to spend $500 on a Precision. The Precision is probably better but I can't imagine it is worth 2.5 times the price.
'04 KFX800
DSC 12:1 Pistons, DSC Stage 2 cams, Ported Heads, 36mm carbs, Muzzy Super Pro, Dual MTX-L A/F Gauges, VFJ Stage 3 Spidermod Clutch & Adj. Weights, +8 Swing Arm, Elka Shocks, Acewell 3200 Tach, CCP Steering Stabilizer, Trail Tech X-bars/Clamp, IMS Kick-up Pegs, IMS Heel Guards, 24" 14-paddle Staggered SLS Extreme paddles, BOSS NOSS 40-shot...
'04 KFX700
FST700 w/ Stage 2 cams, Muzzy Super Pro, 12-hole Airbox Mod, UPP Crossover Intakes, 6* Timing Advance Key, Acewell 3200 Tach, CCP Steering Stabilizer, Trail Tech X-bars/Clamp, DG Heel Guards, IMS Kick-up Pegs, Honda 450R / Elka Rear Shocks, +4 Swing Arm Extension, 24" 9-paddle Skat-Trak Extremes
'04 KFX730
'05 BF730 SRA
twyztid is offline
post #2 of 76 Old 07-26-2010, 07:32 PM
Feedback Score: 16 reviews
Dr. Love's Avatar
Mine sucks.
Dr. Love is offline
post #3 of 76 Old 07-26-2010, 07:42 PM
Feedback Score: 10 reviews
primvnut's Avatar
suits you fine then because you suck too
2004 v force,fst 715 w/stage 3 cams,upp intakes,muzzy super pro,+4 swinger,flexx bars,elka elites +2 asr front suspension,custom +4 prm swingarm skid,hipers,+4 durablue axle,prm sidebars.
primvnut is offline
post #4 of 76 Old 07-26-2010, 08:07 PM Thread Starter
twyztid's Avatar
Come on now. You haven't even installed it yet.
I was hoping to get some REAL reviews in this thread for others down the road that are looking for a stabilizer.
'04 KFX800
'04 KFX700
'04 KFX730
'05 BF730 SRA
twyztid is offline
post #5 of 76 Old 07-26-2010, 10:41 PM
Andycyprus's Avatar
Don't worrt Kev I'll be sure to put a review as soon as my stabilizer gets here, I just hope I'm not too old to ride though ..............................
KFX 730: Green with Graphics & Trimmed Plastics, Stage 3 cams, Ported heads, Muzzy Super Pro, 17 Hole Modded Airbox, Drilled Jets, 42 Pilots, Modded 02 Stacks, Twin Air Filter, MS Mod, 6* Key, NGK CR8EIX Iridium Plugs, Mobil 1 Synthetic, Evans NPG+ Coolant & No Thermostat, VFJ Stage 3 Clutch, Dalton Cover, VFJ No.2 Spring, Hiper wheels, Razr 2's, Elka's Front & Rear, CCP Steering Stabilizer, ASR +2" Extended A-Arms, G-Force Ext Rear Hubs, Vens 4" Ext Swingarm, Trail Tech X-Bars, Garmin 60csx GPS, Honda EX Thumb Throttle, ASR SS Front Brake Lines, ODI Grips, Extended Tie-Rods, Pro Armor Protected.
STILL TO COME: Just More Power
PARTS & TECHNICAL HELP THANKS TO WWW.SHOP.ATVTRICKSTUFF.COM & WWW.VFORCEJOHN.COM
Andycyprus is offline
post #6 of 76 Old 07-26-2010, 11:22 PM
Thanks Kev, I appreceate this. I'm pretty sure I'll get some for mine after the discussions I followed. Contacted CNC and they will ship to me when I get to Oregon. Too bad I didn't have one last week at St A's. Smee
SMEE is offline
post #7 of 76 Old 07-27-2010, 07:34 AM
japaroo's Avatar
Got mine yesterday and had it installed within 45 minutes of leaving the post office (It took 30 minutes to get home). Will be going out for a decent ride this weekend although initially I will complain that it's too shiny.
But I will say I'm amazed at the amount of resistance It gave on hardest setting....when would anyone EVER need the much stabilizing
2004 KFX-700--Dual Yoshimura system--UNI air filter--195F/195R--shimmed needles--crossover intake--42 pilots--polished slides--12 hole mod--shorty shifter--TAG handlebars--cracked and cut plastics--DG alloy bumper--AC racing wide grab bar--AC racing Nerf bars--Road Magnet springs--Kenda claw rears--Maxxis Razr 2 fronts--ITP rims--camera mount
japaroo is offline
post #8 of 76 Old 07-27-2010, 07:50 AM
Feedback Score: 8 reviews
Psi-820's Avatar
boys run them soft when ur a man u run them on the tuffest setting being nor ide say you have urs on the weakest settingcome sor and ude have to adjust it
Psi-820 is offline
post #9 of 76 Old 07-27-2010, 12:43 PM
GeneralV's Avatar
I installed mine in about 10 minutes. When I first took it around the track I was hitting everything I could. (ruts, off camber jumps, concrete, ) We started racing and running into each other on purpose. I cant really tell any comparisons between this and another brand or type, but just know that the money spent on this vs. how much difference it makes is really good. Everybody around here wants one now.
2012 General Lee BKP 800... Dixie Horn
Stamp #1
Stamp #2
Stamp #3 - pending
Stamp #4 - waiting on quad to sell
μολὼν λαβέ
GeneralV is offline
post #10 of 76 Old 07-27-2010, 03:10 PM
Feedback Score: 4 reviews
Captjacksparrow's Avatar
Does anyone have pics of this and where can we get one? Thanks Dan
http://www.extrememachines.ca/
2014 RZR 1000.
04-V, (Green) stock
Can am Renegade
R1 Raptor-SOLD
04-V, (Green) 800...stock SOLD
04 900 stroker V, SOLD
Captjacksparrow is offline
atv steering stabilizer
atv steering stabilizer review
best atv steering stabilizer
ccp stabilizer
ccp stabilizer rebuild
ccp stabilizer reviews
ccp steering stabilizer
ccp steering stabilizer damper
ccp steering stabilizer ltr450
ccp steering stabilizer review
ccp steering stabilizer reviews
kfx 450r steering stabilizer
precision steering stabilizer review
steering stabilizer ballpeen Wanted 0 05-06-2009 03:08 PM
steering stabilizer ballpeen Wanted 0 04-14-2009 06:39 PM
steering stabilizer kfxmatt Kawasaki KFX700 V-Force 5 12-24-2008 11:12 PM
Pic of steering stabilizer bonestockklx Kawasaki KFX700 V-Force 3 12-29-2006 04:10 AM
Looking for a STEERING STABILIZER sandring For Sale 0 11-28-2004 03:31 PM
