parting out mojave
ive got everything i need off my parts mojave so im giving you guys a chance to get anything you need before it goes to the scrap yard.
PARTS I DO NOT HAVE: chain, front or rear plastics, rear brake caliper, ignition switch or key, rear shock, clutch lever/perch. maybe a few other things.
the only thing wrong with the motor is the output shaft i think is broken. the motor runs fine but wont go anywhere. regardless its something in the tranny.
a few examples of what i do have: front a arms upper and lower, front brakes/calipers, front shocks, carb, any engine component, cdi box, stator, coil, hubs, swingarm, frame, throttle cable, brake lines...the list goes on.
again the motor ran fine, just something in the tranny kept it from going anywhere, so im guessing the output shaft. let me know if you guys need/ want anything and ill throw you a price. thanks
