Mojave Carb Settings - Kawasaki ATV Forum
Kawasaki Mojave/Lakota The revolutionary long-lasting Mojave, and it's close cousin
post #1 of 2 Old 12-14-2011, 10:06 AM Thread Starter
Ok so the problem I had with my mojave was it would crank up & idle fine, but when i pushed the gas it would cut it off. It was weird & I never experienced it before. Push gas & it bogs/stalls/cuts off. Was told its the carb. So I pulled the carb off, cleaned it multiple times. Put it back on, now it won't even crank.
Also put in a new spark plug.
So before it would crank & idle perfectly, now after cleaning the carb it wont even crank.
So I am guessing that when I removed all of the screws inside the carb that I didn't set them correctly.
Any help would be greatly appreciated, all I need to know is what screws are what (air/fuel mixtures, idle, air flow, etc) & how many turns they need to be correct
Infamous4x4 is offline
post #2 of 2 Old 12-14-2011, 11:06 AM
will2002ksf250's Avatar
There are 2 plugs that go over the tube that go to the air box. They might be unplugged. It could also be the float level. float level should be 17.0mm give or take 1 or 2mm. Also turn the fuel on to the reserve. Gas tank could be low.
will2002ksf250 is offline
Go Back   Kawasaki ATV Forum > Kawasaki ATV Performance / Maintenance / Technical > Kawasaki Mojave/Lakota
2000 kawasaki 250 mojave stalls off idle
2007 kawasaki 450f carburetor settings
float level adjustment on mojave
how many times do i turn the float screw on my kawasaki mojave atv carburator
kawasaki 450f carburator adjustment/settings
kawasaki mojave 110 carb
kawasaki mojave 250 carburetor
kawasaki mojave 250 hesitates off idle
kawasaki mojave carb adjustment
kawasaki mojave carb settings
mojave 110 carburetor
mojave float adjustment
what is the stock settings for a 250 mojave on the carburetor
87 Mojave 250 what are stock carb settings? alexbekjr Kawasaki Mojave/Lakota 6 05-16-2014 10:42 AM
Stock Carb Jet Settings rmkelp Kawasaki KFX700 V-Force 14 10-29-2009 12:56 PM
stock carb settings sal Kawasaki KFX700 V-Force 2 11-21-2008 12:12 PM
carb settings skyeryder Kawasaki Brute Force/Prairie/Bayou 9 04-07-2008 05:33 PM
V carb settings for new pipes easttxboy Kawasaki KFX700 V-Force 2 06-21-2007 06:09 PM
