Some electrical Questions. - Kawasaki ATV Forum
Kawasaki Mojave/Lakota The revolutionary long-lasting Mojave, and it's close cousin
post #1 of 17 Old 03-15-2012, 09:46 AM Thread Starter
I have some questions regarding my '92 mojave's wiring harness.
One of the previous owners modified the wiring. The voltage regulator is not hooked up, and I cannot find a spot on the harness where it plugs in. Which color wires and where is this supposed to hook in at? Will the bike operate correctly without it in the loop - aside from the lights, which I'm guessing would blow from the high voltage.
On the harness, left side, middle of quad - there is a red and black w/yellow stripe wire sitting unused. The tail light also is disconnected, but there is no wire long enough, unconnected, running to the tail light. Is this the correct color combo for that light?
It is currently non, running, so I cannot test with a volt meter. I'm trying to get in as much work as I can while the timing chain is on its way to me.
I've tried looking over the repair manual and couldn't figure it out.
going off this image - which connector goes to the volt reg?
catalyst is offline
post #2 of 17 Old 03-16-2012, 11:28 AM Thread Starter
anyone? I just need a picture and wire colors of what the voltage regulator plugs in to on the harness.
catalyst is offline
post #3 of 17 Old 03-16-2012, 01:13 PM
will2002ksf250's Avatar
let me know if this helps.
will2002ksf250 is offline
post #4 of 17 Old 03-16-2012, 09:00 PM Thread Starter
Where is the voltage regulator on the drawing? Am i missing it?
U did solve my tail light question tho.
catalyst is offline
post #5 of 17 Old 03-17-2012, 06:44 PM
I think the voltage regulator is part of the cdi. someone let me know if i am wrong.
post #6 of 17 Old 03-19-2012, 06:56 AM
Feedback Score: 1 reviews
Well yes and no. The voltag regulator is separate from the CDI but they are mounted together on the same plate/bracket.
Timberwolf 8199 is offline
post #7 of 17 Old 03-19-2012, 07:36 AM Thread Starter
Can someone just take a photo of your voltage reg - it does connect up at the front on the right side (sitting down in the seat)
I guess I should get a clarifying question - this is a voltage regulator, right? Its the thing with the heatsink.
I have no wires or anything with the other end of that connector on it. If I do, I didn't see it. There's nothing on the harness anyhow. The reverse light is also not hooked up nor are there any wires for that, as well - so I'm not sure where that'd connect in, either.
The only "open" wires I know of are a red, and a black with yellow stripe, and I think they are for the rear tail light, but I could be wrong.
So the voltage reg being disconnected - Would this impact the bike being able to start / run, or just the lights, for which I've pulled both bulbs so as to not pop them.
catalyst is offline
post #8 of 17 Old 03-19-2012, 11:08 AM
I know that the lights did only work on high, but they did work. We couldnt figure low out or figure the voltage regualtor out, so we left it alone. Seemed to run fine.
KawasakiLuvr is offline
post #9 of 17 Old 03-19-2012, 11:29 AM
Kawasaki KSF 250 MOJAVE 87-04.pdf
download this. It will help you! Its a big file.
post #10 of 17 Old 03-19-2012, 11:37 AM Thread Starter
I have the PDF of the manual, and the diagrams from that manual were posted in this thread by you. I'm still at a loss because I don't know where on that diagram the voltage reg is.
If someone could post some photos or simply tell me what color wires your voltage reg plugs in to, it would help me out a bunch.
from what i've been reading, not having the voltage reg in the circuit will pop the bulbs for the lights at high rpm, as the alternator generates more voltage.
catalyst is offline
Go Back   Kawasaki ATV Forum > Kawasaki ATV Performance / Maintenance / Technical > Kawasaki Mojave/Lakota
2002 lakota brake light wire
color coding of electrical wiring for kawasaki motorcycles
how to hook up wires on a voltage regulator for atv
kawasaki mojave 250 blowing out tail lights
kawasaki mojave 250 wiring diagram
kawasaki mojave electrical diagram
kawasaki mojave electrical problems
kawasaki mojave tail light wire colors
kawasaki motorcycle wiring color code
kfx 700 brake light wiring
mohave break light diagram
rear brake light kawasaki mohave wiring diagram
wiring diagram 92 kawasaki mohavi
electrical help please! bowmaster30 Everything Else 4 05-15-2012 04:56 PM
Electrical Problems = Questions DanInMontana Kawasaki Brute Force/Prairie/Bayou 9 11-01-2010 06:25 PM
39 mm carbs questions/ motor build questions. jksimpson Kawasaki Brute Force/Prairie/Bayou 15 07-19-2010 08:15 PM
WTF? Electrical DoubleTapXX Kawasaki KFX700 V-Force 9 04-17-2010 10:54 PM
electrical help ?????? FLVFORCE Kawasaki KFX700 V-Force 2 05-17-2009 07:17 PM
