kawasaki lakota engine rebuild - Kawasaki ATV Forum
Kawasaki Mojave/Lakota The revolutionary long-lasting Mojave, and it's close cousin
post #1 of 8 Old 09-16-2012, 01:52 PM Thread Starter
hey wassup everyone got some more questions thanks for answering all my other questions. i wanted to know if the kawasaki bayou 300 is the same as the kawasaki lakota. if so do you think i could use the piston and the carb from the bayou for my lakota and will it run healthy
renecitobt is offline
post #2 of 8 Old 09-16-2012, 02:09 PM
Feedback Score: 1 reviews
Mojaveracer2001's Avatar
the mojave and lakota engines are alike, not the lakota and bayou. If you get the cvk 34 from the mojave it might run good...But if you already have a carb from the lakota I suggest using the lakota carb. For a piston, you can buy a piston for the lakota...a bayou piston wont work.
klx110's
1 155 reverse intake
1 143 forward intake w/reverse manifold
Mojaveracer2001 is offline
post #3 of 8 Old 09-16-2012, 08:53 PM
Quote:
Um, are you sure about this? The Lakota engine is the Bayou engine with the output shaft changed and the cam changed. How can the Mojave and Lakota engines be the same or similar when one is liquid cooled and the other air cooled? They aren't even the same CC's.
I also just went to powersportspro.com and checked part numbers. The pistons are the same part number. The carbs however are not the same p/n. I don't know if a bayou carb would work or not. I'm sure you could make it work since they are the same engine basically but it may take some ingenuity.
Any questions holler at me. I've pretty much had most of my top end torn down and my lakota was so beat up I've done a lot of research on them.
tcanthonyii is offline
post #4 of 8 Old 09-17-2012, 09:27 PM
Whoa my bad i got that completely mixed up. Bayou and lakota engines are alike mojave and lakota chassis are almost identical...sorry about that
klx110's
post #5 of 8 Old 09-17-2012, 09:36 PM
I was hoping that's what you meant. I miss talk all the damn time.
post #6 of 8 Old 09-18-2012, 09:05 PM
Haha, you can use a bayou carb... But a stock lakota carb will be much easier to tune...technically you can put whatever carb you want on the bike. A 450r carb will be alot harder to tune and it would take so much modification its not worth it, but technically it can be done. Go with a lakota carb definitely
klx110's
post #7 of 8 Old 09-21-2012, 05:24 PM Thread Starter
yea i finally found my carb from the lakota.i just cleaned it today real good wit some carb cleaner and im lookin to buy a racing carb rebuild kit. i should be gettin my piston any day now just ordered it a few days ago.now ima sand blast the top end so it been cleaned on the outside and cleaned on the inside so the air and the exhaust can flow nice
post #8 of 8 Old 09-22-2012, 06:08 AM
1nasty23's Avatar
Helpful tip that worked on the lt80 carb I just did. Boil the carb for 45 minutes to an hour. to get in all the tight places. Then just shoot it with carb cleaner when you pull it apart for the rebuild. Worked great on the little lt80 carb I just rebuilt. Don't see why it wouldn't work for you too. It'll surprise you the amount of dirt that ends up in the bottom of the pot.
01 mojave750- 05 gsxr750 power
89 lt250r-complete restoration
88,91,95 Lt80's-2 sets of front brake cables, 1 rebuild
04 kfx700(my ride)-hmf duals,rejet........stolen
06 250ex(kids ride)-nerf bars.......spun bearing, gave away
1nasty23 is offline
Go Back   Kawasaki ATV Forum > Kawasaki ATV Performance / Maintenance / Technical > Kawasaki Mojave/Lakota
how to rebild a kawasaki 300 lakoda
is bayou and lakota same engine
kawasaki lakota
kawasaki lakota 300 engine rebuild kit
kawasaki lakota 300 timing
kawasaki lakota rebuild
kawasaki lakota rebuild kit
kawasaki lakota sport engine rebuild
lacota kawasaki timin the engine
top end rebuild kit for lakota 300
top end rebuild on kawasaki lakota
would a kawasaki bayou and lakota take the same carburetor
2001 lakota sport engine rebuild questions renecitobt Kawasaki Mojave/Lakota 10 06-02-2014 06:07 PM
Engine Rebuild? Wbcj83 Kawasaki Tecate 5 05-16-2012 11:22 PM
Lakota running VERY rich after rebuild llstow Kawasaki Mojave/Lakota 4 09-07-2011 07:25 AM
01 lakota engine rebuild bikrboyzx10r Kawasaki Mojave/Lakota 1 04-07-2011 12:09 PM
05 BF 750 Engine Rebuild. Who makes a good rebuild kit? nsbsteveo Kawasaki Brute Force/Prairie/Bayou 14 10-20-2010 05:44 PM
