I have an 01 lokota that I traded for 3 years ago and I cant get this hesitation out of the throttle. It idles fine and starts easy but if you throwthe throttle to it fast it luggs and back fires unless you fether the throttle fast then it will rev up. I ave taken the carb off 3 or 4 times and cleaned it. This last time I put a new jet kit in it and i still have the same problem. I installed a new battery and checked to make sure that it was charging and I have 13.9 volts when running so I am assuming that the voltage regulator is good. Any help would be great.
You may need to adjust your needle in the carb. What is your elevation? You can find it through NOAA. just enter your city. Also look at the plug, what color is it?
my diff locking cable is damage, how i can install a new one.
maybe can you tell a link to see how?
or a virtual manual?
Related Threads
Kawasaki ATV Forum
971.2K posts
52.4K members
Since 2002
