How do you adjust mojave valves. - Kawasaki ATV Forum
Kawasaki Mojave/Lakota The revolutionary long-lasting Mojave, and it's close cousin
post #1 of 7 Old 07-26-2010, 10:05 PM Thread Starter
I need someone to help tell me how to adjust the vavles. Please if possiable give step by step instructions. Also what specs are they supposed to be at and do you need any special tools to do this. Thanks.
Fastassbanshee96 is offline
post #2 of 7 Old 07-27-2010, 01:10 PM
Feedback Score: 1 reviews
Mojave Problem HELP heres some help and get the manual it has the specs and the clearance in on says 0.20 mm - 0.24mm front and backvalves i just did mine so i hope its right and i set mine to 0.22 easyis on the gage just have to finsh some carb work but yeah not that hard really just pashintes and all of plastiac seat etc a little airboxing has to come off
lovewheelen is offline
post #3 of 7 Old 07-27-2010, 03:44 PM Thread Starter
Ok I started doing it today. Now when you put the crank at tdc the line on the crank should be in the viewing window at the top.... Now is the dot on the timing supposed to be in the front or the back? And do you adjust all 4 valves at once or is it like on chevy 350 where you put it at tdc on the intake stoke then adjust the exhaust then put on the exhaust stroke and adjust the intake. I really appreciate the help. No one else seems to want help out. And as far as the manual... It's not my 4 wheeler and the guy doesn't really want to spend the money. I know how to do the valve adjustment just not the procedure.... But thanks again.
post #4 of 7 Old 07-27-2010, 05:40 PM
Mojave Magic's Avatar
After you get the crank to tdc and see the line in the upper timing hole, you should see two dots on the cams like this picture. http://www.kawieriders.com/forum/att...81-medium-.jpg
That is where they stay while adjusting both the intake and exhaust valves. .008" on both is good for stock.
2001 Mojave sold
2002 Race Mojave sold
2003 Z400 sold
2005 Z400 too much to list Gncc #254
2003 Z434 Ars-Fx long travel super build almost done
Riders4christ.com
In Memory of Christopher Riley Andrews
1-24-02 to 1-23-06
Mojave Magic is offline
post #5 of 7 Old 07-27-2010, 06:02 PM Thread Starter
Thanks alot. I'm going to give it a shot tomorrow. Hopefully all goes good and I can get it running. When I did it today I believe I had it on the exhaust stroke, the dots on the timing were facing eachother, but when I went to start it it was back fireing real bad. What could this be caused from. I'm guessing I adjusted the 180 out. When I talk to the dealer they said you can do it at tdc of either. They were kinda being dicks and were trying to get me to bring it in. But thanks again. I will post how it goes.
post #6 of 7 Old 07-27-2010, 06:28 PM
I can't remember if you can do them 180 out or not. You'll find we don't put much stock in dealers around here, I only go to mine if I absolutely have to.
After the valves are correct, there's plenty of other stuff to make these run bad, so we'll go from there.
2001 Mojave sold
2003 Z400 sold
Riders4christ.com
1-24-02 to 1-23-06
post #7 of 7 Old 07-27-2010, 06:47 PM Thread Starter
Sounds good. Thanks again for all the help. I'll let you know how it goes tomorrow.
Go Back   Kawasaki ATV Forum > Kawasaki ATV Performance / Maintenance / Technical > Kawasaki Mojave/Lakota
How do you adjust the valves on mojave? crmaverick Kawasaki Mojave/Lakota 7 01-31-2009 11:20 PM
NEw coils on ebay or adjust valves by the stealer MUddogg Kawasaki KFX700 V-Force 1 01-13-2008 01:01 PM
how to adjust the valves? sdteb Kawasaki Brute Force/Prairie/Bayou 2 01-06-2007 05:57 AM
When to adjust Valves on P700 bigred04 Kawasaki Brute Force/Prairie/Bayou 1 01-24-2005 10:18 AM
How to adjust suspension dnkrm Kawasaki Mojave/Lakota 1 08-26-2004 04:58 AM
