gas and oil mixture - Kawasaki ATV Forum
Kawasaki Tecate The most under-rated high-performance ATV ever!
post #1 of 10 Old 05-16-2005, 08:10 PM Thread Starter
hey guys, got a dumb question for ya. im knew to mixing gas and oil cause i have a 4 stroke dirtbike that runs of regular pump gas. i just bought a '88 tecate 4 and bought 5 gallons of gas. and i put a full bottle of oil in it.the guy i bought it from told me put the whole thing in, but after i did, i saw there were 2 different size of oil containers so im not sure which one he was talking about. did i put to much in,or is it ok? the manuel says a 20:1 mixture, is that ok or should it be higher?
sorry to sound so dumb, but im knew to 2 strokes, so thanks for the help, and try not to laugh at me, lol.
gellison38 is offline
post #2 of 10 Old 05-16-2005, 08:22 PM
mkacuna's Avatar
What size oil container you put in will determine what ratio you pre-mix is. I've always used 32:1 here in AZ. I'm sure you'll get a wide range of opinions on what to run. Good Luck!
mkacuna is offline
post #3 of 10 Old 05-16-2005, 09:06 PM Thread Starter
i used a regular 5 gallon gas tank, i put 5 gallons in it and mixed one of the 1 quart containers of oil in it. what ratio is that and was i supposed to use the whole bottle? i just want to make sure i didnt waste that gas and that its still ok to use.
post #4 of 10 Old 05-16-2005, 10:56 PM
kawie87's Avatar
Post
If you added 1qt to 5gal (20qts) of gasoline you're ok. Technically that is what the factory specs call for. A lot of people on here say that they run 32:1, 36:1 or 40:1 without trouble. But I had the same question (misc questions anyone???-forum) and I think the way King of Kawies explained it made most sense. Its along the lines of we are alowed to thin the mixture out a little more these days because the quality of gasoline and oils has improved alot since the 80's when these were made but he also advised not to run much leaner than a 26:1 because that also lubes your crank. These are high reving machines. Take precautions because the parts are rare.
kawie87 is offline
post #5 of 10 Old 05-16-2005, 10:58 PM
kawie87's Avatar
just because i did not clarify, that mixture you used was 20:1, factory specs.
kawie87 is offline
post #6 of 10 Old 05-17-2005, 01:17 AM
There is nothing wrong with 20 to 1. Better to be safe then very sorry.
04 KFX700 Gone
88 KXF250 Tecate-4 Sold them all!! Never again
87 Banshee Stock lol why the he!! did i ever not get one!!
Located in Kansas City,Missouri..........Missouri were the monster Bucks are. Dont think so ask for some pictures of my Missouri Bucks.
KingOfKawies is offline
post #7 of 10 Old 12-10-2011, 03:08 PM
i have a 1987 kxf250 tecate 4. does anyone know what ratio i should use?
kevans is offline
post #8 of 10 Old 12-10-2011, 03:28 PM
Feedback Score: 3 reviews
rockhound's Avatar
40:1 is how i mix mine
rockhound is offline
post #9 of 10 Old 12-13-2011, 10:43 AM
just to be sure, thats 40 ounces to a gallon right? and will duplex work with it? i have the kips motor by the way
kevans is offline
post #10 of 10 Old 12-13-2011, 01:24 PM
no not 40 ounces. 40:1 is the ratio not how many ounces to one gallon. buy a ratio rite and it will have the ratios for different amounts of fuel.
brose434 is offline
Go Back   Kawasaki ATV Forum > Kawasaki ATV Performance / Maintenance / Technical > Kawasaki Tecate
air/fuel mixture screws crazyorange Kawasaki KFX700 V-Force 5 06-22-2007 12:40 PM
Air/Fuel Mixture flipper Kawasaki KFX700 V-Force 4 04-23-2007 05:56 AM
More jetting, mixture, etc. help please ... twvette Kawasaki KFX700 V-Force 4 12-06-2004 08:43 AM
air mixture screw help SxysCowboy Kawasaki Brute Force/Prairie/Bayou 1 12-04-2004 07:28 PM
PRO-TEC mixture screw V10KLZZ71S Kawasaki Brute Force/Prairie/Bayou 1 11-29-2004 07:22 PM
