Dune gears
This is a discussion on Dune gears within the Kawasaki Tecate forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; What are you guys running for gearing at the dunes? I'm getting ready to go to Glamis soon and would like to put my power ...
Go Back   Kawasaki ATV Forum > Kawasaki ATV Performance / Maintenance / Technical > Kawasaki Tecate
Kawasaki Tecate The most under-rated high-performance ATV ever!
Old 01-26-2008, 11:14 PM   #1
View tecateguy's Photo Gallery(0)
Default
What are you guys running for gearing at the dunes? I'm getting ready to go to Glamis soon and would like to put my power to good use! My T-4 is stock except for the FMF fattie (blah, i know) and a K&N filter. Mods to come later. I weigh about 180lbs and the bike never seems to catch up with the tires. It will spin 'em in any gear when it comes on the pipe and I'm just wondering if I should chage anything? I do use the bike for more than the dunes...alot of desert riding near Florence and Maricopa (Phoenix for those who don't know). Any help would be great. Thanks in advance, Matt.
tecateguy is offline   Reply With Quote
KawieRiders.com is the premier Kawasaki ATV Forum on the web. Registered Users DO NOT see these ads. Please Register - It's Free!
Old 01-27-2008, 01:50 AM   #2
Feedback Score: 2 reviews
rockhound's Avatar
View rockhound's Photo Gallery(0)
Default
what size paddles are you running? i run 13-45 with 22x11x10 9 paddle haulers. after my new 330 i will run 13x43. if you are running a 20x10x10 8 paddle hauler. run a 13x39-42. don't go with a 12t front as you will eat the case with he chain. i can get you nice sprockets for whatever gearing you want. i'm ordering sprockets on monday. let me know, fronts are 10.00 plus shipping and rears will be 45.00 plus shipping.
ILR 330
ILR big bore pipe
44mm Lectron carb
chromoly antivibe stem
steel braided br lines
Trail tech computer
Rad bearing carrier
Choke on the bars
Flame seat cover
Stainless bolt kit
+2.5" swingarm
+3 ilr aarms
+4 durablue
New plastic
ASV levers
PVL coil
Check it out at http://www.rockhoundmotorsports.com
rockhound is online now   Reply With Quote
Old 01-27-2008, 04:17 PM   #3
Default
[/b]
I'm running 22x11x10 Sand Sharks (came with the bike), so what do you recomend?
Old 01-27-2008, 05:14 PM   #4
SandGeek's Avatar
View SandGeek's Photo Gallery(0)
Default
Have Rockhound score you a 46 rear from PBI.
a 22" is a tall sand tire for a stock engine. 13/46 will give you plenty of torque to move em. Its what I ran stock. I now have bumped the front up to a 14.
Every day when I wake up, I beat my own personal record for most consecutive days alive...
SandGeek is offline   Reply With Quote
Old 01-28-2008, 08:27 PM   #5
Default
[/b]
My mistake...they're 20's!! Sorry guys, how 'bout now?
Old 01-28-2008, 08:43 PM   #6
rockhound's Avatar
Default
13/39 is stock i would probably go 13/42
ILR 330
ILR big bore pipe
44mm Lectron carb
Trail tech computer
Rad bearing carrier
Choke on the bars
Flame seat cover
Stainless bolt kit
+2.5" swingarm
+3 ilr aarms
+4 durablue
New plastic
ASV levers
PVL coil
Old 01-29-2008, 07:32 PM   #7
Default
Bigger in back? I'm thinking I've got too much bottom now! Maybe I'm looking at it wrong...I'd like to get a little more top end or maybe use the lower gears a little longer.
Old 01-29-2008, 07:53 PM   #8
rockhound's Avatar
Default
what's your gearing now? what is dome to your motor?
ILR 330
ILR big bore pipe
44mm Lectron carb
Trail tech computer
Rad bearing carrier
Choke on the bars
Flame seat cover
Stainless bolt kit
+2.5" swingarm
+3 ilr aarms
+4 durablue
New plastic
ASV levers
PVL coil
Old 01-31-2008, 02:28 PM   #9
Default
Nothing, yet. Just seems to have too much bottom end...won't hook-up! Got good tires on the back but it just spins 'em when it comes on the pipe!
Old 01-31-2008, 04:23 PM   #10
rockhound's Avatar
Default
in the dunes? with paddles? sounds like you need a better paddle tire, with more paddles
ILR 330
ILR big bore pipe
44mm Lectron carb
Trail tech computer
Rad bearing carrier
Choke on the bars
Flame seat cover
Stainless bolt kit
+2.5" swingarm
+3 ilr aarms
+4 durablue
New plastic
ASV levers
PVL coil
Bookmarks
You may not post new threads
You may not post replies
V gears rsnyder1976 Kawasaki Brute Force/Prairie/Bayou 2 03-03-2009 06:45 PM
German Gears (BEVEL GEARS) Mikeyboy_esq Kawasaki KFX700 V-Force 23 11-23-2008 01:26 AM
V gears vs. Prairie gears?? JMcClure Kawasaki Brute Force/Prairie/Bayou 10 12-09-2007 11:45 AM
front bevel gears. AKA out put shaft gears. speedy81304_KVF700 Kawasaki Brute Force/Prairie/Bayou 0 10-27-2007 02:05 PM
Gears? hughfr1 Kawasaki KFX700 V-Force 18 02-06-2007 08:27 PM
