Torque Specs - Kawasaki ATV Forum
Kawasaki Tecate The most under-rated high-performance ATV ever!
post #1 of 6 Old 03-11-2008, 11:15 AM Thread Starter
This is my last lack-of-manual post, I promise!
I called today, repairmanual.com says that they are shipping it out today.
However, my powervalves came in today, so I can finally put my engine back together.
Can someone supply me the torque specs for:
1) The head bolts
2) The large nut that holds the clutch basket on
Thanks!
nhm90 is offline
post #2 of 6 Old 03-11-2008, 12:04 PM
1) The head bolts
Thanks!
[/b]
Head bolt torque is 18 ft-lb for the 8mm, 87 in-lb for the 6mm. Tighten 8 mm;s first.
Nut for clutch basket is 65 ft-lb.
jcchristn is offline
post #3 of 6 Old 03-11-2008, 01:05 PM Thread Starter
Thank you sir!
nhm90 is offline
post #4 of 6 Old 03-11-2008, 04:31 PM
gooie250's Avatar
Quote:
<div class='quotemain'>
1) The head bolts
Thanks!
[/b]
[/b][/quote]
does anyone have the torque specs for the hole bike?? if so so that would be very helpfull to all
gooie250 is offline
post #5 of 6 Old 03-11-2008, 05:56 PM Thread Starter
Well...she is back up and running.
I need a new carb/intake boot. Mine is all cracked and it is running lean. Also, the side case is leaking ATF. I need to take it back off. The previous owner did not have a gasket on it and had sealed the entire side case with silicone. I have a new gasket, which was coated in Permatex Copper, but it is still leaking. I assume that there is a high spot or a bad scratch in the sealing surface.
nhm90 is offline
post #6 of 6 Old 03-11-2008, 06:18 PM
SandGeek's Avatar
I didn&#39;t have much luck with the clutch cover gasket either. I just use case sealer
Hey are the head torque spec right from the manual? I was told (and have always used) 20 ft. lbs.
Either way, make sure you re-torque them again after a couple heat cycles.
Every day when I wake up, I beat my own personal record for most consecutive days alive...
SandGeek is offline
Go Back   Kawasaki ATV Forum > Kawasaki ATV Performance / Maintenance / Technical > Kawasaki Tecate
Torque Specs stut1313 Kawasaki Mojave/Lakota 0 05-08-2009 05:34 AM
Torque Specs The Speed Force Kawasaki KFX700 V-Force 9 03-10-2008 08:57 PM
torque specs. jake_evans420 Kawasaki KFX700 V-Force 5 08-09-2007 03:56 PM
Torque specs RamForce Kawasaki KFX700 V-Force 6 08-05-2004 04:52 PM
cam torque specs rubicon20032003 Kawasaki Brute Force/Prairie/Bayou 0 06-14-2004 01:47 PM
