wont start
This is a discussion on wont start within the Kawasaki Tecate forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; Ok I think I figured it out I started measuring the electric side of the bike. Stator source coil fine also the primary side of ...
Go Back   Kawasaki ATV Forum > Kawasaki ATV Performance / Maintenance / Technical > Kawasaki Tecate
Kawasaki Tecate The most under-rated high-performance ATV ever!
Old 07-02-2009, 06:42 PM   #11
Feedback Score: 1 reviews
ezjman's Avatar
View ezjman's Photo Gallery(0)
Default
Ok I think I figured it out I started measuring the electric side of the bike. Stator source coil fine also the primary side of main coil fine. When I got to the secondary side of the main coil it had an open cicuit. I then put a plug in the boot and spun motor and it was sparking. I measured circuit again and it was still bad. I removed the boot from the wire and again measured and this time it came up good. Something in the boot is shorted or broken. I next put a spare coil on the bike that measured good and the spark was much brighter. I guess that the spark was jumping in the bad boot. My question is when the spark plug is in the cylinder and under compression with weak spark will it spark at all. This would explain the overload of fuel in the cylinder.
88 Tecate 4
ILR 330LR
ILR Big Bore Pipe
ILR Big Air Filter Kit
Lectron 44mm Power Jet
ILR +3 A Arms
04 Yfz450
All stock
08 Engine Mod
ezjman is offline   Reply With Quote
Old 07-02-2009, 08:03 PM   #12
canada's t4's Avatar
View canada's t4's Photo Gallery(0) Send a message via MSN to canada's t4
Default
it will spark but it wont combust the raw fuel causing it not to spark
`2005 bruteforce 750i
26 inch mudlites
moose power module
passenger seat
warn winch
fairing
muzzy pro
`1996 ski doo formula 3 600 triple(AKA the purple screamer)
`1990 kawasaki bayou 300 4x4
25" mudbugs
custom loud leaky exhaust
custom topend lubrication mod(cooked rings lmao)
aftermarket rev box increased rev limit to 9800rpm
canada's t4 is offline   Reply With Quote
Old 07-03-2009, 03:25 PM   #13
T4250's Avatar
View T4250's Photo Gallery(0)
Default
Quote: Originally Posted by asnowmobiler View Post
try leaving the gas cap loose,so it does not build pressure.
The fuel only gets in one way,that's past the needle/seat.
there ya go !
  1. 87 T4 250
  2. 97 Warrior 350
  3. 06 Z 250
  4. 88 XL 1200
T4250 is offline   Reply With Quote
Old 07-03-2009, 04:09 PM   #14
ezjman's Avatar
Default
Ok got it started in 3 kicks tonight. The coil was the problem. Not a strong enough spark. Thanks for the help guys, all good info
88 Tecate 4
ILR 330LR
ILR Big Bore Pipe
ILR +3 A Arms
04 Yfz450
All stock
08 Engine Mod
polaris ultra 680 fuel problems
You may not post new threads
You may not post replies
I've tried everything - V wont start The Speed Force Kawasaki KFX700 V-Force 63 02-26-2009 03:10 PM
Help my v wont start gadawgz71 Kawasaki KFX700 V-Force 14 04-29-2008 04:55 AM
v-force wont start now. wont turn over 2qk4u Kawasaki KFX700 V-Force 1 10-28-2007 08:24 AM
Well, it wont start Enigma Kawasaki KFX700 V-Force 39 05-16-2007 08:18 AM
V wont start! Phil Kawasaki KFX700 V-Force 13 10-09-2006 06:10 PM
