This is a discussion on Parting a fresh bike with all the fixins!! within the Kawasaki Tecate forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; Before i quote the motor price to anyone, first i want to lay out what a motor of this caliber takes to build top end, ...
| Kawasaki Tecate The most under-rated high-performance ATV ever! |
LinkBack | Thread Tools | Display Modes |
#11 |
Feedback Score: 2 reviews
top end, with head machine and porting with teflon coated piston 700.00 rebuilt long rod crank 250.00 all bearings and seal for lower end 300.00 labor to split cases 300.00 new power valves 100.00 new stator and flywheel 250.00 carbon tech reeds, reed spacer and big carb intake boot 150.00 The cases are powdercoated red, the side covers are powdercoated black, the head and jug are polished. it would cost you 2050 to build this same motor, not including any shipping. of course, that's with labor, but not including the motor itself. i am selling the motor for 1800.00 shipped. Or, if it doesn't sell, i'll shrink wrap it and leave it in my trailer as a spare.
ILR 330 ILR big bore pipe 44mm Lectron carb chromoly antivibe stem steel braided br lines Trail tech computer Rad bearing carrier Choke on the bars Flame seat cover Stainless bolt kit +2.5" swingarm +3 ilr aarms +4 durablue New plastic ASV levers PVL coil Check it out at http://www.rockhoundmotorsports.com |
| Sponsored Links | ||
KawieRiders.com is the premier Kawasaki ATV Forum on the web. Registered Users DO NOT see these ads. Please Register - It's Free! |
#13 |
For those of you who are himming and hawing, hurry and make up your minds, i have multiple guys asking about the same parts. i'm going to start taking the offers where they confirm they want the parts.
#14 |
I have received enough interest in these parts to begin disassembly, for those of you who have commited to parts, send some money to rockhoundmotorsports@yahoo.com and be sure to put in the notes what you are buying and your kawieriders username. Parts will start shipping on monday
#15 |
Here is a list of all that is left, i will update it daily:
carb ***Klemms pipe<<<<<>>>>>3WHLNUT Billet rear bearing Carrier Engine seat(black gripper) Pc brake lever and clutch perch/lever +2" RHMS steering stem(w/anodized red aftermarket upper bar clamp) aftermarket tie rods front aluminum wheel spacers 1"(3 sets available) shifter(chrome) kicker(chrome) front bumper(chrome) chain and sprocket set PBI and oring Powdercoated swinger w/new bearings<<<<<>>>>>brose434 88 aarms w/new balljoints and pivot bearings/seals powdercoated spindles front hubs with brake discs and new bearings ***billet gas cap<<<<<>>>>>D'sTecate rebuilt rear shock powdercoated twist throttle with cable pegs(chrome) headlight and mechanism harness with components front fender support PC radiator front PC 87 shocks with chrome keepers tank and petcock pc sprocket hub pc brake hub R brake assembly front brake assembly pc brake stay ***PC rear wheel hubs 4 0n 110<<<<<>>>>> 3WHLNUT pc rear hubs 4 on 156 aftermarket grab bar hoses taillight bars pc white maier rears with very small bubble white factory fronts white factory hood black sides(painted) air box w/k&n Frame Pc red with title(and subframe) white rad shrouds stainless bolt kit Rear fender support RHMS Stainless Rear brake disc. If it's on this list, it's available. Hurry guys, this stuff is going fast
ILR 330 ILR big bore pipe 44mm Lectron carb chromoly antivibe stem steel braided br lines Trail tech computer Rad bearing carrier Choke on the bars Flame seat cover Stainless bolt kit +2.5" swingarm +3 ilr aarms +4 durablue New plastic ASV levers PVL coil Check it out at http://www.rockhoundmotorsports.com Last edited by rockhound; 02-08-2010 at 06:26 PM. |
#16 |
Feedback Score: 1 reviews
I want the folowing chrome items pegs, kicker, shifter, brake pedal, front bumper
and the aftermarket grab bar
06 Kfx 700 fst800 stage 2 cams big kev drag pipe 87 Tecate 4 soon to be a 330 Last edited by hensons700v; 02-07-2010 at 09:09 PM. |
#19 |
Pm sent, Hurry guys, off to ebay soon.
#20 |
40mm Lectron Powerjet Carb 185.00 ***Klemms pipe<<<<<>>>>>3WHLNUT Billet rear bearing Carrier 75.00 Engine 1800.00 seat(black gripper) 65.00 Pc brake lever and clutch perch/lever 30.00 +2" RHMS steering stem(w/anodized red aftermarket upper bar clamp) 135.00 front aluminum wheel spacers 1"(3 sets available) 50.00 per set shifter(chrome) 40.00 kicker(chrome) 75.00 front bumper(chrome) 75.00 chain and sprocket set PBI and oring 100.00 Powdercoated swinger w/new bearings<<<<<>>>>>brose434 88 aarms w/new balljoints and pivot bearings/seals 125.00 powdercoated spindles 85.00 front hubs with brake discs and new bearings 60.00 rebuilt rear shock 160.00 powdercoated twist throttle with cable 25.00 pegs(chrome) 75.00 headlight and mechanism 60.00 harness with components 125.00 front fender support PC 40.00 radiator 30.00 front PC 87 shocks with chrome keepers 75.00 tank and petcock 40.00 pc sprocket hub 85.00 pc brake hub 85.00 R brake assembly 75.00 front brake assembly 60.00 pc brake stay 15.00 PC rear wheel hubs 4 0n 110 40.00 pc rear hubs 4 on 156 40.00 aftermarket grab bar 25.00 hoses 20.00 taillight 25.00 bars pc 25.00 white maier rears with very small bubble 175.00 white factory fronts 150.00 white factory hood 25.00 black sides(painted) 85.00 air box w/k&n 45.00 Frame Pc red with title(and subframe) 275.00 white rad shrouds 125.00 stainless bolt kit 75.00 Rear fender support 45.00 If it's on this list, it's available. Hurry guys, this stuff is going fast. For those of you who haven't paid for your confirmed parts, this afternoon they will come available again. I want this stuff gone so jump on this stuff. There are still a lot of aftermarket parts left. Don't let all the Ebay vultures have all these bitchin parts!! Prices are shipped continental U.S. __________________
ILR 330 ILR big bore pipe 44mm Lectron carb chromoly antivibe stem steel braided br lines Trail tech computer Rad bearing carrier Choke on the bars Flame seat cover Stainless bolt kit +2.5" swingarm +3 ilr aarms +4 durablue New plastic ASV levers PVL coil Check it out at http://www.rockhoundmotorsports.com Last edited by rockhound; 02-09-2010 at 10:03 AM. |
Back to Top
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Parting out a very nce bike | rockhound | Kawasaki Tecate | 19 | 10-05-2009 08:58 AM |
| Parting out a fresh bike | rockhound | Kawasaki Tecate | 25 | 08-25-2009 04:11 PM |
| fresh meat | warpigg | New Member Introductions | 5 | 08-23-2009 06:13 AM |
| "parting out new bike" | sfarrar | Kawasaki Tecate | 10 | 08-06-2009 01:54 PM |
| For Sale: 1989 Kawasaki KX80 KX 80 Engine Motor $200 (Parting out bike) | cyrjordan | For Sale | 2 | 01-01-2009 08:54 PM |
Looking for information on other ATV Manufacturers? Head on over to visit our friends on these other forums specializing in the following: Kawasaki ATV - Can-Am ATV - Polaris ATV - Suzuki ATV - Yamaha ATV - Honda ATV - KTM ATV - Yamaha Raptor - Can-am DS450 - Kawasaki KFX 450 - Suzuki LTR 450 |
