Go Back   Kawasaki ATV Forum > Kawasaki ATV Performance / Maintenance / Technical > Kawasaki Teryx 750 / Mule / UTVs
Kawasaki Teryx 750 / Mule / UTVs Kawasaki Teryx ForumThe new Teryx UTV, and the original Mule. For a site specific to the Kawasaki Teryx, please check out TerxForums.net.
Old 09-06-2011, 05:46 PM   #1
View luke0927's Photo Gallery(0)
Default Help troubleshooting mule that will not start!
Hey folks this has me stumped hopefully you can help me figure it out, This is my grandpas mule 550 KAF300-C6.
Everything was running fine put it up one night, went out the next morning was a little harder to start (normally fires right up said it kind of sputtered) road it around a little and then parked it went back later and it will not start turn over but will not start.
So hear is what I have went through.
Pulled plug changed plug, and it gets plenty of spark, finger over spark plug hole will blow back when turning engine over, cleaned fuel filter, new gas, pull fuel line to carb gas is pumping to the carb, pulled carb cleaned it....
That still didn't work, then I tried to start with Ether and it would not hit even with ether. All fluids are good so I wouldn't think it would be some sort of safety cut off (that would kill fire at the plug right) So when I had compression, fuel, fire, and it wouldn't even hit on ether I'm stumped.
the only thing I can think of is there is something up with top dead center or the timing...but I'm not real familiar with Kawasaki's or air cooled engine but if I have good instruction I can normally work on it.
we use this a lot for work on the farm etc...been down about a week and hopefully can get it up an running.
Thanks!!
Luke
luke0927 is offline   Reply With Quote
Old 10-01-2011, 10:09 PM   #2
View Smcardoza's Photo Gallery(0)
Default
Im having the same issue. Got spark,fuel, but not even a pop. I dont get it!! Did you figure it out??
Smcardoza is offline   Reply With Quote
Old 10-02-2011, 05:50 AM   #3
Feedback Score: 2 reviews
rdm531's Avatar
View rdm531's Photo Gallery(0)
Default
do a real compression test , my 650i ran fine started with a bump on the button, moved a trailer one morning turned it off to hook trailer tothe truck , it never started agian, like you said it would blow finger off hole , but the real compression was likr 25 to 30lbs tore it down an rings were collapsed to the piston
06 650i,sleeved to 85mm, fst 11.5-1 pistons, fst stage 2 cams,hd value springs,dyna fs ing,full hmf exhaust, hl springs & lift,29.5skinny laws, 1.5in spacers front/2.5 spacers rear, 3000hd warn winch, 2in center snorkels,rad relocated/brush guard&wind screen,aux driving lights,back up light/brush guard,front mounted recever hitch,custom 4 gauge cluster, oil temp, oil press, water temp, an return oil temp,rmax manual 4wd,oil cooler,b/w boston(mud)terrior goes everwhere 4 wheeler gos. ez steer
rdm531 is offline   Reply With Quote
Old 10-03-2011, 10:27 PM   #4
Default
Thanks.. compression is at 15-20. The manuel says it should be between 115-175. I guess ill start tearing into the top end. Thanks for replying!!
Old 10-04-2011, 04:50 AM   #5
rdm531's Avatar
Default
strange how these things will do , mine never used oil or smoked , an ran strong , an like i said worked that morning , shut down for 10/15 mins ,an never even tried to start after that, hope its just rings for you not value related
Old 11-20-2014, 09:42 AM   #6
View Yaddammerpl's Photo Gallery(0)
Default
This posts is*very*informative.*Thank you!
матрешки
Yaddammerpl is offline   Reply With Quote
Remove Ads
07 kawasaki mule 600 wont start
1997 kawasaki mule 550 nuetral safety switch
3010 mule will only start with spark plug pulled
kaf620h6f mule wont start
kawasaki mule 4010 fuel filter location
kawasaki mule 550 no spark
kawasaki mule 550 starter clicks
kawasaki mule diesel wont start
kawasaki mule that wont start
kawasaki mule won't start
mule 610 gas in oil
my kawasaki mule won't start
troubleshooting kawasaki mule
You may not post new threads
You may not post replies
04 Prairie 700 4x4 troubleshooting bones22 Kawasaki Brute Force/Prairie/Bayou 4 07-10-2010 07:23 PM
my 610 mule Darrell Kawasaki Teryx 750 / Mule / UTVs 0 09-21-2009 07:54 PM
More Jetting Questions & Troubleshooting TheHouse Kawasaki Brute Force/Prairie/Bayou 13 03-13-2008 09:59 AM
Troubleshooting a sitting quad. miskywhisky Everything Else 8 03-10-2008 11:25 PM
Troubleshooting a sitting quad. miskywhisky Kawasaki Brute Force/Prairie/Bayou 0 12-31-1969 06:00 PM
» Discount Tire
Motosport.com
