840cc teryx top speed
This is a discussion on 840cc teryx top speed within the Kawasaki Teryx 750 / Mule / UTVs forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; did some speed runs today and all i could get was 68mph out of it, i was really hoping to break 70. we used a ...
Go Back   Kawasaki ATV Forum > Kawasaki ATV Performance / Maintenance / Technical > Kawasaki Teryx 750 / Mule / UTVs
Kawasaki Teryx 750 / Mule / UTVs Kawasaki Teryx ForumThe new Teryx UTV, and the original Mule. For a site specific to the Kawasaki Teryx, please check out TerxForums.net.
Old 03-22-2008, 06:32 PM   #1
View chase's Photo Gallery(0)
Default
did some speed runs today and all i could get was 68mph out of it, i was really hoping to break 70. we used a radar gun and gps to make sure the speed was accurite. using an hpd plain spring with vforcejohns clutch mods the shift rpm is at 7200-7300, at 68mph it was at 8050rpm. i'm fairly sure i'm not into the peak power yet so i need to get the rpms up more. i'll order up some more parts this week and try again next weekend.
i've got a short video that is still uploading, will post a link later tonight!
chase is offline   Reply With Quote
KawieRiders.com is the premier Kawasaki ATV Forum on the web. Registered Users DO NOT see these ads. Please Register - It's Free!
Old 03-22-2008, 07:04 PM   #2
Feedback Score: 1 reviews
mikee's Avatar
View mikee's Photo Gallery(0)
Default
That is still fast in a side x side. Probably alot faster than you can go most anywhere in it but I know how it is faster the better.
08 Brute Force 750 EFI
Parting it out.
mikee is offline   Reply With Quote
Old 03-22-2008, 07:07 PM   #3
Banned
View FourStrokeTech's Photo Gallery(0)
Default
[/b]
I'm sorry I told you 8500, it's 7500 so you are close.
FourStrokeTech is offline   Reply With Quote
Old 03-23-2008, 07:20 AM   #4
Supporting Vendor
Feedback Score: 5 reviews
VFORCEJOHN's Avatar
View VFORCEJOHN's Photo Gallery(0)
Default
Sounds good. I thought it would be faster than that but you aren't able to use all of the overdrive.
before at 58 MPH you were on the Limiter @ 9200?. now at 68 you are just breaking 8000 rpm. it has the gearing, just needs more power, and to tinker with the clutch setup
Like we discussed. Try a lighter spring like the OR/Blue or the Maroon, or Comet Black. the HPD#6 is hard hitting but is about the worst top speed spring out there.
If we still need to get the RPM"s up you can Only use the 08 Brute X1 weights.
Also If you have an LM1 tinker with jetting. too righ or too lean on top and you won't see all you have to offer.
Thanks for the feedback
www.VForceJohn.com (570) 773-1721
VFORCEJOHN is offline   Reply With Quote
Old 03-23-2008, 10:21 AM   #5
Default
Quote:
<div class='quotemain'>
[/b]
[/b][/quote]
i feel stupid Mickey asking you if you are sure, the only reason i do is that when the clutch was stock and i got to 50+mph the motor sure felt like it was pulling hard all the way to 58mph at 9200rpm?
Old 03-23-2008, 10:40 AM   #6
Default
[/b]
i'm going to try the comet black and the or/blue next week also getting those weights just incase.
the clutch does hit very hard off the line now and pulls real good up to about 50mph, above that the acceleration seems to really drop off. with the stock clutch and spring as i said above it felt like it was still pulling hard at 58, i could be wrong but it sure felt that way. i know my way around the motors ok but these clutches are another thing, still trying to understand exactly how they work.
can you explain to me why the hpd plain spring is about the worst top speed spring, and how that works. i just want to fully understand this clutch.
thanks!
Old 03-23-2008, 07:39 PM   #7
Feedback Score: 3 reviews
View minimus's Photo Gallery(0)
Default
[/b]
thanks!
[/b][/quote]
Chase have you opened the air box, and rejeted? The comet black is a good spring. Don't rely on GPS for short distance because of delay almost 2 seconds. Radar gun is good.
Not sure on your clutching but I gained 2 mph today with 1" taller rear wheels and 4 lbs lighter. I'm trying to get a good drag setup so been experimenting on my Brute.
minimus is offline   Reply With Quote
Old 03-23-2008, 08:40 PM   #8
Banned
Default
[/b]
[/b][/quote]
[/b][/quote]
I will check the dyno charts but I'm nut sure if its going to be the sams because I didn't do it on the same motor as you have, it was on a prairie with the same 840 and stage 3's.The prairie has longer smaller pipes and small carbs and longer intake lenth.
Old 03-24-2008, 08:31 AM   #9
Supporting Vendor
VFORCEJOHN's Avatar
Default
you don't need to rev that high. 7600-7800 rpm is where you want to be
DON"T chase an RPM. these are not 2 strokes. these motors can be clutched very broad in the RPM range and still put the power to the wheels
we saw on the dyno that making 730's with stage 2 cams revving 7900 rpm that was too high and LOST RWHP. 7300-7400 was optimum for best rwhp. more than that you lost power, less than that you lost power
what the HPD does is when compressed it is a VERY heavy spring to push fully closed. this closes the clutch slower at higher speeds. It is a very heavy hitting
Old 03-24-2008, 09:00 AM   #10
Default
thanks you guy, i will spring it down a bit and report
Bookmarks
You may not post new threads
You may not post replies
New Teryx... JAKE JANACEK Kawasaki Teryx 750 / Mule / UTVs 13 01-14-2009 06:16 AM
When will we get a Teryx like this? T_Dilley Club Kawie 12 11-18-2008 07:26 PM
840cc big bore update chase Kawasaki Teryx 750 / Mule / UTVs 79 09-10-2008 08:57 PM
Teryx on Speed Channel now. asnowmobiler Kawasaki Teryx 750 / Mule / UTVs 6 06-01-2008 11:53 AM
'08 750 or Teryx Roofer Kawasaki Brute Force/Prairie/Bayou 7 01-28-2008 09:38 PM
