Electric Fuel Pump Mod for IRS Brutes - Page 2 - Kawasaki ATV Forum
Interstate Motorsports
post #11 of 22 Old 03-27-2012, 09:06 AM Thread Starter
John, what do you think about connecting the pump to the kill switch wire? The y/r wire is very small where it connects to the CDI.
2012 Kawasaki Brute Force 750i non eps
Stock except for O/D Face Plate
2007 Kawasaki Brute Force 750i
Dynatek CDI, Standard Muzzy, VFJ Clutch, EHS Lid, 42s Fuel Pump Conversion
2006 Kawasaki Brute Force 650i
Dynatek CDI, Dalton Springs, O/D Face Plate
TNBRUTE is offline
post #12 of 22 Old 04-30-2012, 11:22 AM
what is everyone using for an adjustable fuel pressure regualtor? . . .
my pump is blowing past the seats
What PSI should I get 3-4 psi?
06 Brute Force 650i
4" Catvos | Gorilla axles | 29.5 outlaws | Highlifter radiator relocate
Dynatech CDI | Snorkeled | HMF slip-on | Front POS winch
TooTall is offline
post #13 of 22 Old 04-30-2012, 11:41 AM
Feedback Score: 18 reviews
brute 840's Avatar
I have a MR Gasket Regulator on mine
2012 TERYX
750 SPORT
2012 FX2 Super Crew F150
355 Gears Rear Locker
SCT X4 Tuner/Unleashed Tuning
Kicker Soundgate kit
Lowered
VAS Traction Bars
Wagner Intercooler
brute 840 is offline
post #14 of 22 Old 04-30-2012, 11:45 AM
Quote:
this one ? Mr. Gasket 2015
Mr. Gasket 2015 - Mr. Gasket Fuel Pressure Regulators - Overview - SummitRacing.com
Is there a return line on the bottom, or is that for a gauage hook up?
06 Brute Force 650i
TooTall is offline
post #15 of 22 Old 05-01-2012, 11:25 AM Thread Starter
I have had this happen a couple of times on my Brute. I have found that the pumps seem to vary a little in pressure. I have a cheap little vaccuum/pressure guage that I simply plug onto the outlet of the pump now before installing. The pump I was having problems with shows 8psi. The other three pumps I have bought show anywhere from 3-4psi. I have not seen a problem with any of the pumps showing the lower pressure. I believe that the 12s pump occasionally gets packaged as a 42s, but this is just a guess.
TNBRUTE is offline
post #16 of 22 Old 05-08-2012, 09:22 AM Thread Starter
Another update, I have finally taken the time to replace the pump on MY brute again. I tested the new 42s pump and found that it also only shows about 3psi. I took the pump off that was showing 8psi. I am having no more problems with fuel pushing the needles open. My fuel levels were always high with the 8psi pump and would occasionaly flood it out on side hills.
With this being said, I would HIGHLY recommend checking the pressure on the pump before installing.
TNBRUTE is offline
post #17 of 22 Old 08-05-2012, 06:40 PM
Thanks
Wanted to thank you guys for this valuable info (~$450 actually). I have an 2002 650 Prairie and after rebuilding the carb, I finally figured out the fuel pump was bad. Then after checking the price for a new pump (ridiculous $490+), I found this site and this post. I drove up to advanced auto parts and found the pump. I did do a few things different. I put the pump in the same spot as the old one, I simply slid the hose up on the existing pipe and was able to fit the new pump in to the old pump's spot. I cut the wires off the old pump and then used butt connectors and connected to the new pump, used heat shrink connectors, then double the heat shrink on top of that (I was a little concerned of getting a spark). Total time including the 15 min round trip to get the pump was just under 2 hours. Great information and tips, thanks again.
duckhuntinsailor is offline
post #18 of 22 Old 08-06-2012, 07:33 AM
Feedback Score: 9 reviews
VFORCEJOHN's Avatar
yes, that will absolutely work. with the 42S, if you grind off the molded plastic case, it's just a round small fuel pump.
WEB: WWW.VFORCEJOHN.COM
PHONE: 570-773-1240
EMAIL: [email protected]
DISCOUNT MUZZY EXHAUSTS click here https://www.kawieriders.com/forum/int...ml#post1328320
VFORCEJOHN is offline
post #19 of 22 Old 08-07-2012, 07:48 PM
Two notes, for those in the future who attempt the fix in the way that I did.
1. While you have the pump assembly out, replace the little piece of hose between the pump and the existing pipe. (Otherwise, you will likely have to tear it all apart very soon, to replace it anyway.)
2. Also take a good look inside your tank, drain it. I was actually glad I had to tear back into it. I had my son helping and he dropped the filter back into the tank. He stuck his hands in to retrieve it and said, "is all the pieces of plastic suppose to be in here???". I'm not real sure what is was from, but there were a lot of black pieces of plastic, all shapes and sizes, just waiting to be sucked up into the newly rebuilt carbs.
Just waiting on a 2WD 4WD actuator now. Hoping to have the beast back to life this weekend, it's been a long time... 3+ years!!!
post #20 of 22 Old 11-19-2012, 10:04 PM
cjcycle's Avatar
How about trying the Mr. Gasket 12s. It is rated at 35 GPH and the 42s is rated ate 42 GPH. Has anyone tried the 12s? Maybe I will try it.
cjcycle is offline
Electric Fuel Pump Mod - IRS Brutes TNBRUTE Kawasaki Brute Force/Prairie/Bayou 27 08-06-2013 04:06 PM
BF650i electric fuel pump Capt Duck Kawasaki Brute Force/Prairie/Bayou 0 01-26-2011 05:56 AM
do i have electric or vacuum fuel pump dieselfuel007 Kawasaki Brute Force/Prairie/Bayou 7 04-25-2010 07:06 PM
Electric fuel pump mod for Brute 650's with vacuum fuel pump VFORCEJOHN Interstate Motorsports 0 04-14-2009 01:21 PM
Electric fuel pump rsnyder1976 Kawasaki Brute Force/Prairie/Bayou 24 08-24-2008 11:17 PM
