Muzzy Exhaust Gasket for brute... - Kawasaki ATV Forum
Interstate Motorsports
post #1 of 15 Old 06-04-2012, 01:44 PM Thread Starter
Gallop's Avatar
Question Muzzy Exhaust Gasket for brute...
Just wondering what size these gaskets are? For the muzzy dual system on the 750 brutes...
I had the front head pipe come loose and blew out the gasket, what would be the best replacement gasket for me to use...
Thanks
08 840 DSC stg 1, TRP Cams, 28`OL2's/14'SS 212, 2`RDC Lift, Elka Stage 4's, ASR Pro X Tie Rods & Ends, Snorkeled, MSD Charge FI, Muzzy Super Pro`s, K&N Air Filter, VFJ Clutch Stage 3 Spidermod #3/#1 Springs, Highlifter DHT Axles, OMI Greasable Steering Stem, J&T Temp Gauge, 2012 Front Upper A-Arms, Full Ricochet Skids, Warn AT Winch 2500lbs, Heated Grips & Thumb, Eagle Eye HDI's, Kimpex Flexi Box + Pegs
Gallop is offline
post #2 of 15 Old 06-04-2012, 03:09 PM
2010Bruterider's Avatar
I have been using stock kawi exhaust gaskets with my standard Muzzy.
Sent using Tapatalk 2
Snow White 2010 Brute 750, protected by .357
2010Bruterider is offline
post #3 of 15 Old 06-04-2012, 04:44 PM
Feedback Score: 9 reviews
VFORCEJOHN's Avatar
That's because the std. muzzy (now discontinued) uses stock gaskets. the PRO and super pro have much larger headers and the stock gasket would simply fall down the pipe.
the PRO and SUPER PRO DUALS use either the gasket from Muzzy, which is a VOLKSWAGEN 1.5 inch flanged gasket. from an air cooled bug motor.
OR you can go to CB Performance and use their copper 1.5 inch gasket. either will work just fine. VVVVVVV Link below VVVVVV
CB Performance - Online Catalog
the copper get installed raised flange area toward the head.
the KEY TO INSTALL is making the gasket last by installing it correctly. evenly tighten down the stud nuts. some folks crank down on one side of the stud crushing the gasket and the other side seals cocked and blows the gasket out and then it can backfire on decel.
WEB: WWW.VFORCEJOHN.COM
PHONE: 570-773-1240
EMAIL: [email protected]
DISCOUNT MUZZY EXHAUSTS click here https://www.kawieriders.com/forum/int...ml#post1328320
VFORCEJOHN is offline
post #4 of 15 Old 06-04-2012, 05:27 PM Thread Starter
Gallop's Avatar
Thumbs up
I figured the stock gasket was way tooo small,
Perfect! That gives me a couple options to go with...
Just as you describe, "The key to install" is pritty much what happened to me, it was blowing out one side, and pop pop pop on decel is what I got, lol....
Thanks for the info..
Cheers!
Gallop is offline
post #5 of 15 Old 01-31-2013, 10:47 AM
CobraCDN's Avatar
Garage
The link no longer works, I found this one, just want to make sure it's the correct gasket.
1882 Copper Exhaust Gaskets 1 1/2" (set of 4)
That the one?
2007 Brute Force
Fundy 880 Big Bore
Muzzys Super Pro Dual Exhaust
CobraCDN is offline
post #6 of 15 Old 01-31-2013, 01:45 PM
VFORCEJOHN's Avatar
thats it
PHONE: 570-773-1240
post #7 of 15 Old 02-01-2013, 07:06 AM
CobraCDN's Avatar
Garage
Thank you
2007 Brute Force
Fundy 880 Big Bore
CobraCDN is offline
post #8 of 15 Old 03-31-2014, 12:42 PM
Can this gasket be used for the 650 Brute also?
That the one?
commando57 is offline
post #9 of 15 Old 04-08-2014, 06:49 PM
VFORCEJOHN's Avatar
Not unless you have Super Pro or PRO Muzzy headers
PHONE: 570-773-1240
post #10 of 15 Old 04-09-2014, 02:41 PM
I have the Muzz's that have 2 mufflers. They are Super Pro's, right?
Wtb big gun or muzzy exhaust for brute 750 JLOWERY Wanted 1 01-25-2012 09:11 PM
750 Brute Muzzy Exhaust, Do I need to Rejet dicko1980 Kawasaki Brute Force/Prairie/Bayou 6 07-08-2010 05:53 PM
Brute 750 Muzzy exhaust 05-BF-750 For Sale 17 06-05-2010 04:12 PM
Muzzy Exhaust and EHS controller for Brute Force 750 skip nay For Sale 3 11-16-2009 05:36 PM
Brute/Prairie 650 muzzy exhaust 05-BF-750 Wanted 6 03-16-2009 12:15 PM
