2012 bf 750 PC5 with custom map - bogging out used to work - Kawasaki ATV Forum
Interstate Motorsports
post #1 of 6 Old 10-04-2015, 05:27 PM Thread Starter
Angry 2012 bf 750 PC5 with custom map - bogging out used to work
I have a bf 750 with pc5 with custom dyno map from vforce john and clutch springs and swamp exhaust. the mapworked ok but I am having trouble with the bf bogging out mid throttle and seems to be worse in colder weather and really bad when I get down to 2 fuel bars and below.
I may put the stock map in and see if that fixes or improves anything. something is not right and I may have to verify the wiring and make sure both ignitions for each cylinder are connected. I can figure the problem.
my air box instead of a centre snorkel I have a breathing lid and blocked my stock airbox intake.. I removed the block which improved the bogging but like I said when fuel level is low its very evident..
any ideas would much appriociated. thnxs
kingnewf is offline
post #2 of 6 Old 10-04-2015, 06:26 PM
Feedback Score: 1 reviews
Could it be the fuel pump on the way out? The fuel level should have no effect on how it performs until it runs out of course
Green 2004 Vforce
2002 650 Prairie
riverkid is offline
post #3 of 6 Old 10-06-2015, 06:37 PM Thread Starter
Quote:
How would i test that? i am wondering if i have a hole in one of my exhaust pipes could that cause my issue. Im gonna try my stock map and see.
kingnewf is offline
post #4 of 6 Old 10-07-2015, 02:56 AM
I believe you can do a fuel pressure test prof you get a manual there is usually a measurement of how much fuel it should pimp out on a certain amount of time
Green 2004 Vforce
2002 650 Prairie
riverkid is offline
post #5 of 6 Old 10-13-2015, 07:00 PM
Feedback Score: 9 reviews
VFORCEJOHN's Avatar
Verify 43-45 psi. test this while running and under load situations while driving. this will require you to make a tee fitting to run to a pressure gauge. test it when you are experiencing the problem. bad fuel pumps are a huge issue with these machines.
Also. be sure your intake valves are not too tight. this has an effect on starting and midrange when cruising by loading it up.
WEB: WWW.VFORCEJOHN.COM
PHONE: 570-773-1240
EMAIL: [email protected]
DISCOUNT MUZZY EXHAUSTS click here https://www.kawieriders.com/forum/int...ml#post1328320
VFORCEJOHN is offline
post #6 of 6 Old 11-02-2015, 12:02 PM Thread Starter
thnxs vfj I took out my fuel pump replaced the fuel strainer and new plugs and wow did the bike wake up. Now I know there is another filter you cant replace in that pump assembly but I am hoping the pump has not gotten damaged but by the performance chance I suspect im good to go. That being said I am looking to re-run the check valve to my airbox as I read threads about the poor design of this and dirt getting sucked into the tank via the frame. I also bought ne check valve as it was stuck open.
thnxs for the info
kingnewf is offline
Help please. Need advice on 2012 Brute, bogging problem fuel or spark? CodysBrute Kawasaki Brute Force/Prairie/Bayou 8 06-17-2015 12:40 PM
Why is my atv bogging down Bobbyjt09 Tips/Help 1 12-08-2014 03:04 AM
Like my page... Custom vinyl work mnchvgs79 Club Kawie 0 10-01-2012 04:46 PM
bogging down mhilly Kawasaki Brute Force/Prairie/Bayou 0 06-14-2011 01:48 PM
custom fab work SxysCowboy Kawasaki Brute Force/Prairie/Bayou 11 08-12-2004 09:52 AM
