Teflon coated replacment faceplate bushings - Kawasaki ATV Forum
Interstate Motorsports
post #1 of 13 Old 08-02-2010, 08:42 AM Thread Starter
Feedback Score: 9 reviews
VFORCEJOHN's Avatar
Thumbs up Teflon coated replacment faceplate bushings
I finally got these in from being made up. they are stock replacment teflon coated faceplate bushings.
It's an alternative to replacing the faceplate which is over 75.00. and this will cure the knocking faceplate. simply press the old one out ahd press this one in.
These work in all Clutch faceplates, stock, stage 1-2-3-4 modded, Dalton, Dasa.
I have them in stock and ready to go.
18.00 Plus shipping (2 day is 6.00)
If you want them installed in your NON KEBC faceplate. ship me your's and I'll install it for free and return it. same price.
My bushing on the left. worn stocker on the right
Here's where the bushing goes. this is a stock Vforce faceplate but they fit every kawy faceplate made from 360cc to 750cc
Here's a picture comparing the bushings. the stock is a brownish paper impregnated bushing. you can see the thickness of the teflon impregnated in my replacment bushing.
This is a stock KEBC faceplate. they fit in there as well. but most of the time the KEBC bearing is worn as well. better than paying 85.00 for a stock kawy faceplate.
WEB: WWW.VFORCEJOHN.COM
PHONE: 570-773-1240
EMAIL: [email protected]
DISCOUNT MUZZY EXHAUSTS click here https://www.kawieriders.com/forum/int...ml#post1328320
VFORCEJOHN is offline
post #2 of 13 Old 08-02-2010, 09:14 AM
Feedback Score: 5 reviews
ItsAllCreated's Avatar
is that the knocking sound that almost sounds like engine has rod knock?
Why or what makes the faceplate knock?
~StephenB
ItsAllCreated is offline
post #3 of 13 Old 08-02-2010, 09:31 AM Thread Starter
VFORCEJOHN's Avatar
the faceplate knocks from this worn bushing. until now kawasaki only sold the bushing in the faceplate. they offer no replacment bushing.
to check your faceplate. just unbolt it and check the wobble in it. if it is over 1-2mm of play, then it's worn.
My main reason for making these is all the stage 2-3-4 clutches I have out there that have modified cltuch covers. Having them out there since 2003 and seeing what's been coming in lately, they have to be all worn out by now.
It's expensive to buy a new faceplate and then remachine it just to have what you already have. the aluminum doesn't wear, just this bushing. so this is the cure
however, this is not an end all, fix all to a worn clutch. There are other bushings and pads that wear that I have as well.
lower sheave bushing and weight bushings, as well as spider pads and weight pins.
PHONE: 570-773-1240
post #4 of 13 Old 08-02-2010, 10:36 AM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
What do you need to do different to install the bushing in faceplate with the KEBS bearing still in place? Had my clutch off yesterday; that bushing is worn, among other things, lol.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #5 of 13 Old 08-02-2010, 11:02 AM Thread Starter
VFORCEJOHN's Avatar
For the KEBC faceplates. You need a blind hole bearing puller and slide hammer it out. or hammer it out thru the faceplate hole (not recomended) sometimes they are in there pretty tight.
I use an arbor press to install and remove them. if you are using a hydraulic press, you'll probably crack the faceplate of the bearing is hard coming out.
PHONE: 570-773-1240
post #6 of 13 Old 10-13-2010, 05:29 PM
Feedback Score: 24 reviews
twyztid's Avatar
John,
I have an extra clutch that knocks a little until you rev the motor. The faceplate bushing definitely has some play but it seems that the spider pads and lower sheave bushing have a little more than normal play as well. I also noticed that the stall with any spring is increased with this clutch because it must be binding a bit from the worn bushings. I realize that the right thing to do would be to replace all of those pads/bushings but I don't want to spend the money on that. Would replacing this faceplate bushing help at all or would it be a waste of money without doing the others also?
'04 KFX800
DSC 12:1 Pistons w/ Stg 2 cams, Ported Heads, 36mm carbs, Muzzy Super Pro, Dual MTX-L, VFJ Stg 3 Spidermod Clutch & Adj. Weights, +8 Swing Arm, Elka Shocks, 24" 14-paddle Staggered SLS Ripper paddles, BOSS NOSS 40-shot
'04 KFX730
Custom 84mm 12:1 JE Pistons w/ FST Stg 2 cams, Muzzy Super Pro, UPP Crossover Intakes, 8* Timing Key, Elka Shocks, +4 Swing Arm Extension, 24" 10-paddle Skat-Trak Extremes
'04 KFX730
Wiseco 84mm 11.5:1 Pistons w/ Fundy Trail/Race cams, Muzzy Super Pro, Crossover Intakes, 6* Timing Key, Works front & Elka Rear Shocks, +4 Swing Arm Extension, 24" 9-paddle Skat-Trak Extremes
'05 BF730 SRA
'04 Prairie 700
twyztid is offline
post #7 of 13 Old 10-13-2010, 05:35 PM Thread Starter
VFORCEJOHN's Avatar
I have the lower sheave 15.00 and the faceplate 18.00 as well as shims for the spider pads.
dismantling the clutch is the easy part (if you have the tools). pressing out that damn lower sheave bushing without blowing the sheave in 1/2. that's the hard part.
faceplate bushing is easy install. place the new one on the top and press it right thru. old one pops out, new one goes in.
PHONE: 570-773-1240
post #8 of 13 Old 10-13-2010, 06:02 PM
twyztid's Avatar
I don't the tools to remove the movable sheave to replace the lower bushing or spider pads. Do you think it is worth replacing just the faceplate bushing?
'04 KFX800
'04 KFX730
'04 KFX730
'05 BF730 SRA
'04 Prairie 700
twyztid is offline
post #9 of 13 Old 10-13-2010, 06:26 PM
Thumbs up
Hey guys... I just noticed a wicked knock the other day, figured it was the clutch. When I removed the primary and started her up, the noise was gone. After a little more investigating, I found the faceplate bearing was the culprit and it seems no one can match up the bearing ( John, do you know anywhere that can provide a replacement bearing?) Anyway, I decided to press it out and re-pack it, in an attempt to buy a little more time and noticed the clutch cover wouldn't fit properly. That's when I realized the engine brake actuator malfunctioned and may be the root cause of the bearing failure. Thought I'd give everyone a heads up and the dealer tells me that there may be a recall, Has anyone else heard anything like this? It's either the module ( under the seat) or the actuator itself.....Anyway, Cheers! BTW it's an '06 Brute
hutchy is offline
post #10 of 13 Old 10-13-2010, 06:54 PM
Feedback Score: 10 reviews
GeneralV's Avatar
I know you said 360 to 750, but the p400 has a different type of clutch....will it work on a p400?
2012 General Lee BKP 800... Dixie Horn
Stamp #1
Stamp #2
Stamp #3 - pending
Stamp #4 - waiting on quad to sell
μολὼν λαβέ
GeneralV is offline
teflon tape? bjarke Kawasaki KFX700 V-Force 16 03-26-2010 12:13 PM
Clutch faceplate worn. Need advice ASAP. bigdaddy24 Kawasaki KFX700 V-Force 7 03-07-2008 08:27 AM
shock replacment serottak Kawasaki Tecate 3 03-11-2007 01:40 PM
Belt replacment question bradinwva Kawasaki Brute Force/Prairie/Bayou 11 12-30-2004 01:08 PM
Replacment front shocks Crashnrondo Kawasaki KFX700 V-Force 16 02-12-2004 06:44 AM
