1999 Prairie 400 wont get over 20mph - Kawasaki ATV Forum
post #1 of 10 Old 04-11-2014, 07:41 PM Thread Starter
Full disclosure I usually work on Honda ATV's. But, a buddy of mine bought a 1999 Prairie 400 for "a good deal" on local craigslist. It seemed to idle great and even rev up in neutral just fine, but does not accelerate past about 20 or so mph (cant tell cause speedo is broke). Prairie only has 1250 miles on it, so I thought no problem probably a carb issue from sitting. Went through the carb and runs even better now, but still wont rapp up /accelerate ike it needs to/should. Took clutch cover off and checked belt, few chunks on one side missing, so bought a new belt hoping that was it... Installed new belt and still wont increase speed to over 20ish.
In neutral, the CVT clutch system (front pulley) moves in and the belt moves up like it should??. When in gear (low and high) and under full throttle the clutch will move a little bit and belt slides up but only a little, does not come to even 1/3 as high at top speed as it does when in neutral. It also squeaks when in high gear and sitting parked with the new belt on it.
Looking for advise on how to fix this thing and if it is worth it? Anyone out there run into this issue before? I am 110% sure it's not carb related (have cleaned and rebuilt 50+ atv and moto carbs in the past). These CVT clutches are just new to me so any help is much appreciated. I did do a search of the forums but could not find anything that fit the bill. Prairie only has 1280 miles and 440 hours of use on it. Also checked spark plug and it is fine.
Thanks in advance from sunny Oregon
rocketvfr is offline
post #2 of 10 Old 04-11-2014, 07:47 PM
lumbeebrute's Avatar
Sounds like something in clutch is binding. Maybe take belt back off and see if it moves any further in when revved. Try to push it in by hand.
Black 09 650sra
Crossover intake
Vfj#1primary/#1secondary
Dynatek
Sunpro tachometer
Moose rear bumper
Superwinch lt3000
Scratches and dings.
lumbeebrute is offline
post #3 of 10 Old 04-11-2014, 07:55 PM Thread Starter
Clutch moves in great when sitting in neutral, belt goes to the top of the front pulley no problem. It just barely moves when it is in gear...
Open to thoughts.. Kawi's are new to me, had a prairie 650 that had a little carb trouble but once sync'd they worked great.
post #4 of 10 Old 04-12-2014, 06:20 AM
2 things come to mind. Clean the surfaces of the clutch with some a scotch bright or something not to aggressive to clean the glaze and old belt off the surface. Could be slipping at RMP. Also take your air compressor and blow out the clutches they are probably pretty dirty and possibly the pc's missing off the old belt are stuck in their.
zrock is offline
post #5 of 10 Old 04-12-2014, 08:41 AM
Feedback Score: 3 reviews
w_pinkerton's Avatar
secondary clutch froze?
2002 P650
Dynatek CDI/Plug Boot Mod/Crossover Intakes/Stock Exhaust
'03 Airbox/UNI filter/Polished Slides/2 Shims per needle/142F&R/42 Pilots
Pink Primary/Dalton OD Cover/KEBC Removed
Aluminum Products Skids and Bash Plate
Elka Spring Kit, 2" Lift kit, 1" wheel spacers
ODI grips/Maier Handguards/Rox Risers/Fly CR High Bars
25" Duro Power Grips
w_pinkerton is offline
post #6 of 10 Old 04-12-2014, 01:49 PM Thread Starter
Blew air all through it and scratched it up a bit with sandpaper. That resulted in belt sliding up to top in low range, but still will not in high range. I give up, my buddy can deal w it! Back to working on my foreman thx everyone for the ideas.
post #7 of 10 Old 04-12-2014, 02:56 PM
NovaKaw650's Avatar
Garage
Is it over-revving, or running out of power?
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #8 of 10 Old 04-12-2014, 04:55 PM
Are you sure it's the right belt?
Black 09 650sra
Crossover intake
Dynatek
Sunpro tachometer
Moose rear bumper
Superwinch lt3000
post #9 of 10 Old 04-13-2014, 07:33 AM Thread Starter
Running out of power. Put old belt back on and same result, minus the squeaking. Put a petcock rebuild kit to make sure getting good fuel flow. It's going back to him tomorrow to use in low range and see what results he gets. May end up on craigslist.
post #10 of 10 Old 06-26-2019, 05:30 PM
Quote:
Had same issue, 2001 Kawasaki Prairie 400 Auto 4X4, sat for awhile, got running but wouldn’t go over 15mph, FIXED: Carb slide wasn’t rising? Found Rubber Carb Diaphragm and spacers not installed installed correctly. Re-installed in correct order, Now runs great with plenty of power. 👍
Fpdhdmc is offline
1999 Prairie 400 4x4 Question ncsuengineer Kawasaki Brute Force/Prairie/Bayou 13 12-11-2013 01:10 PM
1999 prairie 300 lonewolf3700 New Member Introductions 2 06-04-2012 02:31 AM
Prairie 360 wont go over 20mph at high altitude-finally fixed it! mhanawalt1 Kawasaki Brute Force/Prairie/Bayou 0 04-17-2012 12:10 PM
1999 prairie 300 ajcof Kawasaki Brute Force/Prairie/Bayou 1 04-26-2011 04:44 PM
1999 prairie 300 4x4 maddmaxx65 Kawasaki Brute Force/Prairie/Bayou 5 03-31-2010 12:24 PM
