Common problems with a Brute Force KVF750 - Kawasaki ATV Forum
post #1 of 15 Old 07-25-2018, 01:59 PM Thread Starter
Capt_Kirk's Avatar
Location: Live in McCordsville Indiana with plans to retire in southern Indiana
Garage
I have an over heating problem with a red light (temp) coming on after 3 miles of pulling a 44" Swisser mower. So I have gotten some replies like: from VTwinkawi says twin prairie never liked going slow for that long always overheated me. why I used the 360 for mowing and rhino. How does the Brute do? My answer is that after 3 miles the over heat light comes on. So I have replaced the thermostat and it does the same thing, I have heard the fan come on so I would eliminate the fan switch and fan. A suggestion is to add an oiler cooler which is a great consideration. Another recommendations is to clean the radiator from the fan location to the forward. So I am 3 hours away from my bike requiring me to trailer it home for an over haul. Thanks all for the recommendation.
My Brute 750 operates cool as a cucumber!
Capt_Kirk is offline
post #2 of 15 Old 07-25-2018, 03:03 PM Thread Starter
Capt_Kirk's Avatar
Garage
What should I expect from EPS
The Electronic Power Steering (EPS) on my Brute Force 7504x4i EPS is it working or not? being a new owner I don't know for sure. I am 245 lbs 64 years young and I can work the handlebars but my wife probable cannot. Should it be an easy movement or not. If there are any of you guys/gals that know about how the EPS feature is suppose to react I would appreciate some feed back. Capt K
post #3 of 15 Old 07-25-2018, 06:54 PM
Swanny52's Avatar
Post
Quote:
I think you have to be moving for it to work ? Pretty shur thats how mine is because i can feel it kick in
17 Brute Force Camo Eps
Stage 3 Elkas
Vfj Stage 3 Clutch
Empire Duals
Vfj tuner and dyno tune
26' mudlite xtrs
Moose front and rear bumper
Full Hdpe skidplates
Kfi 3500s winch
Oem Teryx headlights
1.5 wheel spacers
Asr tie rods
Uni Filter
Swanny52 is offline
post #4 of 15 Old 07-25-2018, 07:05 PM
NMKAWIERIDER's Avatar
It should work without moving as long as the key is on....and better when running with power above 13.5 volts/ It's never easy enough to turn with one finger on pavement but ...one-handed-yes. My friend's 2012 Brute was much like mine with the SATV 380 PS system. On dirt you could turn it with one finger so if yours isn't like that...something may be wrong.
06 BF 750(SOLD)
15 Z Force 800 EPS
My Videos on YouTube
NMKAWIERIDER is online now
post #5 of 15 Old 07-25-2018, 10:39 PM
kickstart's Avatar
I mow about 10 acres of wild grass with a 54" tow mower at 5000 feet elevation. I average about 4 mph for the best cut. Never had it overheat. But I run full synthetic oil and my rad is always clean.
2005 Prairie 732cc Team Green Special Edition
Wiseco pistons
2015 BF750 camshafts
Warn winch/Amsteel Custom Splice synthetic winch rope
Maxxis VIPR tires/12" DWT Rattlesnake wheels
Twin Air filter/TPI air box vent valve
Powermadd Star series handguards/Symtec Heat Demon grips
Adjustable Progressive front springs
VFJ adjustable clutch weights
EPI pink primary/VFJ #1 secondary
QuadBoss 8" sound tube
8" Cree LED bar/LED Underglow kit
Custom RCM shift knob
DYNATEK CDI
kickstart is offline
post #6 of 15 Old 07-26-2018, 01:49 AM
VTwinKawi's Avatar
some things i did to make mine run cooler, take ran fan out once every couple months clean it from the back with foaming simple green. make sure the coolant has more than 50 percent water, added a metal sheild on the frame by the bends, make sure you have side sheilds so the air cant go around it, probably the biggest change was making the tune richer. changing the jets and shims on a carb, tune or ejk on a efi
2018 pioneer 700m2 terra 45, mud lite II
recent previous
2016 570 outty max 27 mudlite xtr
2006 660 Rhino 27 mega mayhems
2003 650 Prairie mud lites(sold)
2008 700r Raptor se razrz
2006 360 full skids winch
VTwinKawi is offline
post #7 of 15 Old 08-09-2018, 06:39 PM Thread Starter
Capt_Kirk's Avatar
Garage
Quote:
my elevation change is about 800ft so now that I have my rad 98% cleared. I will add the oil cooling system and I hope this will resolve any over heating issues.
post #8 of 15 Old 08-09-2018, 07:01 PM
kickstart's Avatar
Kawies run right at the edge of temp. If the cooling system isn't at full efficiency, they'll overheat quick. But as long as the system is operating normally, it shouldn't ever overheat. The fan might run all the time, but that's it.
Of course, adding an oil cooler is never a bad idea.
Wiseco pistons
DYNATEK CDI
post #9 of 15 Old 08-10-2018, 01:23 AM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
What year, and how many hours and miles?
And yes, the rad has to be perfectly clean.
The oil cooler is nice to have, but won't make much of a difference to the operating temperature of the motor.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #10 of 15 Old 08-10-2018, 01:29 AM
NovaKaw650's Avatar
Garage
The fan should come on while hauling the mower, and virtually never shut off.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
2014 Kawasaki Brute Force 750 4X4i EPS Specs NickJ Kawasaki ATV News / KawieRiders.com News 3 10-24-2016 04:07 AM
2016 Kawasaki Brute Force ATV Model Range 4Nines Kawasaki ATV News / KawieRiders.com News 29 04-07-2016 05:14 PM
2012 BF750 High Lifter Lift Kit mbonno For Sale 5 07-18-2014 02:43 AM
2014 Kawasaki Brute Force 750 4X4i EPS Realtree Camo Specs NickJ Kawasaki ATV News / KawieRiders.com News 1 09-11-2013 10:38 AM
4wd problems with 05 brute force 750 blatzman Kawasaki Brute Force/Prairie/Bayou 0 03-09-2010 03:26 PM
