Brute Force 650i problems changing gear - Kawasaki ATV Forum
post #1 of 22 Old 08-28-2018, 12:02 PM Thread Starter
What could be causing my problems on my brute? It's hard to change gear in it and I have to rock the atv forward/backward to get the gears changed. RPMs seem fine. CVT belt is worn out/has cracks and is pretty loose, but doubt that would cause it. Ordered new belt but I think it might be caused by something else. Any ideas? The brute has 3500 miles/600 hours on the clock.
Illusmare is offline
post #2 of 22 Old 08-28-2018, 01:09 PM
VTwinKawi's Avatar
they shift hard, its how all well designed quads are. they have strait cut gears that are designed to last, makes it loud and tough to shift sometimes, its better if you dont hold the brake.
2018 pioneer 700m2 terra 45, mud lite II
recent previous
2016 570 outty max 27 mudlite xtr
2006 660 Rhino 27 mega mayhems
2003 650 Prairie mud lites(sold)
2008 700r Raptor se razrz
2006 360 full skids winch
VTwinKawi is offline
post #3 of 22 Old 08-28-2018, 01:39 PM Thread Starter
Really? Good to know. Thought I had some issues with my brute and was worried it was broken. Only atv I have used before this was my Linhai that I had before the brute. It was never hard to change gears in it, but then again it felt like a toy compared to the brute and I was always worried I would break it.
post #4 of 22 Old 08-28-2018, 04:41 PM
Feedback Score: 2 reviews
dman66's Avatar
Are you saying it needs to be forcefully placed in gear - that aint right . It should go in gear easy - it might make a slight clink clink noise going into gear, but it should go in easy without rocking. If you idle is turned up too much on a carbed brute, grinding may happen when placing it in gear if it will go at all. Also you may want to check to see if the front and rear motor mounts are good and tight as well.
05 Brute 750i Stock engine/ Muzzy Pro exhaust,Dynatec cdi,Vision Bruiser 14" wheels, 26" Bear Claw HTR Tires,3" intake snorkle - restricted,2" CVT snorkles,10" electric fan with custom mount,Mr Gasket Fuel Pump ,rejetted at #42 pilots, 3 out on A/F screws,stock needles shimmed .030",# 168/# 168 main Jets
dman66 is offline
post #5 of 22 Old 08-28-2018, 06:32 PM
kickstart's Avatar
As Dman says, it should go into gear easy. No rocking required. I've never once had to rock mine to get it into any gear.
2005 Prairie 732cc Team Green Special Edition
Wiseco pistons
2015 BF750 camshafts
Warn winch/Amsteel Custom Splice synthetic winch rope
Maxxis VIPR tires/12" DWT Rattlesnake wheels
Twin Air filter/TPI air box vent valve
Powermadd Star series handguards/Symtec Heat Demon grips
Adjustable Progressive front springs
VFJ adjustable clutch weights
EPI pink primary/VFJ #1 secondary
QuadBoss 8" sound tube
8" Cree LED bar/LED Underglow kit
Custom RCM shift knob
DYNATEK CDI
kickstart is offline
post #6 of 22 Old 08-29-2018, 01:42 AM
VTwinKawi's Avatar
had to any time its flat, same with the outlander, not serious rocking just moving my body. had both from new
recent previous
post #7 of 22 Old 08-29-2018, 08:06 AM Thread Starter
Just tried to change gear without staring the brute and same issue. Wont change gear unless i rock the atv... Weird.
post #8 of 22 Old 08-29-2018, 09:19 AM
kickstart's Avatar
Quote:
I have ridden a Can Am Outlander 650 G1, an 800 G1, and a 1000 G2. None of them required rocking to shift them into gear. The 1000 sometimes popped hard once throttle was applied, but it was never hard to move the lever into the range I wanted. The shift linkage probably needed some adjustment on that particular quad.
If your Can Am and Kawie require rocking to shift, then something is wrong with them. They are not supposed to be hard to shift. You should be able to do it with one finger.
Wiseco pistons
DYNATEK CDI
post #9 of 22 Old 08-29-2018, 10:35 AM Thread Starter
Here is a video of changing gear while atv ain't running. It acts exactly the same while running. When camera moves it's me rocking the brute.
https://youtu.be/ziERcoZQkGU
post #10 of 22 Old 08-29-2018, 02:24 PM
dman66's Avatar
How about a video of while its running ?
Your shifting while not running is normal to have to rock it to get the gears to mesh in the right spot.
While the engine is running, you should not be rocking it to get it into gear at all. This points me in the direction that your motor mounts could be loose causing the slightest play in the transmission gear selector rod to make it out of adjustment.
So did you buy the quad used and this is what you have, or was the quad always yours and did this just start ?
You need to check the motor mounts first. Place the rear parking brake on, and rock the quad forward and reverse while watching the engine for movement. If there is no movement, and you insured that all the motor mounts are tight, then you can try adjusting the tie rod in between the shifter and the trans selector. Loosen up both tie rod lock nuts, and turn the tie rod until you have the shifter sitting good in each gear position, while the engine is running. You only usually need to move the tie rod like maybe 1/16th to an 1/8th of a turn in either direction, so mark the rod and a stationary point at the gear selector. Get the adjustment wrong, and you can blow out the trans gear bearing by your left leg while in a hard throttle launch. This adjustment will require lots of patience, and may take a couple of tries till its right.
dman66 is offline
2004 prairie 700 vs 2006 brute force 650i messaman99 Kawasaki Brute Force/Prairie/Bayou 7 04-29-2013 03:52 PM
Brute Force 750 Checked Drive Belt, Now Having Problems!!!! Mods Recommendations??? camobruteforce75009 Kawasaki Brute Force/Prairie/Bayou 0 02-27-2010 12:51 AM
Brute force rear final gear serious issue Jankha Kawasaki Brute Force/Prairie/Bayou 6 11-13-2009 05:17 PM
06 brute force 650i with clicking in front end dayle Kawasaki Brute Force/Prairie/Bayou 4 08-10-2009 01:46 PM
Grizzly!!! maybe Kawasaki Brute Force/Prairie/Bayou 202 02-08-2005 10:21 AM
