Oil leak behind belt - Kawasaki ATV Forum
post #1 of 16 Old 04-07-2019, 07:20 PM Thread Starter
Hi all. I was changing belt today and saw there was some wetness behind the drive clutch. Took off the plate off and saw evidence of oil leak. Can't tell if it's leaking from the chain timing window or the crank seal.
I think i will just replace them both, but I tried to remove the window and it won't budge. Any tricks to it?
How bad is the crank seal to replace?
Thank you.
DESERTDRIFTER is offline
post #2 of 16 Old 04-07-2019, 07:22 PM Thread Starter
Trying to get some pics up but it says I need five posts first.
post #3 of 16 Old 04-07-2019, 07:23 PM Thread Starter
Post number 3
post #4 of 16 Old 04-07-2019, 07:24 PM Thread Starter
Post number4
post #5 of 16 Old 04-07-2019, 07:24 PM Thread Starter
Post number 5
post #6 of 16 Old 04-07-2019, 07:28 PM Thread Starter
This is what it looked like. Any guesses which one is leaking?
post #7 of 16 Old 04-07-2019, 07:54 PM
NMKAWIERIDER's Avatar
A little hard to tell but get it all cleaned up first...and check that oil line. They have O-rings that are known to fail. The book will tell you how to get that window out but I would blast it down reel well with carb cleaner and run some RTV red around the outside edge then wipe the excess off. Did that with my leaking cam plugs..worked just fine. The crank seal is pretty easy. A puller would be nice but whatever you do..do not scratch the case.
06 BF 750(SOLD)
15 Z Force 800 EPS
My Videos on YouTube
NMKAWIERIDER is offline
post #8 of 16 Old 04-07-2019, 08:20 PM Thread Starter
Quote:
The oil line is completely dry all around it. I am sure it's not leaking.
A search said thread bolt in window and pull straight out. Not on mine! I put vise grips on the bolt and pulled with all my weight and it didn't move at all. I think I might just do the rtv trick and call it good. But I think the crank seal is the real issue. I want to do it right.
post #9 of 16 Old 04-08-2019, 05:18 AM
rubiranch's Avatar
Quote:
Originally Posted by DESERTDRIFTER View Post
I think I might just do the rtv trick and call it good. I want to do it right.
2014 750i EPS
9002 miles
775.3 hours
average speed to date: 11.61 mph
average speed last ride: 9.20 mph
Tow Mater approved rear view mirror
rubiranch is offline
post #10 of 16 Old 04-08-2019, 09:30 AM Thread Starter
Quote:
You quoted me out of context. There was another sentence in there. I want to do the crank seal right without buggering up the case.
drive belt broke n big oil leak kfx900rhino Kawasaki KFX700 V-Force 5 05-28-2014 02:20 PM
Prairie Problems jaybird4th Kawasaki Brute Force/Prairie/Bayou 13 01-20-2013 10:58 AM
HELP!! 02 650 4wd not working, smokes, sputters HogWild Kawasaki Brute Force/Prairie/Bayou 11 09-04-2009 05:14 AM
Kawie KVF 360 A1 Excursion Everything Else 11 07-15-2008 11:24 PM
P700 Belt Drag Times on Asphalt Mikeyboy_esq Kawasaki Brute Force/Prairie/Bayou 1 09-24-2003 08:36 PM
