So my brute was sputtering out at mid throttle so I put a brand new fuel pump on it, then I put everything back together went to start it and the injectors were not pumping fuel, I pulled the line off and the pump is working and fuel is getting to the injectors. I bought a used throttle body and I still have the same problem. IT is getting fire and if you pour gas down the throttle body it will start for a second. I am very lost and have no clue what to do now and I can only find threads about this for the older models but nothing 2012 or newer. Please Help!!!
