04 prairie 700 leaking carb - Kawasaki ATV Forum
post #1 of 9 Old 04-10-2019, 03:33 PM Thread Starter
I’ve had 2 different mechanics look at and rebuild the back carb on my prairie 700 and fuel still leaking from only one screw in bottom of carb bowl any suggestions on what problem might be everything is new in the carb
post #2 of 9 Old 04-11-2019, 02:02 AM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
Which screw? The carb drain? Rebuilding won't do anything for a leaking screw.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is online now
post #3 of 9 Old 04-12-2019, 04:47 AM Thread Starter
Any advice on fixing the leak would be appreciated it’s one screw in bottom of back carb where fuel seems to be coming from I put a rubber washer in front of the screw and it slowed it down to small dribble what could be causing this thanks
post #4 of 9 Old 04-12-2019, 06:56 AM
Post a photo. it would really help to identify your leak.
'05 Prairie 700
DynaTek CDI, Full Muzzy (VFJ), VFJ #1 primary and #1 secondary springs, NAPA hose mod, plug wire mod, '13 BF750 cams, 1" wheel spacers, Ricochet skids, 3000lb Viper Max winch
'09 Brute Force 750i
MSD FI (VFJ), Muzzy Pro (VFJ), VFJ #1 primary and #4 secondary springs, 1" wheel spacers, 3000lb Viper Max winch, Full HDPE skids
'15 Brute Force 750i (non-EPS)
Full HDPE skids, Viper Max 3500lb winch, 1" wheel spacers, VFJ #6 primary and Venom gray/yellow secondary springs
windriver is offline
post #5 of 9 Old 04-12-2019, 08:11 AM
NMKAWIERIDER's Avatar
Yeah we need to see what "screw" it is.. Is it a bowl retainer? Is it the drain? Is it the A/F...so post a photo.
06 BF 750(SOLD)
15 Z Force 800 EPS
My Videos on YouTube
NMKAWIERIDER is online now
post #6 of 9 Old 04-13-2019, 04:37 AM Thread Starter
It is the bowl retainer screw that’s leaking
post #7 of 9 Old 04-13-2019, 07:43 AM
Quote:
Those screws don't go into the fuel chamber (as I recall) and the bowl O-ring inside of that. The only way they can leak is if there is a crack or...the O-ring isn't sealing because of a warped bowl..which can happen when the retainers get over tightened. Pull the bowl and check all the surfaces with a straight edge for a warp. the ears will be where it is..probably. If so you will need to fix that. I would get some 1000 G paper on some glass and mill it all flat. Go easy if you do.
06 BF 750(SOLD)
15 Z Force 800 EPS
post #8 of 9 Old 04-14-2019, 04:25 PM Thread Starter
Thanks for the advice however I think the repair is beyond me so to make sure it’s fixed right I took my prairie to the local Kawasaki shop what’s so strange about this problem it started when I first started it up after parking it for the winter I even treated the fuel before parking it thanks again
post #9 of 9 Old 04-17-2019, 04:43 PM
Garage
Following
I have a leak also that is DUMPING fuel from the carb area of my 650. Iíll follow along for ideas here.
Please continue...Iím here for the comments. 🍿
Plwanker is offline
2002 Prairie 650 4x4 and the mystery hole in the carb. BDuke Kawasaki Brute Force/Prairie/Bayou 15 01-21-2019 04:55 AM
Kawasaki Prairie 360 gas leaking from carb hose randyesq Kawasaki Brute Force/Prairie/Bayou 6 05-20-2018 10:50 AM
Super NASTY Carb on 2003 Prairie 650 myridge Kawasaki Brute Force/Prairie/Bayou 17 05-14-2018 01:44 AM
Super NASTY Carb on 2003 Prairie 650 myridge Kawasaki Brute Force/Prairie/Bayou 0 05-07-2018 10:40 AM
Prairie 360 replacement carb? EMK Kawasaki Brute Force/Prairie/Bayou 0 06-04-2014 05:57 PM
