01 prairie problems - Kawasaki ATV Forum
post #1 of 3 Old 04-12-2019, 04:28 PM Thread Starter
01 prairie problems
My 01 prarie wonít operate at full throttle, you and crack it down or ease into it, as long as you donít it full throttle, it will sputter down then cruise at about 20. It canít be the carb, I just bought and put the new one in yesterday, and the old carb had the same problem but worse. Itís been sitting for about 3 years, and only has 400 miles. What could be the problem?
Doyle Haley is offline
post #2 of 3 Old 04-12-2019, 08:26 PM
In no specific order
Make sure the throttle stop screw is not prventing full throttle oerstion
Make sure it has fresh fuel
Make sure tank is clean
Make sure petcock flows fuel, freely
Did you replace with oem carb?
How old is the belt? If it is original, it is very old. I would replace it.
Shouldnt be the clutches but make sure they move freely. Not certain how to do that. Maybe place machine on 4 jackstands and run the trottle to see if clutches open and close smoothly. You will need to remove belt cover to do this.
Make sure brakes are not dragging
Make sure front brake fluid has been changed within the last 5 years and that there are no air bubbles which will expand when hot and cause the pads to engage the discs
Coldfinger is offline
post #3 of 3 Old 04-13-2019, 04:00 AM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
Have you owned this all along, or did you buy it as is?
Fuel delivery. Make sure it's getting gas to the carb.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
Tags
2001, 300, 4x4, prarie, problems
2007 prairie 360 wheels problems auto4x4 Kawasaki Brute Force/Prairie/Bayou 1 12-12-2017 09:50 AM
Problems with my 2003 Prairie tprman Kawasaki Brute Force/Prairie/Bayou 15 09-21-2016 10:59 PM
Prairie 650 couple little problems Camojake Kawasaki Brute Force/Prairie/Bayou 16 11-04-2015 05:47 PM
Buying New ATV in a month...help WVatvRider Kawasaki Brute Force/Prairie/Bayou 14 08-22-2004 06:35 AM
Big problems w/ my Prairie? Adirondack Man Kawasaki Brute Force/Prairie/Bayou 22 08-06-2003 03:43 AM
