1997 Prairie 400 4x4 - Kawasaki ATV Forum
post #1 of 12 Old 05-23-2019, 02:49 PM Thread Starter
I have a 97 Prairie 400.
The problem I'm having is that it will not rev higher than a low rpm even in neutral. It doesn't sputter or anything it just tops out. When I put it in gear whether high or low it will only go at a slow speed, 10 mph or so. With throttle wide open it will keep a consistent speed without sputtering or coughing or anything, it just goes slow. If I go up a hill it loses power. This problem happened all of a sudden. I thought it might be the belt but that shouldn't cause the low rev in neutral, correct?
Any help would be appreciated. Thanks!
wvurider is offline
post #2 of 12 Old 05-23-2019, 07:09 PM
Throwing out some thoughts here based upon my 2000 Prairie 400 but havent had your issue.
Make sure the throttle stop screw behind the thumb throttle isnt limiting lever movement
Fuel starvation?
Run any different on reserve vs normal
Do you have an inline filter and is it flowing enough fuel
Is fuel line pinched
Drain float bowl and watch for anything odd coming out
Engine oil level ok, not too high
Fresh fuel
Main jet obstructed
Valves been adjusted recently
Do a compression test
Air filter clean
Coldfinger is offline
post #3 of 12 Old 05-25-2019, 05:23 AM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
Exhaust restricted?
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #4 of 12 Old 05-26-2019, 04:59 AM Thread Starter
Thanks!
I took the belt cover off and started it up. It did seem to rev at a higher rpm and the clutch moves in all the way. I'm thinking it needs a new belt. This atv sat for a long time and had a lot of parts replaced but it doesn't appear that the belt cover was ever removed.
wvurider is offline
post #5 of 12 Old 06-01-2019, 04:38 PM Thread Starter
The clutch will move in all the way when in neutral but once the transmission is engaged it stays out. Any help?
wvurider is offline
post #6 of 12 Old 06-01-2019, 06:39 PM
Feedback Score: 2 reviews
dman66's Avatar
How high is the belt in the secondary sheaves ? The top of the belt should be flush with the top of the pulleys or a little higher than the sheaves. It may be possible that the width of your belt is very worn ?
05 Brute 750i Stock engine/ Muzzy Pro exhaust,Dynatec cdi,Vision Bruiser 14" wheels, 26" Bear Claw HTR Tires,3" intake snorkle - restricted,2" CVT snorkles,10" electric fan with custom mount,Mr Gasket Fuel Pump ,rejetted at #42 pilots, 3 out on A/F screws,stock needles shimmed .030",# 168/# 168 main Jets
dman66 is offline
post #7 of 12 Old 06-02-2019, 04:06 AM
NovaKaw650's Avatar
Garage
Quote:
The clutches shift normally when in neutral, as in the primary clutch closes and the secondary fully opens?
Once in gear they don't move? You must have all four wheels jacked up when doing this test?
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
post #8 of 12 Old 06-02-2019, 05:16 AM Thread Starter
Not on jacks. I have the belt cover off. When in neutral the primary clutch will move in when rpms increase. When transmission is in gear (doesn’t matter which gear) the transmission engages properly and the driven pulley stops spinning. When i increase throttle the atv moves forward at a very slow speed engine stays at low rpm and primary clutch does not move in.
wvurider is offline
post #9 of 12 Old 06-02-2019, 06:08 AM
NovaKaw650's Avatar
Garage
If it's moving ahead, then the primary clutch had to move in against the belt.
If the engine won't rev up, then you have an engine problem. Check to be sure the throttle and slide is opening in the carb when you open the throttle while it's running.
If the engine revved up, you might have a clutch problem.
A video would be extremely helpful.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
post #10 of 12 Old 06-02-2019, 04:15 PM Thread Starter
I've really tried my best to post video all day and I can't without 5 posts. So here's my fifth post and I'll try again after this.
wvurider is offline
Axle nut on 1997 Prairie Markthemailman Kawasaki Brute Force/Prairie/Bayou 5 11-05-2016 03:13 PM
How to tell if the water pump is working 1997 Prairie 400 Shadallark Kawasaki Brute Force/Prairie/Bayou 1 07-14-2014 05:41 PM
1997 Prairie 400 4 X 4 clutch setterhills Wanted 0 06-27-2014 08:00 AM
1997 Prairie back brakes Need help ricky b Kawasaki Brute Force/Prairie/Bayou 1 10-20-2009 01:02 PM
1997 Prairie 400 4x4 - Side Panel Removal prarie97400 Kawasaki Brute Force/Prairie/Bayou 2 08-21-2009 09:38 AM
