Oil pump dots? - Kawasaki ATV Forum
post #1 of 15 Old 07-06-2019, 01:16 PM Thread Starter
kickstart's Avatar
Oil pump dots?
I am getting ready to put my Prairie back together. I decided to order new rotors for the oil pump because I figured I might as well while I'm in there, and they're only $5 bucks each. Anyhow, I see both rotors have a dot machined into them. Service manual does not say anything about them, nor does the photo show them. The rotors appear symmetrical, and I can't see how one side would need to be installed in any certain direction. Anyone know the story on these dots?
2005 Prairie 732cc Team Green Special Edition
Wiseco pistons
2015 BF750 camshafts
Warn winch/Amsteel Custom Splice synthetic winch rope
Maxxis VIPR tires/12" DWT Rattlesnake wheels
Twin Air filter/TPI air box vent valve
Powermadd Star series handguards/Symtec Heat Demon grips
Adjustable Progressive front springs
VFJ adjustable clutch weights
EPI pink primary/VFJ #1 secondary
QuadBoss 8" sound tube
8" Cree LED bar/LED Underglow kit
Custom RCM shift knob
DYNATEK CDI
kickstart is offline
post #2 of 15 Old 07-06-2019, 02:49 PM
My 400 service manual says nothing. Google search turned up a few sources that said they are sort of alignment marks, but only in the sense that you want to maintain the original alignment of existing parts, like if both dots face out, reinstall with both dots out. If one dot faces in and the other out, reinstall the same way.
This is because the gears wear together and if you reverse one after disassembly, the fit will be compromised and probably not be as efficient and wear faster. Maybe similar to installing a drive chain sprocket in reverse after it has wear, the engagement of sprocket and chain will not be the same.
In this case, because you are replacing both and the dots of the new assembly are on the same side, I would install them with the dots on the same side. I am guessing you will have both facing outward.
Coldfinger is offline
post #3 of 15 Old 07-06-2019, 03:49 PM
NMKAWIERIDER's Avatar
I always assumed...and yes, I know,.. that a the two rotors are designed to bring oil in one side and force it out the other and that requires the rotor mesh cuts to be tapered slightly in one direction.. so it is important that not only are the dots on the same side, but the rotor accembly is facing the correct direction. That might be 100% wrong...so, just put the new ones in the same way as the old ones came out and you should be good..
06 BF 750(SOLD)
15 Z Force 800 EPS
My Videos on YouTube
NMKAWIERIDER is offline
post #4 of 15 Old 07-06-2019, 07:58 PM Thread Starter
kickstart's Avatar
That's kind of what I was thinking. Reference marks. If they were more than that, or directional, you'd think Kawasaki would be very descriptive about them.
Wiseco pistons
DYNATEK CDI
post #5 of 15 Old 07-06-2019, 08:07 PM Thread Starter
kickstart's Avatar
Quote:
That's wherein the problem lies.....
I unbolted the whole pump and immediately put it into a ziplock bag to keep it clean. Next day, went to get it out of the bag and the outer rotor fell out into the bag before I got to see where the dot was. Inner rotor is circlipped to the shaft, and it had the dot facing inside the engine. So I just installed the new rotors both with the dot facing in. Hope it works!
I did fill it up with oil and played around with it before I installed it. Seemed to squish oil out the same whether it was dots in or dots out.
Wiseco pistons
DYNATEK CDI
post #6 of 15 Old 07-06-2019, 09:16 PM
Fingers are crossed..
06 BF 750(SOLD)
15 Z Force 800 EPS
post #7 of 15 Old 07-06-2019, 11:40 PM Thread Starter
kickstart's Avatar
Well, I just watched three videos of kawasaki oil pumps being removed, and all of them had the dot on the outer rotor facing the engine and the inner rotor dot was facing the inside of the cover. Wth.....
Wiseco pistons
DYNATEK CDI
post #8 of 15 Old 07-07-2019, 04:23 AM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
Look at the old ones to see if they are truly symmetrical. If they are, it doesn't matter. If there's no reference in the manual, it likely doesn't matter.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #9 of 15 Old 07-07-2019, 06:47 AM
Quote:
Yeah, if it was that critical Kawasaki would have referenced it in the manual for sure.
06 BF 750(SOLD)
15 Z Force 800 EPS
post #10 of 15 Old 07-07-2019, 10:18 AM Thread Starter
kickstart's Avatar
Seems odd to put ref marks on it, but then not put them both on one side....
I think I better pull it off and mic them.
I ran a search on it, but nothing came up. Hard to believe I'm the only guy in the 17 year history of this engine that's ever wondered how this thing is supposed to be installed.
Wiseco pistons
DYNATEK CDI
