Kawasaki ATV Forum
Kawasaki ATV Forum (https://www.kawieriders.com/forum/)
-   Kawasaki Brute Force/Prairie/Bayou (https://www.kawieriders.com/forum/kawasaki-brute-force-prairie-bayou/)
-   -   Fuel pump pressure (https://www.kawieriders.com/forum/kawasaki-brute-force-prairie-bayou/90898-fuel-pump-pressure.html)
LAVRx 10-31-2009 10:18 AM
Fuel pump pressure
Hello!
I have n problem with my Kawasaki Brute Force 750i 4x4 2008year. I already changed fuel pump, because ATV was loosing power. When I started ATV it works ok, bet when i ride ATV for about 15 minutes it starts to loose power. Also there was an really loud shots from exhaust. So I and mechanics though it was fuel pump problem, but when I changed fuel pump problem still stayed.
So we think that there is an problem with fuel pump pressure, maybe someone knows optimal fuel pump pressure. We can measure pressure, but we don't know the right pressure to compare it.
I'm newbie in this forum and sorry if this isn't the right place to write this thread, and also sorry for my English.
BRICKLAYER 10-31-2009 10:48 AM
Im not 100% sure but im pretty sure there is a vacuum valve that comes off the fuel pump that is supposed to control the pressure. it is bolted right beside the fuel pump. check that. i was told if you take it off and blow through it its faulty but i could be wrong it might actually need pressure to opperate.
LAVRx 10-31-2009 11:08 AM
Yes i've checked that valve and i can blow through one side, but could not blow through other side.
greasemonkey 10-31-2009 05:05 PM
Usually when the engine fires out the exhaust it is either running too rich , the timing is retarded, or the valves are too tight.Check the color of the spark plugs to see if it is rich.For the timing to change enough for it to backfire it would be something electrical like the ignition module.And lastly if the valves are tight, they will get tighter when everything is hot and expanded.I hope this gives you a direction to start looking.
08GREENBRUTE 10-31-2009 09:16 PM
could be wrong here but i thought if it was backfiring it was running lean
greasemonkey 11-01-2009 06:17 AM
Quote:
Backfiring out the exhaust is rich condition.Popping out the carbs is a lean condition.
LAVRx 11-02-2009 04:33 AM
Thanks for info! I'll check thing you mentioned.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
