Common Mechanical Problems of the KFX 700 - Page 6 - Kawasaki ATV Forum
post #51 of 56 Old 06-08-2015, 02:30 PM
dunerider1976's Avatar
Not the usual problems but I can't be the only one.
So, not a common problem but....the other day I was changing out the jets on my 2006 KFX for the what seems like the 100th time, to get the right fuel mixture, when one of the bolts I had in my hand dropped down this small hole in the air box. The tube attached to the hole is an "Air Vent" that goes right down into the crankcase. I checked the tube and it is not there. Next step drain the oil and see if the bolt comes out with the oil. Has anyone out there had to open the crankcase before? I head out for Florence, OR in a week and really don't want to ride my kids 250.
The other issue is it stuck in the reducer from the tube into the crankcase. Even with my small hands I can't get in there to take a look.
dunerider1976 is offline
post #52 of 56 Old 06-08-2015, 03:38 PM
Try to get down there with a magnet. Might get lucky.
'08 Trailblazer SS black/black
'15 GMC Sierra SLT
'06 Brute 650sra
FST665, FST Cams, Full Muzzy, Innovate WideBand, Dyna CDI, 14-Hole MOD, Almond Secondary, No-Toil Super Flow, 27" Zilla's, Rox Handle Bar Kit, Progressive Springs, Elka Rear, Bigger Radiator, SPAL Fan, Temp Gauge
jg650 is offline
post #53 of 56 Old 06-10-2015, 12:51 PM
Feedback Score: 24 reviews
twyztid's Avatar
We had that happen to a friend's bike. It doesn't go all the way down. There are bosses inside the path that keep it from reaching the bottom. He was able to suck it out of the tube with an air-powered vacuum.
'04 KFX800
DSC 12:1 Pistons w/ Stg 2 cams, Ported Heads, 36mm carbs, Muzzy Super Pro, Dual MTX-L, VFJ Stg 3 Spidermod Clutch & Adj. Weights, +8 Swing Arm, Elka Shocks, 24" 14-paddle Staggered SLS Ripper paddles, BOSS NOSS 40-shot
'04 KFX730
Custom 84mm 12:1 JE Pistons w/ FST Stg 2 cams, Muzzy Super Pro, UPP Crossover Intakes, 8* Timing Key, Elka Shocks, +4 Swing Arm Extension, 24" 10-paddle Skat-Trak Extremes
'04 KFX730
Wiseco 84mm 11.5:1 Pistons w/ Fundy Trail/Race cams, Muzzy Super Pro, Crossover Intakes, 6* Timing Key, Works front & Elka Rear Shocks, +4 Swing Arm Extension, 24" 9-paddle Skat-Trak Extremes
'05 BF730 SRA
'04 Prairie 700
twyztid is offline
post #54 of 56 Old 07-01-2015, 09:06 PM
I adjusted the valves on mine a corroding to what the mannual said. A friend of mine also has a kfx 700 and he said the valves are bad about tightening theirselves up. So I did mine to the higher number in the range to adjust them. When I started it, the four wheeler started making a ticking noise. Should I just run it and wait for it to go away or try to fix it
Cole is offline
post #55 of 56 Old 05-14-2017, 11:35 PM
I just bought mine, im glad to see this...
ctp123 is offline
post #56 of 56 Old 05-25-2017, 09:04 AM
looking for a KFX 700
howdy folks, I've been looking for a KFX 700 for my wife and it seems every one one in my area for sale is an 04. I keep reading about the rocker shaft failure on the 04 models and I'm wondering if I should avoid them altogether? should I look at 06+ models? or is the rocker mod easy to fix, I saw that a member "Nathan" would do the mod, can anyone provide me his contact info? It won't let me send PM's yet. I appreciate any help and insight anyone can provide.
krossroads8601 is offline
looking at a 09 brute force 650i any common problems or concerns? kenton15 Kawasaki Brute Force/Prairie/Bayou 16 07-26-2011 08:01 PM
3 mechanical problems occured on yesterday's trail ride Mikeyboy_esq Kawasaki Brute Force/Prairie/Bayou 8 04-18-2011 06:06 AM
coolant low - is this common? [email protected]*[email protected]+ Kawasaki KFX700 V-Force 1 08-10-2010 11:47 AM
Common Tools and what they do RANDALLPINK7 Club Kawie 15 06-30-2010 08:16 PM
The Links to the Most Common Modifications The Speed Force Kawasaki KFX700 V-Force 24 06-07-2010 08:03 PM
