Very hard starting - Kawasaki ATV Forum
post #1 of 6 Old 06-28-2018, 08:31 PM Thread Starter
Feedback Score: 12 reviews
VENFORCER's Avatar
Very hard starting
I’m running a 800 BBC with stage 3 cams. Crossover intakes. CBR 36 mm carbs. It has always been very hard to start cold with the 36 mm carbs. Rocker lash is set correctly. Pilot jets are clear. Full choke doesn’t help.
Any suggestions would be appreciated.
2004 Green KFX 700, Boss Nos(30 shot), FST 803, stage 3 cams, AMR ported heads, 36mm carbs, My +7" cut and weld swinger, My 6 pack rack grab bar, My Manta dash, Stadium shocks front and rear, LTE exhaust, Razer 2 tires, IMS front bumper. My radiator guard. My 14mm stainless steel tie rods. ODI grips, Honda throttle, My stainless steel pegs, My billit stator cover.
www.atvtrickstuff.com
VENFORCER is offline
post #2 of 6 Old 01-25-2019, 01:36 PM Thread Starter
VENFORCER's Avatar
I have your exact same set up. It has always been hard to start when cold. If my battery is at 100% charged it starts a lot easier. Also make sure you have fresh 93 octane in the fuel tank.
post #3 of 6 Old 01-25-2019, 01:40 PM Thread Starter
VENFORCER's Avatar
That was stupid. I just answered my own post. I found out that the battery was most of the problem.
post #4 of 6 Old 01-26-2019, 05:05 AM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
I know this is old, but do you still have compression releases on the cams?
They start way easier with full compression.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #5 of 6 Old 01-26-2019, 09:37 AM Thread Starter
VENFORCER's Avatar
I removed them when I did the 800 kit
post #6 of 6 Old 01-27-2019, 05:22 AM
VTwinKawi's Avatar
hard starting after battery and plugs is low speed carb jet too lean. dont know that carb but needles or idle air mix is too lean
2018 pioneer 700m2 terra 45, mud lite II
recent previous
2016 570 outty max 27 mudlite xtr
2006 660 Rhino 27 mega mayhems
2003 650 Prairie mud lites(sold)
2008 700r Raptor se razrz
2006 360 full skids winch
VTwinKawi is offline
Pro FX Hard Cab weight NWPATim Kawasaki Mule 3 07-16-2016 07:33 PM
650 i hard starting trigger Kawasaki Brute Force/Prairie/Bayou 15 03-17-2014 05:27 AM
Hard starting Brute cmartin248 Kawasaki Brute Force/Prairie/Bayou 2 02-21-2011 05:45 PM
hard starting 05 BF mjet Kawasaki Brute Force/Prairie/Bayou 2 01-06-2010 06:27 AM
Hard starting after engine gets hot Eforce13 Kawasaki KFX700 V-Force 24 03-10-2008 04:02 PM
