carb rebuild issues HELP Please - Kawasaki ATV Forum
post #1 of 8 Old 11-08-2018, 03:20 PM Thread Starter
I took the carbs apart and installed new rebuild carb parts, jets, etc. after putting the carbs back onto the inlets it will only start if I have the throttle wide open and then it is rough and the butterflys are not moving.
I am sure with all the knowledgeable individuals on this site that someone has run into this problem and can help me resolve it.
Thank you
Ron
billsinca is offline
post #2 of 8 Old 11-09-2018, 01:40 AM
VTwinKawi's Avatar
rebuild kits make them run terrible, if you have crapped up carb you have to clean and pick out the originals and use oem
what was the original problem
2018 pioneer 700m2 terra 45, mud lite II
recent previous
2016 570 outty max 27 mudlite xtr
2006 660 Rhino 27 mega mayhems
2003 650 Prairie mud lites(sold)
2008 700r Raptor se razrz
2006 360 full skids winch
VTwinKawi is offline
post #3 of 8 Old 11-09-2018, 06:24 AM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
By the butterfies not moving, are you referring to the slides?
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #4 of 8 Old 11-09-2018, 07:24 AM Thread Starter
Yes. The slides are not moving. I had issues starting the quad when it was cold, it would take a lot to get it started so i changed out the jets.
I will change out the jets back to original and see if that helps
post #5 of 8 Old 11-10-2018, 05:04 AM
VTwinKawi's Avatar
have to clean those too, there is a barrel for vacuum and the seals have to be perfect if either one of those is in the wrong spot the things wont slide. it should be fairly to move with you fingers and go back all the way slowish if not something wrong with the vacuum in that area
make sure you clean and reuse the oem jets, you will introduce running issues if you use rebuild kit ones
recent previous
post #6 of 8 Old 11-13-2018, 07:49 AM Thread Starter
took the tops off and adjusted the baffales, now they are working correctly but it will not idle, idle adjustment is all the way in and the cable all the way out. is there another adjustment for the idle?
post #7 of 8 Old 11-13-2018, 01:01 PM
VTwinKawi's Avatar
idle mix screw on the side of each
recent previous
post #8 of 8 Old 11-15-2018, 06:25 AM
auburn6887's Avatar
piolet jets
replace the pilot jets with a new set
auburn6887 is offline
Carb issues ... remington100 New Member Introductions 0 10-08-2017 02:08 PM
Carb Rebuild Kit and Fuel Probs? ehoward58 Kawasaki Brute Force/Prairie/Bayou 3 09-14-2016 02:20 PM
carb rebuild ryah21 Kawasaki Mojave/Lakota 3 02-13-2012 05:45 PM
Carb rebuild Steve30 Kawasaki Mojave/Lakota 57 01-31-2012 07:00 PM
More Carb Issues ? jjs3788 Kawasaki Brute Force/Prairie/Bayou 0 09-26-2011 06:53 PM
