2012 Brute 750 starting Issues - Kawasaki ATV Forum
post #1 of 9 Old 02-04-2019, 10:17 AM Thread Starter
I recently bought a 2012 brute 750i with EPS. For some reason i have to give it some gas to crank. I cant just hit the green start button. Also when its running it seems like the engine idle is low. To low for me. I replaced the spark plugs on both heads and cleaned out the air filter. The previous owner only ran the bike in WV trails so he had put some grease all over the filter and I think it was struggling to get air.
Some people have said it could be valves. The bike runs strong and good. I have never owned a EFI bike that you could not just hit the start and it crank. Someone also mention I could adjust the idle also. Im trying to avoid taking it to the dealer. Any and all help will be appreciated. Thanks
12CamoBruteNasty is offline
post #2 of 9 Old 02-04-2019, 10:25 AM
NMKAWIERIDER's Avatar
Always go through all the basics first like valve lash, air filter, fuel supply, voltage testing along with connections. Then for a situation like yours I would test the TPS and idle-air systems.
06 BF 750(SOLD)
15 Z Force 800 EPS
My Videos on YouTube
NMKAWIERIDER is offline
post #3 of 9 Old 02-04-2019, 11:30 AM Thread Starter
How do you test the TPS and idle air system?
post #4 of 9 Old 02-04-2019, 11:44 AM
Quote:
All is covered in the service manual. Here:
https://files.acrobat.com/a/preview/...5-c5d63cf8e194
06 BF 750(SOLD)
15 Z Force 800 EPS
post #5 of 9 Old 02-04-2019, 12:24 PM Thread Starter
thats what I was looking for Thank you!
Also im changing the oil and wanted to Run T6 10w40 Rotella. It is better on dino oil or synthetic Thanks
post #6 of 9 Old 02-05-2019, 07:57 AM Thread Starter
still no luck. I removed the idle air unit and took it apart it was pretty clean all expect the end of it. I wiped it off. No luck. It still requires me to give it gas to start.
Any ideas ?
post #7 of 9 Old 02-05-2019, 08:46 AM
How did the TPS test-out? Have you checked the boots for cracks? How about the valve lash?
06 BF 750(SOLD)
15 Z Force 800 EPS
post #8 of 9 Old 02-05-2019, 01:28 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
Did you clean the grease out of the filter, like really clean it out? I wouldn't count on a water based cleaner to cut through it if it was really slopped on.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #9 of 9 Old 02-07-2019, 06:57 AM Thread Starter
yes i had to soak in gas to clean. They I let it air out over night
bike def runs better but still wants to go to low idle when coming to a stop. I think ill order a Idle air contoller. Its like 100.00 and easy to put on
2012 Brute Radiator Issues gtsum2 Kawasaki Brute Force/Prairie/Bayou 9 12-10-2012 01:41 PM
Observations of my 2012 Brute over the last couple days mnchvgs79 Kawasaki Brute Force/Prairie/Bayou 46 11-21-2012 01:55 PM
2012 brute in bed of pick up Markdb Kawasaki Brute Force/Prairie/Bayou 24 09-06-2012 07:55 AM
Repaired CV BOOT on 2012 brute 750 blackje8884 Kawasaki Brute Force/Prairie/Bayou 14 04-27-2012 07:09 PM
2012 Brute Force 750 vs Other Big Bore ATVS blackje8884 Kawasaki Brute Force/Prairie/Bayou 10 04-10-2012 06:13 PM
