Compression check after rebuild - Kawasaki ATV Forum
post #1 of 5 Old 04-20-2019, 10:53 AM Thread Starter
N-gin's Avatar
So fin finally got the rebuild done on the KFX and I went to do a compression check and I found out that I have 125 psi in each cylinder this is before break-in.
this is a far cry from specs I think I read somewhere that it was 30 to 60 PSI. Cam timing is spot-on I did do a full rebuild with hot rods hot crank timing set and of course seals and gaskets. The heads have new valves and about .0050 cut off the surface, the Pistons are Numura Pistons stock bore stock cams. Seems to start fine with no issues of backfiring. I was just wondering is this normal for these engines and that the book I'm reading is wrong.
N-gin is offline
post #2 of 5 Old 04-20-2019, 10:59 AM
More is better, usually, 30-60 is very low
Dan Schultz is offline
post #3 of 5 Old 04-20-2019, 12:49 PM
NMKAWIERIDER's Avatar
That 30-60 is with the stock pistons, stock throw crank and stock cams with compression releases. You will be higher. What cams are you using...and do they have the comp releases? Nothing wrong with the 125 anyway.
06 BF 750(SOLD)
15 Z Force 800 EPS
My Videos on YouTube
NMKAWIERIDER is offline
post #4 of 5 Old 04-24-2019, 04:24 AM Thread Starter
N-gin's Avatar
Stock cams with releases.
The Pistons are stock bore replacements. Same goes for the crank and rods, all stock diamentions.
Runs great really snappy.
Now I'm wondering if I should have just thrown a set of cams (hotcam)at it.
N-gin is offline
post #5 of 5 Old 04-24-2019, 02:42 PM
Feedback Score: 24 reviews
twyztid's Avatar
Hot Cams are a waste of money & no real gains.
Sent from my LM-G710VM using Tapatalk
'04 KFX800
DSC 12:1 Pistons w/ Stg 2 cams, Ported Heads, 36mm carbs, Muzzy Super Pro, Dual MTX-L, VFJ Stg 3 Spidermod Clutch & Adj. Weights, +8 Swing Arm, Elka Shocks, 24" 14-paddle Staggered SLS Ripper paddles, BOSS NOSS 40-shot
'04 KFX730
Custom 84mm 12:1 JE Pistons w/ FST Stg 2 cams, Muzzy Super Pro, UPP Crossover Intakes, 8* Timing Key, Elka Shocks, +4 Swing Arm Extension, 24" 10-paddle Skat-Trak Extremes
'04 KFX730
Wiseco 84mm 11.5:1 Pistons w/ Fundy Trail/Race cams, Muzzy Super Pro, Crossover Intakes, 6* Timing Key, Works front & Elka Rear Shocks, +4 Swing Arm Extension, 24" 9-paddle Skat-Trak Extremes
'05 BF730 SRA
'04 Prairie 700
twyztid is offline
Bayou 220 Rebuild Issues Acme54321 Kawasaki Brute Force/Prairie/Bayou 6 10-10-2012 07:43 AM
Fuel check valve leaking up by pod mn250r Kawasaki Brute Force/Prairie/Bayou 2 09-16-2012 03:31 PM
Motor has low compression..repair costs? bship123 Kawasaki Brute Force/Prairie/Bayou 1 01-28-2011 01:55 PM
HELP!! 02 650 4wd not working, smokes, sputters HogWild Kawasaki Brute Force/Prairie/Bayou 11 09-04-2009 05:14 AM
Compression Problems PRIME TIME Kawasaki KFX700 V-Force 5 05-17-2009 08:39 AM
