36mm Carb Jetting - Page 9 - Kawasaki ATV Forum
post #81 of 90 Old 04-03-2012, 10:47 AM
Feedback Score: 18 reviews
brute 840's Avatar
They are different for sure,and mine run better with the Factory Pro over the stockers for some reason I could get it right with stock needles,all these carbs a different and when modded like we do makes them act even Worse.
2012 TERYX
750 SPORT
2012 FX2 Super Crew F150
355 Gears Rear Locker
SCT X4 Tuner/Unleashed Tuning
Kicker Soundgate kit
Lowered
VAS Traction Bars
Wagner Intercooler
brute 840 is offline
post #82 of 90 Old 04-17-2012, 02:30 PM
Feedback Score: 24 reviews
twyztid's Avatar
I have a pair of stock needles now and they are a lot fatter at the tip than the other ones (Factory Pro?). I will probably try out the Factory Pro ones first.
'04 KFX800
DSC 12:1 Pistons w/ Stg 2 cams, Ported Heads, 36mm carbs, Muzzy Super Pro, Dual MTX-L, VFJ Stg 3 Spidermod Clutch & Adj. Weights, +8 Swing Arm, Elka Shocks, 24" 14-paddle Staggered SLS Ripper paddles, BOSS NOSS 40-shot
'04 KFX730
Custom 84mm 12:1 JE Pistons w/ FST Stg 2 cams, Muzzy Super Pro, UPP Crossover Intakes, 8* Timing Key, Elka Shocks, +4 Swing Arm Extension, 24" 10-paddle Skat-Trak Extremes
'04 KFX730
Wiseco 84mm 11.5:1 Pistons w/ Fundy Trail/Race cams, Muzzy Super Pro, Crossover Intakes, 6* Timing Key, Works front & Elka Rear Shocks, +4 Swing Arm Extension, 24" 9-paddle Skat-Trak Extremes
'05 BF730 SRA
'04 Prairie 700
twyztid is offline
post #83 of 90 Old 05-15-2012, 10:26 PM
Feedback Score: 1 reviews
Buck700's Avatar
Quote:
Originally Posted by twyztid View Post
I took one out and that is what it looked like to me as well. Be aware, I have used the 21-series pilots in stock carbs but they are actually just slightly different than the stock ones. The correct pilot jets for the stock carbs are the N424-74c series, not the N424-21 series.
So the mains and pilots are the same ones the stock kawasaki carbs use??
Or do the 36's use the -21 series pilot?
'04 BKP 800 (Mine) - Muzzy Super Pro - BKP Intakes - Ported - 36's - +6 Swinger - +2 Arms -Spark plug mod - Shorty Shifter - YZF & Predator Shocks - VFJ Stage 3 Clutch - 26" STU #2 Blasters SOLD!
'06 KFX 700 (Wifes) - 12 Hole Mod - Muzzy Super Pro - 450R Shocks - Spark Plug Mod - EPI Pink Spring - Crossover intake - #42 Pilots - 5/64" mains - 6 Degree key - 24" Extremes
Buck700 is offline
post #84 of 90 Old 05-16-2012, 05:57 AM
twyztid's Avatar
I think the 36's use the N424-21 series pilots.
'04 KFX800
'04 KFX730
'04 KFX730
'05 BF730 SRA
'04 Prairie 700
twyztid is offline
post #85 of 90 Old 10-06-2012, 05:34 AM
It wasnt the carbs at all, it was my porting that was messed up. Someone, (I'm not calling names) put my heads on a flow bench and then filled in the intake ports to make them flow better (higher #'s on that damn machine) and more even. So after that stuff was ground out of my intake ports it was fixed. I kinda new it wasnt the carbs or any tunning problems for that matter because I had been using the 36's before the problem and they worked perfect.
aakash is offline
post #86 of 90 Old 01-04-2014, 10:10 PM
Feedback Score: 2 reviews
bubbasoffroad2's Avatar
all i got is this thread hurts my head now i need a pillow and off to dream abut what its going to make squids bike run right
2008 fst 840 teryx
2004 V FST 800 stage 3 cams ported heads with stock valves 36 carbs muzzy super pro stock clutch for now elkas all around +1 herrmann stem Grannysmith green powercoated frame and silver vein pro armour nerfs, ODI rogue grips on trail tech bars Camo shifter race cut plastic with AC front bumper and PRM grab bar,
bubbasoffroad2 is offline
post #87 of 90 Old 01-04-2014, 10:27 PM
twyztid's Avatar
Is he running 36mm carbs? PM me, I may be able to help.
'04 KFX800
'04 KFX730
'04 KFX730
'05 BF730 SRA
'04 Prairie 700
twyztid is offline
post #88 of 90 Old 07-15-2014, 10:09 PM
yogie's Avatar
Stupid question time, dont laugh at me
Okay this is a stupid question, but I don't know. can Jets wear out or get stuffed ?
no laughing
not yet....
okay laugh now if you must.
OZATV, the aussie quad forum
2005 KFX700-its a green one
FLEXX BARS
UNI-filter, keeps it clean
dura blue axle
a shit load of shiny stuff on the way
Shiny bits are by AC
Twin Yoshie's, make it all that sweeter to start up
QPG S/S brake lines
Powermadd star hand protectors (with trail mirrors)
Set of elkas.
Itp mudlites.
American star a arms, hiem jointed, tie rods.
http://www.youtube.com/user/aussieyo...54/-1Ndbmw_W8c
yogie is offline
post #89 of 90 Old 07-20-2014, 01:17 PM
Feedback Score: 5 reviews
Alright guys I need a hand at a starting point. Amr730 pistons fst stage 2 cams on a partially gutted stock exhaust, yeah I'm broke for a while it was free and free is for me, I have a copperhead vdi gen2 I will be running on the bike I have a set of 36's and fst upp intakes that came off a 900 kfx so jetted big 48's and 145's I believe front and rear. I know it probably will be to much fuel for a 730 with a mild cam so just looking for a good starting point. Thinking 40's and 120's as a start. Also no porting or anything done to head other than dual springs.
nate_1503 is offline
post #90 of 90 Old 07-20-2014, 03:08 PM
diggin riggin's Avatar
140 mains should be close with the taller GYTR filter (or k&n equivalent) filter and stock needles. Not sure how much impact the stock exhaust will have though, better to start off rich anyway. 40-42 pilots for stock or other non crossover intakes. My buddy is in the low 120's but has dynojet needles.
Prairie 730
KFX FST 820
diggin riggin is offline
36mm carb filter # vtprairie03 Kawasaki KFX700 V-Force 8 02-27-2009 11:47 AM
36mm carb needles bb 650 Wanted 2 08-27-2008 11:52 AM
36mm carb pilots fastfatboy Kawasaki KFX700 V-Force 10 05-11-2008 03:07 PM
730's WITH MUZZY - 36mm CARB JETTING????? rpm Kawasaki KFX700 V-Force 25 05-08-2008 02:29 PM
36mm Carb air/fuel bb 650 Kawasaki KFX700 V-Force 3 04-19-2007 01:27 PM
