Mule pro fxt air filter upgrade - Kawasaki ATV Forum
post #1 of 13 Old 11-17-2018, 05:14 PM Thread Starter
Hello I just watched a video on YouTube by Hesters Motorsports about a air filter up grade for the FXT basicly you use a air filter for a T-rex didn't know this was a problem but they said they have been having some engine failures because the stock air filter allows to much dirt into the engine. Just thought I would pass it on check out the video on you tube. I think I will be changing mine over to the T-rex air filter
Reurink is offline
post #2 of 13 Old 11-17-2018, 05:33 PM
Interesting. I didn't realize that people are having a problem with engine failures due to the air filters. I wonder why Kawasaki doesn't just use the Teryx filters as oem? Can't be much cost difference.
Here's a link to the video
farmer_74 is offline
post #3 of 13 Old 11-17-2018, 05:35 PM
mtimesplitter167's Avatar
Garage
Quote:
Good find,Thank you.
2018 MULE PRO FXR
High lifter,lift kit
Tusk Warthog 29x11x14
STI HD6 Alloy Radiant Red
Air intake snorkeled
Clutch snorkeled
Volt meter/USB charge ports
Temp gauge
oil pressure gauge
Back up lights
Spare tire mount(Home made)
EPI clutch kit
Fan override switch
Gates Carbon 42C4266-belt
Kobalt tool box=Lows #67697
Factory UTV A-Arm Guards
mtimesplitter167 is offline
post #4 of 13 Old 11-17-2018, 11:30 PM
Easttxhoghunter's Avatar
Garage
Just ordered one, have been running a pre-filter for a couple of weeks, but this will make it even better.IMG_0892.JPG
Easttxhoghunter is offline
post #5 of 13 Old 11-19-2018, 03:20 AM
Quote:
Video link didn't work but I found it on YouTube. I appears to me that the problem with the original filter is only a problem if the filter isn't changed until after it's plugged and the engine sucks air past the foam gasket. The fact that the gasket will fail at this point is a design flaw.
I have a new original filter and check mine regularly, so I think I'm Ok. Having said that, I'll buy the Teryx filter as a replacement because it has much more surface area.
NWPATim is offline
post #6 of 13 Old 11-20-2018, 05:26 PM
UNI is $30 off Amazon.
Not bad for a "Lifetime" filter.
https://www.amazon.com/Uni-Multi-Sta.../dp/B007TWY76K
toddstang is offline
post #7 of 13 Old 11-20-2018, 05:54 PM
Garage
I bought mine from ebay.
https://www.ebay.com/itm/UNI-AIR-FIL...yPvo:rk:1:pf:0
2018 MULE PRO FXR
Clutch snorkeled
Temp gauge
oil pressure gauge
Back up lights
EPI clutch kit
Fan override switch
post #8 of 13 Old 11-21-2018, 11:03 AM
Garage
It’s hard for me to believe this is an issue. Donelson filters are top notch. They’re used on a lot of heavy duty equipment, tractors, zero turn mowers. If a person uses any amount of common sense there won’t be any issue with any type of air filter.
The filter shown for replacemt should let more air in but intuitively it seems it would let more dust in. Am I missing something here?
I’m not knocking the filter shown. It will perform differently from the Donelson with pros and cons. But to me it seems very naive to think it’s better for dirt/dust.
Please feel free to refute my line of thinking. I’m open to learning something here.
FriendofCoal is online now
post #9 of 13 Old 11-21-2018, 11:58 AM
Quote:
Originally Posted by FriendofCoal View Post
Itís hard for me to believe this is an issue. Donelson filters are top notch. Theyíre used on a lot of heavy duty equipment, tractors, zero turn mowers. If a person uses any amount of common sense there wonít be any issue with any type of air filter.
Iím not knocking the filter shown. It will perform differently from the Donelson with pros and cons. But to me it seems very naive to think itís better for dirt/dust.
Please feel free to refute my line of thinking. Iím open to learning something here.
I was thinking the exact same thing. We use these type of filters on all of our farm equipment (combines, bailers, tractors, harrowbed). It seems strange that if the Teryx filter (11029-0025) works better on the Mule, why design two different types, including having to design and manufacture the inner housing that seats the filter into the box for the mule, when it would be unnecessary if using the Teryx filter?
The mule is a working machine, the Teryx is a play machine. Maybe that's why the different filter.
Is the Teryx filter able/intended to be blown-out and cleaned regularly? I have no knowledge of that filter.
Something is off here...but I would sure like it if Kawasaki would send out a TSB to Mule owners if this change is needed.
defenestrator is offline
post #10 of 13 Old 11-21-2018, 02:05 PM
+1
No refute from me.
Sounds like the crappy foam seal failing (not the paper filter).
Personally I trust a paper filter with a good rubber seal (like a Donaldson) more than the foam filters
05 Kawasaki Brute Force 750 (sold)
09 Kawasaki Versys
05 Polaris XC 800 SP
2016 Polaris RZR 900s
riderX is offline
Mule 610 Upgrade Project (lots of pics) NVBigBlue Kawasaki Mule 6 02-21-2014 09:19 AM
Just got a UNI filter cdcbarr Kawasaki Brute Force/Prairie/Bayou 4 09-07-2013 10:12 PM
After market oil filter - Bayou 220 BigYoung Kawasaki Brute Force/Prairie/Bayou 7 03-24-2013 05:50 AM
Where To Get OEM Air Filter ? 05-BF-650 Kawasaki Brute Force/Prairie/Bayou 11 02-15-2013 07:20 PM
V FORCE OIL FILTER mister Kawasaki KFX700 V-Force 6 11-02-2006 03:09 PM
