Cold Natured - Kawasaki ATV Forum
post #1 of 14 Old 12-12-2018, 05:30 PM Thread Starter
Cold Natured
On a cold start my Mule Pro FXT often requires a second start before I can pull away..It idles rough until warmed up which can take a minute..Normal are no???
Lawman1 is offline
post #2 of 14 Old 12-12-2018, 05:42 PM
Mine does not do that. It initially a little sluggish, but starts/idles great.
Sent from my SM-G955U using Tapatalk
jcummins is online now
post #3 of 14 Old 12-13-2018, 03:59 AM
My '16 did that recently for the first time, but it had been at least 6 weeks since I started it last.
NWPATim is offline
post #4 of 14 Old 12-13-2018, 05:19 AM Thread Starter
Lawman1 is offline
post #5 of 14 Old 12-13-2018, 11:44 AM
NJBourne23's Avatar
Garage
not sure if you have fuel injection or not but if not this seems normal on really cold days
NJBourne23 is offline
post #6 of 14 Old 12-14-2018, 05:30 AM Thread Starter
It's only 1 - 2 years old so I'm sure it is fuel injected..
Lawman1 is offline
post #7 of 14 Old 12-14-2018, 08:45 AM
mtimesplitter167's Avatar
Garage
Quote:
Yes it is fuel injected.
2018 MULE PRO FXR
High lifter,lift kit
Tusk Warthog 29x11x14
STI HD6 Alloy Radiant Red
Air intake snorkeled
Clutch snorkeled
Volt meter/USB charge ports
Temp gauge
oil pressure gauge
Back up lights
Spare tire mount(Home made)
EPI clutch kit
Fan override switch
Gates Carbon 42C4266-belt
Kobalt tool box=Lows #67697
Factory UTV A-Arm Guards
mtimesplitter167 is offline
post #8 of 14 Old 12-14-2018, 08:46 AM
Garage
Not normal,it should start and run smooth and not die.
2018 MULE PRO FXR
Clutch snorkeled
Temp gauge
oil pressure gauge
Back up lights
EPI clutch kit
Fan override switch
post #9 of 14 Old 12-15-2018, 07:28 PM
Quote:
Update: That was two weeks ago. I started it Thursday and it was fine.
NWPATim is offline
post #10 of 14 Old 12-19-2018, 03:32 AM
I had this happen a couple times when it was really cold, in the teens, and found if I cycled the key twice to allow the fuel pump to prime twice and then crank, it resolved that issue. I've since replaced the plugs and haven't had the issue again. Not sure what the real issue was or is but when it was happening, that double prime did the trick. Just wanted to throw this out there for anyone else that might experience this issue. It's worth a try.
rototerrier is offline
How cold is to cold fstang24 Kawasaki Brute Force/Prairie/Bayou 35 03-11-2010 06:48 PM
Cold Weather Apparel jakedogg Tips/Help 2 01-09-2010 02:20 PM
Cold natured mojave. TheCableGuy Kawasaki Mojave/Lakota 8 12-28-2009 06:53 AM
It looks like a COLD winter is coming. asnowmobiler Club Kawie 8 10-27-2009 08:06 PM
cold natured 650 brute cagle1 Kawasaki Brute Force/Prairie/Bayou 10 10-10-2006 12:58 PM
