Lift kit recommendations - Kawasaki ATV Forum
post #1 of 7 Old 12-23-2018, 06:44 PM Thread Starter
I purchased a 2018 Kawasaki Mule Pro FX EPS and I got a question about attachments. I just want to add some clearance to the Mule and Iím concerned what items I will need to get.
My end goal will be to eventually get Camso Tracks and from reading Camsoís website, 2 inch lift will be required before installing them.
I read that people add wheel spacers or ball joints, clutch kits or A-Arms or maybe springs, when they change to lift kits. Are any of these items needed to support a lift-kit? Iím looking to get what I need along with the lift, so I donít damage my rig.
Can anyone recommend a site to purchase them? I see that the price varies from $250 up to $400. Is there a big difference with the more expensive ones?
Any advice for a newbie would be appreciated! Thanks!
Checker1965 is offline
post #2 of 7 Old 12-24-2018, 07:20 AM
mtimesplitter167's Avatar
Garage
I would go with the highlifter lift,i did .IMO it is the best one.I went with 1" wheel spacers.I dont know if you need spacers with tracks.
2018 MULE PRO FXR
High lifter,lift kit
Tusk Warthog 29x11x14
STI HD6 Alloy Radiant Red
Air intake snorkeled
Clutch snorkeled
Volt meter/USB charge ports
Temp gauge
oil pressure gauge
Back up lights
Spare tire mount(Home made)
EPI clutch kit
Fan override switch
Gates Carbon 42C4266-belt
Kobalt tool box=Lows #67697
Factory UTV A-Arm Guards
mtimesplitter167 is online now
post #3 of 7 Old 02-28-2019, 07:20 PM
I did a 4” lift on my 2018 FXR on 28” tires with 2 “ wheels spacers.
File Type: jpeg A679CB9F-04E6-4EFE-9101-292E4855DE4B_1551410375282.jpeg (889.0 KB, 24 views)
File Type: jpeg 7573796E-87ED-4040-8A70-E3D9ECE1F492_1551410391080.jpeg (858.3 KB, 18 views)
masterNmind is offline
post #4 of 7 Old 04-10-2019, 10:44 AM
savin_yours's Avatar
Where did you get spacers from?
savin_yours is offline
post #5 of 7 Old 04-10-2019, 07:52 PM
Put a 2" highlifter on my 19 pro fxt ranch which lifted it about 3 3/4 inch total and I'm impressed.
I won't be adding spacers because of some tight and narrow places between big rocks where we sometimes ride in Lake Havasu, AZ area. spacers might look better but narrow will get thru tighter places and save on tires in the long run. You will have plenty of clearance and won't need to add other things, I would try that first and add things later if you want to.
roadhog2546 is offline
post #6 of 7 Old 04-11-2019, 07:25 AM
Savin' - I used these spacers with my Highlifter kit. I really like them, but I did notice that the studs can get a little rust on the ends if re-using your stock open-faced lugnuts. I believe I went 1" spacer on front and 1.5" on back, which the front wheels now currently only stick out 1/4-1/2" wider than before I installed the lift. I may decide to get the 2" for the rear and move the 1.5" to the front now, since I prefer a wider stance.
Below are some pics of the spacers being installed. I will see if I have pics of the stance after install to show the resulting wheel/tire width with the spacers. Hope it helps.
https://www.sidebysidestuff.com/bill...content=Brands
defenestrator is offline
post #7 of 7 Old Today, 05:23 AM
Garage
I also used the Highlifter 2" kit, and measurements before and after showed a 3.75" increase in body height. The 2" is the distance that they move the shock mount point outboard. Raising the body of course does not raise the axles or differentials; that can only be achieved with larger wheels and tires, but a 2" larger wheel only raises the vehicle 1".
17ProDx is online now
4010 trans lift recommendations Uct Kawasaki Mule 2 04-01-2017 08:32 AM
Mule Pro Fxt mule lift recommendations bhess Kawasaki Mule 37 12-19-2016 07:20 AM
2" lift kit 360/700/650 straight axle high lifter kclack2727 For Sale 0 04-06-2010 06:21 PM
working on a new lift for my P700 speedy81304_KVF700 Kawasaki Brute Force/Prairie/Bayou 2 06-01-2009 12:34 PM
Cycle country Extended manual lift, for plow NJ or PA kmmon1 For Sale 0 12-10-2006 02:05 PM
