2018 Mule PRO FXT EPS - Lift Issue - Kawasaki ATV Forum
post #1 of 4 Old 04-18-2019, 02:42 PM Thread Starter
T. Baggin's Avatar
I have a 2018 Mule PRO FXT EPS. I use it exclusively at the ranch in West Texas which means I need ground clearance and the ability to allow the suspension to articulate
I purchased the High Lifter 2” lift, installed it and it was great. Well, almost. I needed a little more height to clear some of the larger rocks, so I ordered the High Lifter Max Clearance A-Arms - front and back.
I was told over the phone, prior to ordering, that it was no problem to use both the 2” lift and the a-arms. Well, that proved to be incorrect.
The rear was perfectly fine. The front, however, was a different story. The front wheels had a severe camber issue. Since their a arms are not adjustable, I called them to ask about the issue. They asked if I had a lift on it, I told them what I had and they were clueless.
Next they wanted me to send the a-arms back (at my cost) and let them look at them. Well, I pulled the lift off and the camber issue was fixed.
Now I need to pick your brains to see if anyone is aware of a lift I can run with these a arms in order to allow ample room for the 30” tires.
Any help you pros can provide is much appreciated!
T. Baggin is offline
post #2 of 4 Old 04-18-2019, 08:04 PM
How high did the a arms lift it.
roadhog2546 is offline
post #3 of 4 Old 04-19-2019, 08:26 AM Thread Starter
T. Baggin's Avatar
Not much, if any.
post #4 of 4 Old 04-19-2019, 11:59 AM
I don't have the a arms but have the 2" lift which they said would raise it 2" but it raised it 3 3/4 " and it looks higher than it should but performs very good. If the a arms don't raise it much at all you should be ok. I've been thru some wicked angles and beat it up in the dirt and no problems but bigger tires would get you more clearance with the lift kit and not change all the angles any more than what you have. let us know what you end up with?
Kawasaki Mule Kaf620e 2007 Fuel Pump Issue asand211 Kawasaki Mule 0 04-06-2019 06:12 PM
2018 Mule Pro FXR smells like burned oil johnWI Kawasaki Mule 12 12-22-2018 06:40 AM
Mule 610 Upgrade Project (lots of pics) NVBigBlue Kawasaki Mule 6 02-21-2014 09:19 AM
Kawasaki mule lift kit SuperATV Kawasaki Mule 0 11-15-2010 10:19 AM
2" Kawakaki Mule Lift SuperATV Kawasaki Mule 0 05-24-2010 06:05 AM
