Mule Pro EPI clutch kit - Kawasaki ATV Forum
post #1 of 13 Old 04-26-2019, 05:58 AM Thread Starter
Who has one installed? What does it change over stock? Any downsides to it?
NonTypicalCPA is offline
post #2 of 13 Old 04-26-2019, 06:36 AM
Garage
Quote:
Do you ever search before posting? This topic is like 3 below your post?
FriendofCoal is online now
post #3 of 13 Old 04-26-2019, 06:41 AM
https://www.kawieriders.com/forum/ka...lutch-kit.html
Changes out OEM clutch springs to stiffer clutch springs. Makes take-offs quicker for 26-27" tires, maybe 1-2 mph higher top speed (I was up to 46mph). Specific springs to use depending on tire size. I've read somewhere that if running 28+ inch tires, it brings the mule back to factory quickness for low and mid range. It may improve it beyond, but I have no experience with that.
I really like the results. Mule is definitely quicker on low and mid-range. I haven't yet tested if engine braking has improved, but I read that it supposedly does.
Perhaps read the reviews for other's opinions.
https://epiperformance.com/economy-clutch-kit-we437501/
defenestrator is offline
post #4 of 13 Old 04-26-2019, 07:55 AM Thread Starter
Thanks Defenestrator. Does it make low speed clutch engagement harsh? I love the engagement of my mule over my past Polaris Ranger. Any downsides for you so far?
post #5 of 13 Old 04-26-2019, 08:27 AM
Not harsh at all. The pedal isn't touchy, it just gets from 0-15 much quicker, 0-30 as well. Still easy to maintain lower speeds. I actually like the pedal better. It actually responds when you want it to, rather than that stock, mushy, momentary pause before it gets moving. My kids had the hardest time with the pedal when we first bought it new. It's much better pedal with the EPI springs. It almost felt like an electric vehicle take-off when using the stock springs.
No downsides that I can tell, but if you really want to tear up the ground, you can now, especially in accelerated turns.
post #6 of 13 Old 04-27-2019, 08:50 AM Thread Starter
Thanks Defenestrator. Sounds like I need to swap springs. Do you have any other mods you like?
post #7 of 13 Old 04-29-2019, 07:26 AM
Keep your expectations reasonable. The EPI springs aren't going to turn the Mule into a super quick machine. It will just make it more responsive and quicker than stock, especially on trails with a lot of tighter turns that require the vehicle to slow down, and then have to get back up to speed. Worth it to me for the small price.
The only mods I've done are:
-SuperWinch
-Aluminum skid plate (a must if doing rough trail riding. I've high centered/scraped so many times I obviously needed a lift.)
-Highlifter (see above)
-CV Joint/A-arm guard sets. From ebay, but I actually like Kawasaki's better, more coverage, but 50% more expensive.
-Wheel spacers after lift
-Aluminum roof. DIY. So much cheaper than buying them after market, but those are nice.
-Under seat storage mods. Both the raised center bin and a drop-in garbage can that rests on the side skids.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
-NOAM Bluetooth and speakers
-EPI Springs
-Dynamat and hoodliner under the lift-bed. Cuts down the engine noise/echo and bed vibrations. Can have a normal conversation with passengers at speeds without having to yell.
-fabric seat covers. Good for summer heat.
-Hood Scoop. Worked fantastic this weekend with mid-90's. No heat in the cab at all after running all day
-Swap out 12-volt cig lighter receptacle for USB charger w/voltmeter:
-UNI Air Filter
Mods still need to do:
-Hinged seat mod. How in the world Kawasaki doesn't have a hinge on the front seat is baffling to me.
-new tires, perhaps ITP Blackwater or Tusk Terabite, maybe wheels, but they aren't needed yet.
-rear bumper
-maybe swap out non-LED OEM lights
post #8 of 13 Old 05-01-2019, 05:19 PM
we are on 27" tires, should we use the white spring or pink spring? Never get above 30 mph around the place
steven liebchen is offline
post #9 of 13 Old 05-10-2019, 06:36 AM
(Since I posted this in a different thread)
I'm still running 26" tires. I won't go above 27". I used Yellow for Primary clutch, and Pink for Secondary. I believe if you are running 28"+, there is another color (perhaps white?) that you run. I don't quite remember now. I talked with EPI and they told me which to use for my tire size.
post #10 of 13 Old 05-15-2019, 05:55 PM
the spring for 28" + tires is the PINK spring. It was too revvy for stock, so use the WHITE spring for up to 27" tires
secondary clutch removal Mule 4010 frank losch News/Support/Feedback 0 11-21-2018 10:32 AM
Kawasaki mule fuel pump for sale 550Mule For Sale 0 06-02-2018 11:31 AM
2016 Kawasaki MULE PRO-FXT Model Range 4Nines Kawasaki ATV News / KawieRiders.com News 3 10-24-2016 03:56 AM
2016 Kawasaki MULE PRO-DX 4Nines Kawasaki Mule 1 06-02-2015 06:23 AM
mule 610 clutch pike13 Kawasaki Mule 3 10-23-2012 06:12 PM
