Hesitation when first applying pressure on gas pedal - Kawasaki ATV Forum
post #1 of 7 Old 05-09-2019, 03:41 AM Thread Starter
Since new the PRO FX has had a notable delay in response between my initially pressing down on the gas pedal and the clutch engaging the engine. This is not a problem on flat surfaces, but when starting on a steep incline I find I have to either keep the parking brake engaged or use my left foot on the brake while giving it gas or the Mule will roll a significant distance. Is this an inherent characteristic of how the clutch engages or is there an adjustment I can make to remedy it?
PETDOC is offline
post #2 of 7 Old 05-09-2019, 06:30 AM
Yep. Always bugged me, so I did the clutch spring kit and it's gone.
https://www.kawieriders.com/forum/ka...lutch-kit.html
defenestrator is offline
post #3 of 7 Old 05-10-2019, 04:47 AM
What size tires do you have and which color spring did you use?
jcummins is offline
post #4 of 7 Old 05-10-2019, 06:34 AM
I'm still running 26" tires. I won't go above 27". I used Yellow for Primary clutch, and Pink for Secondary. I believe if you are running 28"+, there is another color (perhaps white?) that you run. I don't quite remember now. I talked with EPI and they told me which to use for my tire size.
post #5 of 7 Old 05-15-2019, 05:58 PM
its the opposite of what is said above- EPI says white spring for up to 27" tires, pink spring for 28" and up
if you are running 28"+, there is another color (pink)
steven liebchen is offline
post #6 of 7 Old 05-16-2019, 06:34 AM
Thanks for this. I couldn't remember.
post #7 of 7 Old 05-16-2019, 11:06 AM
sure thing, we learned that by having to put them each in!
Brute Cooling System keeping pressure Lineman052 Kawasaki Brute Force/Prairie/Bayou 11 08-26-2017 10:54 AM
Turbo Teardown Camo Member Pictures & Movies 187 03-15-2012 04:56 PM
Tire pressure.. what a joke! screamin96 Club Kawie 9 10-17-2011 05:14 PM
Fuel pump pressure LAVRx Kawasaki Brute Force/Prairie/Bayou 6 11-02-2009 04:33 AM
FPS cam testing update Dynoray Kawasaki KFX700 V-Force 439 11-21-2007 10:02 PM
