Mule Pro FXT Oil/Grease in Clutch Cover - Kawasaki ATV Forum
post #1 of 5 Old 05-19-2019, 06:52 PM Thread Starter
Need some help guys. My belt was slipping toward the end of deer season and figured I needed a new belt so got one ordered. Tonight I took off the clutch cover and everything inside was full of oil and grease.
I stopped there as it was getting late but curious where this all came from? Belt looks fine but suspect all the slippage was from the oil and grease. Any ideas or do I have a bigger issue on my hands? Thanks in advance.
Southdakota_man is offline
post #2 of 5 Old 05-22-2019, 07:25 PM
Looks like the o-ring on the drive pulley needs replacing. Easy fix if that is the problem
GeorgiaRTVrider! is offline
post #3 of 5 Old 05-26-2019, 11:47 AM
there`s a o ring between your drive coverter and gear box but I think that is just to keep out the dust and dirt you may want to pull your clutch and look where it goes in the gears to see if you have oil in there. and have you checked your oil level if you losing any oil you may have a problem further back in your gear box is that gear oil or motor oil
shadowm77 is offline
post #4 of 5 Old 05-27-2019, 07:28 PM Thread Starter
I changed the oils right before tearing into the clutch so couldnít tell if it was low. Is the gearbox oil sealed? Meaning there is nowhere to check/fill it?
I tried to take the secondary clutch off ( yes I know it is left hand thread and used M8 bolts and a box end wrench to hold the clutch tight. Could not get the bolt to budge with big ratchet or impact. Was afraid to snap it if I tried any longer. I ended up pressure washing all the grease and oil off everything and then dried it all with air compressor. Itís hard to tell where it is coming from without being able to pull the secondary clutch.
May just put it back together and drive it a bit to see if it happens again. Thoughts
post #5 of 5 Old 05-28-2019, 05:03 PM
maybe if you go to kawasaki.com you may have to sign up to view the pdf files but it should be helpful
Honda Pioneer 1000 vs Mule FXT Ranch Edition Plumber101010 Kawasaki Mule 11 03-22-2018 07:11 AM
2016 Kawasaki MULE PRO-FXT Model Range 4Nines Kawasaki ATV News / KawieRiders.com News 3 10-24-2016 03:56 AM
2016 Kawasaki MULE PRO-DX 4Nines Kawasaki Mule 1 06-02-2015 06:23 AM
HELP!!!!! Mojave clutch cover wildcard Kawasaki Mojave/Lakota 4 02-05-2010 06:31 AM
Ever seen these clutch weights??? asnowmobiler Kawasaki KFX700 V-Force 17 10-24-2009 07:40 AM
