Hello I picked up a running 01 mojave for $500. It makes clunks in 2nd gear only, so assuming it's the gear missing a tooth. I have the motor pulled and noticed after cleaning it up that the left side case has been jb welded pretty heavily so I plan to replace the case, are their any years that will only work with specific years... I ended up finding a 02 set of cases for 75 so hoping I won't have any issues. My plan was to still use the 01 stock right case and then use the 02 left side case any reason this wouldnt work?
If the new cases are ok and servisable use them , when manufactured cases are usually machined as a pair to assure alignment , by chopping and swapping you possibly open a can of worms and grief ..!!!!
