Ok so lights are flashing back and forth on dash. measured resistance on the actuator and all seems Fine. The Front actuator for 4x4 wont move and when you turn key on the one for engine breaking moves Real slow or not at all. Am I thinking right that the Controller may of actually went out? is there a way to check it?
What is the pattern on your dash?
When turning the key to ON, the engine brake actuator may make a small noise or no noise. When you turn your key to OFF, it should make its little round then stop. How did you check the 4WD actuator? The wheels must spin a little for it to engage, changing 2WD => 4WD or 4WD => 2WD while standing still won't do anything.
76079
Pattern is #3 CHecked the 4wd actuator with an Ohm meter per manual was within ranges. The belt actuator makes no sounds Turning on or Off. The KEBC has been took out for years Just got the Actuator there doing nothing. Can it be bypassed?
You can put in a KEBC delete kit. Check out Sgroi Innovations and look up the delete kit as I am unsure what years it fits.
