1 - 20 of 23 Posts
What location would be best on this CT Racing Pipe? One in each head pipe, or one in the canister where the 2 meet?
Also, what will have to be done to weld the bung in with the coating used on this? I believe it is similar to Jet Hot.
The coating going to have to ground off. No way around it. I think the anal folks are doing three bungs. One cylinder at a time to get it dead on and one in the collector to monitor. One in the collector would be fine though. JMHO
The merge collector is really close to the can. How are you going to avoid picking up pulses from individual cylinders?
On my BKuzzy system I have one exhaust bung at the end where the two pipes meet.
Right about here,with the sensor as straight up as possible.
I almost bought that CT system off BANDAMAN when he first posted it. Looks like a grate exhaust, be sure to report back after you have it installed and tuned in. I'd love to hear a sound clip to if you can get it.
Discussion Starter · #7 ·
Thanks for the input, guys. I'm going to see what BigKev thinks on it..he will keep it aesthetically pleasing. :D
Discussion Starter · #8 ·
Got the pipe today! Nicer than I expected. Now its off to BigKev for an 02 bung in the canister, and I think I'm going to order the other tip for it.
:D
That is sharp.. I like it.
Glad you like it:)
Told you guys it was nice, can't believe it took so long to sell. ya bunch of muzzy lovers! :lol: I hated to sell it so cheap, but I don't have any use for it.
Thanks Travis! :cool:
Looks very nice. Yea if I would have bought it I would have also put the other tip on it as well.
Yeah, I thought about it too but couldn't get past that disc-type end cap. I hated the way the exhaust flow came out on the White Bros E-Series that I used to have on my orange V.
I don't understand how you can tune each side correctly without a bung on each header---How do you know which cyl needs adjustment when they are read from one bung placed on the the 2in1 collector??????
The anal type mentioned seems like a good idea--fine tune each separately--Then see if it's consistent in the connector.
Can someone sort this out a little---Thanks
Kenny
Discussion Starter · #15 ·
This is how BigKev sorted me out. IF you are drag only, one in each cylinder is a must for tuning purposes. If it is a general purpose bike one in a central spot should be fine. I am just using this for tuning purposes with a small shot. When I get to the point that I am spraying over a 40 or so shot I will get some drag pipes made and put one in each head pipe.
Most dyno's just use a sniffer to check the AF Ratio, which is a piece that goes into the exhaust. If that works for a dyno, then this should be fine for my pansy lil 715..
Your not running over a 40 shot? So, that means I am not doing the nitrous jetting for ya? lolololol
Discussion Starter · #17 ·
I gotta crawl before I can walk..;)
speaking off.. I gave jammer a hand putting a +8 on his bike this past weekend.. Gauge did a fantastic job on it.. YOU NEED one....
Discussion Starter · #19 ·
Think I'm gonna get me a 10" when I decide to get it done.
His was a lot nicer than mine is... it is a bit heavy, but.. dear lord.. no way you are breaking it...
1 - 20 of 23 Posts
